Old May 16, 2012, 06:25 AM
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Originally Posted by spcpicard View Post
like my other Crack planes I added my own personal touch
Attachment 4865072
Awesome!
STLAV8R is offline Find More Posts by STLAV8R
Old May 16, 2012, 06:56 AM
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Attachment 4865072
Man you won't miss that coming
Gota get some UV light shone on it to see how it shines up
Aviefly is offline Find More Posts by Aviefly
Old May 16, 2012, 08:08 AM
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
Attachment 4865072
Awesome!
cwojcik is offline Find More Posts by cwojcik
Old May 16, 2012, 09:30 AM
Bedford, Mass. USA
Joined Dec 2007
Well, mine arrived yesterday and I stayed up late working on it last night. I'm having fun building it... probably two more relaxed nights of building ahead. Hope to maiden it this weekend.
Nice design so far!
javabeans is offline Find More Posts by javabeans
Old May 16, 2012, 05:53 PM
morgantown, wv
Joined Mar 2004
I just lost the o-ring that holds the prop on while i was flying. Luckily i seen where the prop had landed and i was able to set the plane down on the tall hay. After about 15 minutes of looking for a prop in a hay field, I found it. That o-ring lasted about 30 flights. I found a heavy duty one in my home tool box and it holds the prop on tighter. Before i lost the o-ring and prop i could tell something was not right with it. When i was doing fast elevator changes i could hear the prop vibrating. Then it just let loose. I need to buy these little o-rings in bulk. And maybe find an easier to see bright colored prop. I was lucky to find the stock black one in the 3ft tall hay. I really do love flying over it though. I have crashed a number of times and the plane still looks new. Not a crack or bend in it anywhere. I know that if i was flying over the back yard and crashed the plane would not look as good as it does. I keep my grass cut short in the yard.
buster7467 is offline Find More Posts by buster7467
Old May 16, 2012, 08:15 PM
3RN13
ernie b's Avatar
West Chicago, IL.
Joined Feb 2008
Originally Posted by buster7467 View Post
I just lost the o-ring that holds the prop on while i was flying..
Don't waste your time with O-rings, see post 240. Do yourself a favor and get the surgical tubing, you'll never use O-rings again.
Ernie
ernie b is offline Find More Posts by ernie b
Old May 17, 2012, 03:31 PM
dynodude's Avatar
El Cajon, CA
Joined May 2007
What OD / ID surgical tube are you guys using?
dynodude is offline Find More Posts by dynodude
Old May 17, 2012, 03:59 PM
3RN13
ernie b's Avatar
West Chicago, IL.
Joined Feb 2008
If no one replies by the time I get home 5pm Central, I'll take some measurements and get back to you.
Ernie
Old May 17, 2012, 04:22 PM
Aviefly's Avatar
Joined Feb 2005
Eventually got a little time to get started on one of the Crack Pitts tonight, decided not to build the two of them together so if I make a mistake it won't be on both of them.
Got my gear all set up for neutrals and directions, arms on and set up. All wooden parts sanded, holes ca'd then cleared out to suit z bends or quick links. Z bends fitted to rods and quick links fitted in the relevant places. All hinges UHU Por'd on the ends(inside) and a patch of blenderm fitted to strengthen them, already been doubled over and weighted down to loosen. The tail plane is on as is the lower back bone and black gussets. Gona leave it to set for the night now to make sure it stays square before I fit the rudder and elevator servos, the extra bit's of wood and the top fuse. I find it quite ingenious the way Twisted has designed the extra strength in where needed to the existing and proven design of the rest of the Crack series, looking forward to getting the rest done and seeing it come together.
As I sat pondering in the workshop I couldn't help but notice as I cast my eye over my fleet of Twisted foamies that there seems to be something missing.
The Edge is 04, the Crack Yak is 07, the mark 2 Slick is 08 and now the Crack Pitts is 09. I presume previous designs account for 01, 02 and 03 but what happened to 05 and 06? and what do we have in store for 10
Old May 17, 2012, 05:12 PM
♫ Learning to fly ♫
dataylor57's Avatar
USA, NC, Greensboro
Joined Dec 2010
I use the latex tubing from Lowes plumbing department. Just over a dollar a foot.
dataylor57 is offline Find More Posts by dataylor57
Old May 17, 2012, 06:44 PM
3RN13
ernie b's Avatar
West Chicago, IL.
Joined Feb 2008
Hey Dynodude, sorry for the late reply, I got seriously sidetracked.
ID = 5mm, OD = 8mm
Later
Ernie
Old May 17, 2012, 07:13 PM
morgantown, wv
Joined Mar 2004
I am hoping to stop by Lowes tomorrow to see if they have any surgical tube. After losing the first one i don't trust them. I was lucky to find my prop when it went flying off. I am also going to place an order for a couple more props.
Old May 17, 2012, 10:31 PM
Joined Feb 2008
If it will fit I think many put on two "O"-rings or rings from surgical tube. Especially if they do a lot of violent stunts.
e-gull is offline Find More Posts by e-gull
Old May 18, 2012, 06:14 PM
dynodude's Avatar
El Cajon, CA
Joined May 2007
ID = 5mm, OD = 8mm
Later
Ernie
Thanks. Gonna see if I can find some at LHS or Lowes.
Old May 18, 2012, 08:31 PM
Crack Team
Dan5.0's Avatar
Joined Dec 2008
I usually use 2
Dan5.0 is offline Find More Posts by Dan5.0
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 5854 Yesterday 07:27 PM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1266 Jun 17, 2013 01:19 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 521 Jun 12, 2013 08:06 PM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
