Old Feb 06, 2013, 07:08 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I'm a pretty 'carefree' builder myself when it comes to slight appearance imperfections.....
HOWEVER....
in this case, believe it or not, it might be that that much offset will cause the fuse to be pulled into a banana shape and not perfectly true.
Perhaps not, but I would definitely carefully check.
On this type of plane, the most important thing is that all the glued parts be axial, level, even, lined up, etc.
So I'd carefully check to see what stresses that might be causing. It's possible you'll decide to carefully use a scalpel to undo the bond, then carefully align and re-bond. If needed, it's a tough bird, it can take it!
tracknoob is offline Find More Posts by tracknoob
Old Feb 06, 2013, 07:26 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
On my two builds I pretty much followed the build Cody did with a few exceptions. No landing gear on my first Pitts and ez connectors for the aileron links on both of them. I did watch the video but had built my first before it so I knew what to expect for the second Pitts.
stgdz you could add some epp if you have it to make it square. It's a learning process you should have seen my first foamy build. I was shocked it even flew.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Feb 06, 2013, 08:22 PM
Luv3d is offline
Find More Posts by Luv3d
Honeybadger don't care...
Luv3d's Avatar
United States, FL, Winter Park
Joined May 2010
Ah- it's fine!!! Needs a little down and little right for the prop/motor anyway.
I think you just saved a washer! Fly it as is (but put a washer in to add a touch of right thrust).
Originally Posted by stgdz View Post
Due to my awesome building this happened. Should I just add some extra welders and make up the gap or cut the EPP. I'm probably going to make up the 1/8" gap with welders. Its not like it will make a difference in a year after flying this
Luv3d is offline Find More Posts by Luv3d
Old Feb 06, 2013, 08:30 PM
Backyard is offline
Find More Posts by Backyard
Backyard's Avatar
Tresure Coast Florida
Joined Feb 2004
The video and directions are great. Any way you build it it will fly if you balance and trim it correctly.
But... and I hate to say it, if you want the best practices to build the plane you want you should read the 2462 posts above, take notes and execute your own plan. There is a TON of wisdom to be had and there are worthwhile mods.
Backyard is offline Find More Posts by Backyard
Old Feb 07, 2013, 01:52 AM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
I hadn't used landing gear on with my Pitts or my CY.
No issues, they are easy to land and no LG hassles. Lighter too. I would only add LG if I going to be landing on
Concrete or indoor, where the wheels will rotate freely.
jimbo320 is offline Find More Posts by jimbo320
Old Feb 07, 2013, 07:55 AM
swampflyer is offline
Find More Posts by swampflyer
United States, FL, Keystone Heights
Joined Dec 2012
thanks guys.
its not my first build, ive built 2 CY lites now, and im halfway through the crack wing at the moment. i just thought there were a few typos or steps out of order that i heard about here or there... but its probably rather straight forward like all the TH stuff.
i'll just go over it again today to refresh myself before beginning the build tonight.
swampflyer is offline Find More Posts by swampflyer
Old Feb 07, 2013, 07:59 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Originally Posted by swampflyer View Post
thanks guys.
if you see something while you are doing the build, especially if it does not make sense let me know, if an edit or correction is needed we will get it done.
cdee
cdee is offline Find More Posts by cdee
Old Feb 07, 2013, 08:02 AM
Joined Dec 2012
will do.
Old Feb 07, 2013, 11:32 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
As others have said a bit of down thrust might not be detrimental but even so I think I'd get the steel rule out and trim it down. I'm thinking that when you glue the fibre plate on you want the thing to sit flat and have good surface area for the glue.
I can see what Tracknoob is on about. If it's that far out down the length of the fuse I suppose it could have induced a warp, check that before you decide what to do.
Aviefly is offline Find More Posts by Aviefly
Old Feb 12, 2013, 04:30 PM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
The cold doesnt get in the way when you want a crack fix
More snow blanketting the UK again. It was bl@@@y cold. -2 and my batts were really getting affected.
Snow - Revisited (4 min 11 sec)
Old Feb 12, 2013, 05:00 PM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Nice Jimbo. I was out in it today up at our new field, brrrrrrrrrr. Though once again you've got more snow than we have
Old Feb 12, 2013, 06:58 PM
Twisted Do Nut!
Joined Dec 2010
Nice one jimbo, the Piits against the snow is cool.
We didn't get as much snow this year as the last few which is cool with me. Going from spring like weather to crazy cold, is annoying though. Waiting to see what the weekend looks like. Going get the Pitts out with the mini if it's nice.
Old Feb 13, 2013, 03:32 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
That's crazy. Our weather is truly screwy.
They have coined a new name for our climate change adjusted weather patterns.
'Monsoon Britain'
Old Feb 13, 2013, 03:35 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
You're in Southern USA/Texas aren't you?. Isn't cold for you about 80F If only we had some of your weather!
Old Feb 13, 2013, 05:31 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Flew the Yak Lite in the frontyard yesterday and it was a blistering 38 degrees. I have flown in 18 degrees earlier this winter and was fine. Just throw a hat and the transmitter glove in the car and I am ready to go!
IndyMatt is offline Find More Posts by IndyMatt
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
