Old Oct 14, 2012, 06:54 AM
Build em lite......
Joined Apr 2012
Originally Posted by stuball56 View Post
I think my hinges being too stiff is the cause of some flying problems I've had. I did tape at the ends, plus welders along the whole hinge.
Hinge tape alone, a much superior option to re-enforce any EPP hinge line.
nkhamlue is offline Find More Posts by nkhamlue
Old Oct 14, 2012, 07:28 AM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
So I am thinking of trying an idea I saw here somewhere (memory shot, lol). Said to very, repeat, very lightly score the top of the hinge with sharp xacto knife to free it up some. Cut through the welders that I put on.
stuball56 is offline Find More Posts by stuball56
Old Oct 14, 2012, 07:56 AM
Twisted Do Nut!
KamikazePilot's Avatar
Fort Worth
Joined Dec 2010
Cool jimbo we'll be waiting for videos.
It's not really scoring it but scrapping the welders off, at least that how I read it. I had acetone laying around for taking welders off and it works to free the hinges as well.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Oct 14, 2012, 08:21 AM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
I have acetone, I have a hard time remembering which solvents/thinners are safe for which foams. Acetone is ok on EPP? I know it eats pink foam very fast.
Old Oct 14, 2012, 08:31 AM
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
That sounds like a better option if it works. It was me that said I cut through the glue but not the foam when I made the same mistake with my Edge but then I am a bit of a butcher at times.
Aviefly is offline Find More Posts by Aviefly
Old Oct 14, 2012, 08:49 AM
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
Originally Posted by Aviefly View Post
Stuball. Welders along the entire hinge line is probably too much. I made that mistake on my Edge when they first came out. It was a bit dodgy but what I did was bent the surface to stretch the glue and very very carefully ran the tip of a #11 blade along it. Going by feel and sometimes it would take a few light passes until I could feel that I had reached the foam but not cut through it. The tape you have at the ends should be enough so anything in between that is just stiffening your hinge in my experience.
2s or 3s!!! that's the beauty of the stock power set. Change the prop, change the pack and change the beast your flying it really doesn't matter as long as your having fun and with the Pitts that's a given.
i run a small bead of welders all the way down the hinge line and then fold it back and wipe the hinge with my finger to get a thin coat all the way down the line,a little stiff at first but my suface doesn't come apart
lugnutz is offline Find More Posts by lugnutz
Old Oct 14, 2012, 09:39 AM
Slopeaholic
jimbo320's Avatar
Joined May 2011
I love the dual ailerons, they look Super cool.
I can see a maiden coming on, perhaps this evening... If weather plays ball, my guess is the fat Pitts won't like the wind..
jimbo320 is offline Find More Posts by jimbo320
Old Oct 14, 2012, 10:02 AM
Slopeaholic
jimbo320's Avatar
Joined May 2011
CG is on the rear of the cabana, which on mine is on the lower spar? Is that correct?
Thx.
Old Oct 14, 2012, 10:13 AM
Aviefly's Avatar
Joined Feb 2005
Yep you should be good to go at that Jimbo. Looking forward to the vid
Old Oct 14, 2012, 10:14 AM
Twisted Do Nut!
Fort Worth
Joined Dec 2010
Yeah the acetone doesn't hurt epp, that's how I reuse the hardware little acetone to loosen things up. Be careful with it around the servos it melts the casing on em.
Thx.
That's where I have both of mine setup. Good to go jimbo, enjoy the Pitts.
Old Oct 14, 2012, 12:34 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Well, she has flown. Wow, I very pleasantly surprised. She flys superbly. No trims required and straight into hangs and harriers. This baby kicks ass!
She also handled the wind very well. Flew the CY as well to compare.
It was an excellent maiden and no damage!
Old Oct 14, 2012, 03:18 PM
Aviefly's Avatar
Joined Feb 2005
Glad you enjoyed it Jimbo. The Pitts is a work of art
Old Oct 14, 2012, 03:40 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Yeah i have to agree with you there. The extra mass/area make the flying quite different.
Old Oct 14, 2012, 04:52 PM
Slopeaholic
jimbo320's Avatar
Joined May 2011
Maiden of my Pitts.
Twisted Hobbies Crack Pitts Maiden Flight (5 min 12 sec)
Old Oct 14, 2012, 05:05 PM
Aviefly's Avatar
Joined Feb 2005
That's what I've been waiting for Jimbo. Can't argue with that for a maiden, your rolling circles are really coming on. That flying field of yours is great, masses of room. How are you getting on with your ExtraVaganza?
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 5815 Yesterday 01:17 PM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1256 May 17, 2013 07:42 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 510 May 11, 2013 03:11 PM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
