Old Oct 09, 2012, 08:10 AM
RonJ is offline
Find More Posts by RonJ
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Cheezels,
I experimented on a newbie friend with a "detuned" TH Slick. Cut the throws way down and added a bunch of expo. On his maiden I instructed him to make his turns with the rudder (on left stick). The ailerons produce roll and it takes a tad of elevator to actually make the turn. He had a little stick time on an Easy Star so not completely new to R/C.
Well, his first flight with the Slick was great, including the landing. He now has a new "detuned" Pitts ready to go and I am sure it will work out for him. The Pitts is even slower than the slick.....Flying "3 mistakes" high not necessary now.
RonJ
RonJ is offline Find More Posts by RonJ
Old Oct 09, 2012, 09:34 AM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
Originally Posted by JForbes View Post
A few things, mostly all my opinion, but we'll see what others say as well....
1. Welcome.
2. Don't feel that the Pitts is only for advanced pilots. Yes, it has the abilities of being a crazy acrobat in the sky, and the build is a tad tricky in a couple of spots, but it can fly slow, and with lower rates, it will make you better. I'm proof of that. Plus, it's very tough, and will take to grass crash landings like it belongs there. lol
3. I'm sure some folks with disagree with me here, but in regards to your rudder/3 channel planes... if you have the option of putting the rudder on your left stick, DO IT!! Learn to fly and turn with your rudder under your left hand. Learn everything you can about what the rudder does... right-side up, inverted, knife-edge (plane flying on it's side), etc.... I say this for two reasons... I learned to fly without using rudder, which now I'm trying to overcome and learning to use the rudder. In these slow fly and 3D planes, you use it A LOT. Old habbits are hard to break.... which leads me to my next point. If you "learn" to fly with rudder under your right hand, then switch to a 4 channel common setup, you'll have to teach yourself all over again.
Like I said, this is just my opinion... most people fly with a common radio setup, but there really isn't anything saying you can't have the channels where you want them I guess.... Keep us updated and best of luck!
I agree with all Jforbes wrote here. Especially having the stick setup how you'll end up flying with in the end. Having to use that left stick for more than the throttle is a lifesaver with these planes.Though my first model wasn't a TH plane I had to unlearn the bad habits I picked up when I was flying a 3 channel plane.
Best of luck to ya.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Oct 09, 2012, 10:52 PM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Agreed if your radio is inclined to put the rudder on the left do it no point staying on the right when you will end up on the left.
Kris... is offline Find More Posts by Kris...
Old Oct 09, 2012, 11:04 PM
carr52 is offline
Find More Posts by carr52
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
Wow cdee a nice shiney clean looking Pitts. Ain't seen one of those in a while. Mine is shall we say a tad bit dusty looking. Nice flying. Thanks for the video.
Tom
carr52 is offline Find More Posts by carr52
Old Oct 10, 2012, 03:44 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
OK, I'm one who disagrees. If you're learning to fly on a 3 channel plane like your Slow Stick, the primary turn function (in this case the rudder) should be on the primary turn stick (in this case the right stick) Transitioning from a high wing plane with no ailerons and the rudder on the right stick to an aileron controlled plane with the ailerons on the right stick will not require much adjustment at all since you're primary "turning" control is still on the right stick it will seem natural to you.
The reasoning behind this is simple. If you learn with your primary control movement on the left stick (rudder) when you transition to an aileron controlled plane the muscle memory you learned will take over and you'll be trying to turn with your left stick even though your primary control is now on the right.
As Aviefly said if your radio is capable, do a mix master aileron/slave rudder so that the rudder moves regardless of which stick you move.
But comma however, we're getting way off topic since this thread is about the Pitts, not primary controls.
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 10, 2012, 06:18 AM
cheezels is offline
Find More Posts by cheezels
Australia, QLD, Tewantin
Joined Jul 2012
OK peoples, thanks for all the input.
Looks like there's an argument for both methods, so I'll think a bit more whilst building the Slowstick.
Sorry for diverting the thread slightly................
cheezels is offline Find More Posts by cheezels
Old Oct 10, 2012, 10:07 AM
markl22 is offline
Find More Posts by markl22
Joined Jul 2012
The last month, when the mood strikes me to fly a bi-plane, I have been choosing my new Techone Energy that I picked up on sale for $29, and let the Pitts sit. I really got to like the Energy, more so I thought, than the Pitts. But last night I gave the Pitts another try, and Wow, it is worlds ahead of the Energy. The Pitts is so good that I had forgotten.................shame on me!!! Now it is between the Pitts and Crack Yak.Hmmmmmmmmmmm.
markl22 is offline Find More Posts by markl22
Old Oct 10, 2012, 10:38 AM
Twisted Do Nut!
Joined Dec 2010
Try having the slick as well and try to decide on which one to like. Couldn't make up my mind so I fly all three whenever I get a chance. I'm more partial to the Pitts since I love bipes. Need to do some work on my two, didn't notice some damage before. Going need more packs at the rate I'm going.
Old Oct 10, 2012, 10:56 AM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Ha... I'm with ya Kamikaze... I have the Pitts and Slick as well... and I feel like a dad of twins or something... I fly one, and look at the other and think....aww man.... I should be flying you.... so I put a pack in it.... then repeat..... lol
JForbes is offline Find More Posts by JForbes
Old Oct 10, 2012, 11:03 AM
markl22 is offline
Joined Jul 2012
Kamikaze, tell me what you like about the Slick vs the Yak. Who knows, maybe I'll be able to 'make room' for one of those as well.
Old Oct 10, 2012, 11:32 AM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Pick the one you like the looks of best and buy that one. You won't be disappointed they both do everything so well.
Aaeolien is offline Find More Posts by Aaeolien
Old Oct 10, 2012, 11:53 AM
Twisted Do Nut!
Joined Dec 2010
mark in all honesty I really don't have a favorite between the slick or yak. I fly them both though the slick was the first plane I got from TH. I ended up building the yak before it. Like Aaeolien wrote pick the one you like the whole TH lineup is made of some of the best foamies I've come accross so far.
Old Oct 11, 2012, 01:19 AM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Servo arrived for my Pitts. Time to crack on with the Pitts.
jimbo320 is offline Find More Posts by jimbo320
Old Oct 11, 2012, 05:37 AM
jimbo320 is offline
Slopeaholic
jimbo320's Avatar
Joined May 2011
Shes taking shape. Oohh she feels way to flimsy for the abuse im likey to be kicking her way. I think she wont last long in my dumb thumbs..
Looks cool tho.
Old Oct 11, 2012, 05:57 AM
Kris... is offline
Registered Addict
Kris...'s Avatar
Joined Jul 2010
Dont forget Jimbo it moves a lot slower than the Crack makes rollers look majestic
I also think you will be surprised how tuff this little plane is.
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
