Old Oct 07, 2012, 09:43 PM
lugnutz is online now
Find More Posts by lugnutz
The Twisted Elf
lugnutz's Avatar
USA, NJ, Trenton
Joined Nov 2010
i put the gear on because i am going to be flying in a gym this winter
lugnutz is online now Find More Posts by lugnutz
Old Oct 07, 2012, 09:46 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Nice I'm on the hunt for a gym to fly in this winter still.
Aaeolien is offline Find More Posts by Aaeolien
Old Oct 08, 2012, 06:23 AM
STLAV8R is offline
Find More Posts by STLAV8R
STLAV8R's Avatar
United States, MO, St Louis
Joined Jan 2009
Or you could leave the gear off, save the weight and expense and just hand launch and catch it.
STLAV8R is offline Find More Posts by STLAV8R
Old Oct 08, 2012, 10:35 AM
RonJ is offline
Find More Posts by RonJ
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Here's a little video of one of the many "dirt flirt'n" flights I have had with the Pitts.
How slow and how low can you go....????
PITTS DIRT FLIRT'N #1 (2 min 49 sec)
RonJ
RonJ is offline Find More Posts by RonJ
Old Oct 08, 2012, 11:17 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Nice flying Ron. What a beautiful flying day too. Do you have any pics or details of what you did with your undercarriage? Looks good from what I could see of it.
Aviefly is offline Find More Posts by Aviefly
Old Oct 08, 2012, 01:46 PM
jimbo320 is offline
Find More Posts by jimbo320
Slopeaholic
jimbo320's Avatar
Joined May 2011
Nice Landing Ron! On the prop, were you trying to save the undercariiage? How well does the undercarriage work on grass?
Heres my build so far. Im short of a aileron servo, it died in my Crack Yak, so build is stalled until it gets here. Going together easy so far. Servo and radio in, motor everything checked over.
Does anyone have a pitts on 3s video?
Thx.
jimbo320 is offline Find More Posts by jimbo320
Old Oct 08, 2012, 02:20 PM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Here you go Jimbo
Crack Pitts, Crack Series Motor on 3S 380mah (5 min 14 sec)
Old Oct 08, 2012, 02:29 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
nice flying there bud! Mine will be cracking out of the box in a few weeks once weather improves.
uptime4downtime is offline Find More Posts by uptime4downtime
Old Oct 08, 2012, 05:13 PM
RonJ is offline
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
The gear was my own design. Did the same thing on my Yak. It was for looks only and turned out to be a pain in the posterior. When a friend asked me to order and build him a Pitts I included an extra set of TH carbon gear for myself. The CF gear works great. Still hand launch but landings much better. Will work great indoor this winter.
RonJ
Old Oct 08, 2012, 05:31 PM
RonJ is offline
RonJ's Avatar
Sparta,WI,USA
Joined Nov 2000
Hey Aviefly..
You got 5 minutes plus on a 3S-380 lipo ? I have a stack of 2S-460 & 610's that will make 5 minutes of low and slow. Started out with Nano-Techs, then added a few Gens Ace and now trying out the Rhino 610's. The Rhinos are looking good so far and only a gram or two heavier. Winter coming and plan to run tests on all my lipos to see how many amps are left.
The volts part usually reads OK but the amps are the important part. One of my original Nanos will give me only a 2 minute flight now. Volts good, amps down. I charge everything at 2C. Flights are timed to 5 minutes.
RonJ, Happy TH Pitts driver
Old Oct 09, 2012, 05:45 AM
cheezels is offline
Find More Posts by cheezels
Australia, QLD, Tewantin
Joined Jul 2012
Guys and Gals,
Bit of a noob (and probably weird) question, but I plan on getting the Pitts sometime in the near future.
In the meantime, after realising my limitations with the planes I unwittingly bought as complete newcomer, I've just received a GWS Slowstick.
Sooo, plan is to learn the basics with this and then move to the Pitts.
Now the question (finally)......
I got a little confused with some comments a couple of weeks back regarding rudder and ailerons and turning.
The Slowstick is 3 channel, so, should I have the rudder on the right stick or left stick (Throttle is on the left stick for me).
I'm thinking right stick to get into the habit of 'turning' on the right stick.
Phew, hope that makes sense
cheezels is offline Find More Posts by cheezels
Old Oct 09, 2012, 07:12 AM
Aviefly is offline
Aviefly's Avatar
Joined Feb 2005
Yeh I'd go for rudder on the right stick for that. Reason being its your primary steering channel where as the Pitts its the ailerons. I don't know what radio you have but I think it would help with the transition if later on when you've got the hang of it you programme a mix from the left stick to the right with your slow stick. It will help you get used to using the left stick to steer with too which will help you greatly with the Pitts.
Old Oct 09, 2012, 07:16 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Originally Posted by Aviefly View Post
Looks like you have some amazingly smooth grass to fly off
Mike Smart is offline Find More Posts by Mike Smart
Old Oct 09, 2012, 07:21 AM
JForbes is offline
Find More Posts by JForbes
Parkfly Padawan
JForbes's Avatar
United States, PA, Waynesburg
Joined Aug 2011
Originally Posted by cheezels View Post
Guys and Gals,
A few things, mostly all my opinion, but we'll see what others say as well....
1. Welcome.
2. Don't feel that the Pitts is only for advanced pilots. Yes, it has the abilities of being a crazy acrobat in the sky, and the build is a tad tricky in a couple of spots, but it can fly slow, and with lower rates, it will make you better. I'm proof of that. Plus, it's very tough, and will take to grass crash landings like it belongs there. lol
3. I'm sure some folks with disagree with me here, but in regards to your rudder/3 channel planes... if you have the option of putting the rudder on your left stick, DO IT!! Learn to fly and turn with your rudder under your left hand. Learn everything you can about what the rudder does... right-side up, inverted, knife-edge (plane flying on it's side), etc.... I say this for two reasons... I learned to fly without using rudder, which now I'm trying to overcome and learning to use the rudder. In these slow fly and 3D planes, you use it A LOT. Old habbits are hard to break.... which leads me to my next point. If you "learn" to fly with rudder under your right hand, then switch to a 4 channel common setup, you'll have to teach yourself all over again.
Like I said, this is just my opinion... most people fly with a common radio setup, but there really isn't anything saying you can't have the channels where you want them I guess.... Keep us updated and best of luck!
JForbes is offline Find More Posts by JForbes
Old Oct 09, 2012, 07:39 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Thx.
Crack Pitts 062212 (2 min 16 sec)
cdee
cdee is offline Find More Posts by cdee
Cool Twisted Hobbys - 32" Crack Yak - Build Thread (Lots of new pics!) hercdriver7777 3D Foamies 6697 Jul 17, 2016 11:17 AM
Discussion Official-Twisted Hobbys Extra Slick 32" Slickinsaneness Build/Fly Thread Tom K. 3D Foamies 1377 Apr 06, 2016 06:24 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Wanted Twisted Hobbys - 32" Crack Yak Wanted Moparbob Aircraft - Electric - Airplanes (FS/W) 32 Jul 10, 2012 06:36 PM
Sold Twisted Hobbies Crack Yak isenbed Aircraft - Electric - Airplanes (FS/W) 4 Apr 16, 2012 10:43 PM
