Old May 17, 2012, 09:31 AM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
You can see how mine are curved on the bottom to clear the wing. Doesn't take all that much and my wing is pretty thick.
Tumbler is offline Find More Posts by Tumbler
Old May 17, 2012, 09:41 AM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Originally Posted by Tumbler View Post
I don;t know what he is referring to by reflex either. Nevertheless, I have seen ducts with a an S shape like a bandit and seen some that are just a straight shot to the fan like the El Bandito with no curve. I have seen all shapes and sizes. Seems like with today's power systems you can get away with alot and do not have to be that precise. Just my opinion.
The shape of my ducts is dictated by the battery space that will be provided above the wing between the ducts and the wing itself.
!I've seen jets with no ducts! !Just bulkheads and formers!
geostomp is offline Find More Posts by geostomp
Old May 17, 2012, 09:57 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Taller and/or less length in the vertical stab...that's just me...nice design!!!
Good luck with your project..
Take care.....Chris
Hover or die is offline Find More Posts by Hover or die
Old May 17, 2012, 10:02 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Take care.....Chris
Taller.....fuse?? I always run a big stab for flight performance, but I suppose I could play around with it for looks. Looks are important.
Thanks, George
Old May 17, 2012, 03:40 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
i like it
stoneenforcer is offline Find More Posts by stoneenforcer
Old May 17, 2012, 04:08 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
There's something that bothers me about the canopy. Maybe it should be longer and 20% bigger?
vettster is offline Find More Posts by vettster
Old May 17, 2012, 07:11 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I'm assuming you mean the bubble itself and not the cutout which serves as access. I can see about that too.
Old May 17, 2012, 09:50 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Yes the bubble. Its just my personal preference, but I think the leading edge of the canopy should be closer to the nose and the glass should be larger taking up more of the fuse.
Great work though! Hope it works out for you
Old May 18, 2012, 07:26 AM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
I used the word reflex to mentally demonstrate the flow of air. Geo's duct has no smoothing it just turns into the center whereas Tumblers has a visual gentile smoothing reflex to the center of the duct, your description uses the letter "S". so were on the same page now?
ApexAero is offline Find More Posts by ApexAero
Old May 18, 2012, 09:48 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Yeah I see. The ducts can be altered at a later date. Once I have a flyable frame I may go further in detail with duct alterations. I would like to see exactly where my batteries need to be to balance and go from there.
Additionally, I would like to make ducts for 80mm and 90mm, and possibly a set for a 2kw 70mm just for kicks.
This jet is sized for easy transport and is not going to run 12s 5000 through its 90mm fan. But it could do 12s 2200 through an inrunner for high voltage efficiency.
Old May 23, 2012, 09:12 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
making a plug....
Old Jun 19, 2012, 08:03 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I got one side of the fuse done. Here it is mocked up with the tail and canopy.
Old Oct 14, 2012, 06:27 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Wing plug fabrication.
Geomax CNC Router (1 min 3 sec)
Old Oct 20, 2012, 05:02 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
ReVolt R/C Jet Development (0 min 45 sec)
Old Nov 08, 2012, 07:39 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I desided to go ahead and ReMill my fuselage with my new router which is cutting much more accurately as compared to the last one I had. Pictured is only one fuse half assembled with flight surfaces and a yet to be fitted canopy.
Question ARF FPV plane design - I need your input IBCrazy FPV Aircraft 26 Mar 10, 2012 11:34 AM
Need some input on how to mod this design Slope Nut Electric Plane Talk 3 Apr 18, 2004 06:21 PM
Design input for 3D limited production run airplane KonstantKrash Parkflyers 1 Feb 28, 2003 11:05 AM
Need input regarding twin edf300 design project topforce Electric Ducted Fan Jet Talk 5 Apr 12, 2002 10:28 PM
Design input GWS A powered bipe boomerace Parkflyers 7 Dec 18, 2001 06:28 PM
