Old May 08, 2012, 03:10 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Originally Posted by geostomp View Post
Slope moved back and a rounded shape added. Let me know exactly what you think of the shape.
really really good. That side view is exactly what i was thinking.
gundamnitpete is offline Find More Posts by gundamnitpete
Old May 08, 2012, 04:39 PM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Geo, I didn't say a flat bottom airfoil I said a semi symmetrical. curved on both sides but not equal, not flat. the semi allows for slip stream and lift to a maximum like a smoothed SD6060
and that one behaves well on a short coupled airframe, doesn't loose speed in turns. Notice the high point, this is a laminar foil.
ApexAero is online now Find More Posts by ApexAero
Old May 08, 2012, 06:14 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Isn't the max thickness a little farther back in NLF airfoils? Like the NACA 64 and 65 series.
scatsob is offline Find More Posts by scatsob
Old May 08, 2012, 10:15 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
take your pick but not symmetrical. thing is naca goes back to the fifties, there is newer stuff out thats coumputer aided in design rather than a slide rule. the Slig-Donovan is for models not full scale
Old May 08, 2012, 10:51 PM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Ok I'm definatley leaning toward that airfoil. Flaps should transform any foil into a high lift surface so whatever is slippery would probably be the most fun. I'm not as well versed on all the aspects and history of airfoils so the your insite is appreciated.
geostomp is offline Find More Posts by geostomp
Old May 08, 2012, 11:13 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
What would be the best way to import an airfoil into a CAD program. Is there a dxf or something?
Old May 08, 2012, 11:17 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Sweet! I'm glad to make changes to the jet without the use of Bondo this time around.
Old May 09, 2012, 06:00 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Import tiff, jpg, as a raster image then trace it, scale it to what you need.
Old May 15, 2012, 08:54 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Ok. so I traced the 6060 foil, applied the foil to my wing, and created my wing saddle.
Old May 15, 2012, 12:41 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Shouldn't be a problem getting to the fan, thrust tube, or elevator servos. After calculating the area im going to come in at about 3lbs per sqft. My Rush is 3lbs per sqft and flys great, but it has no flaps so it comes in fast.
Just looking around it seems the bigger birds with 9lb auw have about 400sqft. which is about 3lb per sqft. I have 250 sqft and plan for a 80-90mm at hopefully 5 but maybe 6 lbs. My heaviest rush was 5.5lbs. At 5 lbs I will be at 3lbs per sqft with this new model.
Old May 16, 2012, 03:02 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
About done now with the CAD. I can smooth edges by hand when I get a plug milled out. I have a feeling there will still be alot of work to do by hand.
Old May 16, 2012, 06:46 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
ReVolt R/C Jet Development (1 min 37 sec)
I would like to get this as exacting as possible, so for my plug I will probably undercut the surface, lay glass and filler, then cut the surface right into the hard outer shell. Sand, prime, paint,wax, mold, layup, stiffen, fly!
Old May 16, 2012, 08:42 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Geo you need more reflex in your duct dwg. Smooth it out!
Old May 17, 2012, 09:24 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
So far my main hurdle with the ducts is clearing the wing. Here it is prior to modification. Please explain how reflex applies to the ducting. Thanks
George
Old May 17, 2012, 09:28 AM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I don;t know what he is referring to by reflex either. Nevertheless, I have seen ducts with a an S shape like a bandit and seen some that are just a straight shot to the fan like the El Bandito with no curve. I have seen all shapes and sizes. Seems like with today's power systems you can get away with alot and do not have to be that precise. Just my opinion.
Tumbler is offline Find More Posts by Tumbler
Question ARF FPV plane design - I need your input IBCrazy FPV Aircraft 26 Mar 10, 2012 11:34 AM
Need some input on how to mod this design Slope Nut Electric Plane Talk 3 Apr 18, 2004 06:21 PM
Design input for 3D limited production run airplane KonstantKrash Parkflyers 1 Feb 28, 2003 11:05 AM
Need input regarding twin edf300 design project topforce Electric Ducted Fan Jet Talk 5 Apr 12, 2002 10:28 PM
Design input GWS A powered bipe boomerace Parkflyers 7 Dec 18, 2001 06:28 PM
