Old May 03, 2012, 11:24 AM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
Originally Posted by Kevin Cox View Post
Looks great but I would change the canopy too. Also it is pretty small for a 90mm fan. I found this out with my Plenum sport jet, it landed at mach 1. The bungee launch model wasn't as bad but it was about 12oz lighter without retracts.
The fan being giant in proportion helps out in power effieciency. It is being designed to take all the components from a high power 70-80mm and use them on a mid power 90, though being designed on the computer I can make intakes for all 3 sizes of fan efficiently.
I'll put flaps on this to help with landing and it will be retract ready. I'm shooting for less than 6lb auw. Comments??
geostomp is offline Find More Posts by geostomp
Old May 03, 2012, 11:29 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Originally Posted by Robert Belluomini View Post
If this will be a bungee jet, consider moving the stabs up on the fuse.
Less chance of damage during the landing phase.!!
Yeah my only concern is structural rigitity and producability. But I agree. I may dial the anhedral down just a hair and move the stabs up as well. I'm staying clear of the bungee this time.
Old May 03, 2012, 05:23 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Here it is with the horizontal stabilizers raised and wings filleted.
Old May 03, 2012, 06:04 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I tryed to get a snap shot of the area inspection command but it hid as I exported the bitmap picture of the intake design. Each side is 3.125 inch^2 which will be 6.25in^2 total intake area.
I am getting 6.387in^2 on the exaust, so my intake area matches pretty well.
Old May 04, 2012, 09:42 AM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I just think its too short coupled. I would like to see the fuse elongated and the distanc increased between the stab and the wing. it will make it less pitch sensitve, roll, and knife edge better.
Tumbler is online now Find More Posts by Tumbler
Old May 04, 2012, 10:30 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
How many inches given the jet is 40" now? My delema is my router table is 40" long so any longer will ad a degree of complexity with routing 40" and sliding the work piece down for another run to compete the remaining inches. All this will ad compexity and I'll loose some hair.
I'll consider any solutions. The only solution I can think of is to shorten the nose and add the length between the flying surfaces.
Old May 04, 2012, 01:41 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Here it is with the intakes, wing, and canopy moved forward 2". I also lowered the nose just a hair.
Old May 04, 2012, 02:45 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Version 3 in paint with current modifications.
Old May 04, 2012, 03:37 PM
Tumbler's Avatar
Joined Feb 2003
Yeah I like that better!
Old May 05, 2012, 02:21 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
V3 looks really really good. This thread is a great idea to.
I think the canopy would look cool if it was a bit more sloped, with a more rounded shape where it meets the rear slope. Maybe move the start of the canopies slope back half an inch or so.
gundamnitpete is offline Find More Posts by gundamnitpete
Old May 05, 2012, 07:19 AM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Semi symmetrical airfoil is faster than a symmetrical though symmetrical lands better and I'm seeing a lot of mass in the top view of the fuse, could thin it or coca cola bottle it as in area rule..
ApexAero is online now Find More Posts by ApexAero
Old May 05, 2012, 11:24 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Slope moved back and a rounded shape added. Let me know exactly what you think of the shape.
Old May 05, 2012, 11:37 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I was always under the impression a flat bottom foil would give higher lift for landing which is why I have use them in the past. But I'm going ultra sport on this one so I am leaning toward the full symmetrical foil. If it helps for landing then that is perfect.
Honestly the airfoil hasn't been properly addressed and the wings you see are just for visual reference. I may have to take measurements and make a seperate wing solid body to be joined in an assembly that incorporates a wing saddle.
As fa as width, so far it is all controlled by the size of the componants. One compalaint I have had with my and others models is the ability to get the plane to CG without modifications. I am puting the fan in the empanage and the battery space will be a variable area from above the wing to about a battery length forward of the wing. There are many component combinations and I'd like them all to work.
Old May 05, 2012, 11:44 AM
sbritton is offline
Find More Posts by sbritton
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
You should look at the wing tips on the Comparf Spark. The turn up like mini winglets...should help with lift and efficiency.
http://www.ductedfans.com/graphics/S...ack_praple.jpg
And personally I like longer wings as well to help with slow landings.
sbritton is offline Find More Posts by sbritton
Old May 05, 2012, 01:46 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Not sure what to say on the winglets, the spark incorporated them nicely and they fit the body style.
As for the wings, I have made jets with wings that span equal to the length of the fuselage and it lost the jet look. I good to know your thoughts though as I finalize the design.
Question ARF FPV plane design - I need your input IBCrazy FPV Aircraft 26 Mar 10, 2012 11:34 AM
Need some input on how to mod this design Slope Nut Electric Plane Talk 3 Apr 18, 2004 06:21 PM
Design input for 3D limited production run airplane KonstantKrash Parkflyers 1 Feb 28, 2003 11:05 AM
Need input regarding twin edf300 design project topforce Electric Ducted Fan Jet Talk 5 Apr 12, 2002 10:28 PM
Design input GWS A powered bipe boomerace Parkflyers 7 Dec 18, 2001 06:28 PM
