Old May 02, 2012, 09:30 PM
geostomp is offline
Find More Posts by geostomp
ReVolt- Proprietary Insanity
geostomp's Avatar
United States, MI, Wixom
Joined Sep 2007
ReVolt Jet Design Constructive Input
Hey, give me some input.
geostomp is offline Find More Posts by geostomp
Old May 02, 2012, 09:39 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Maybee a little droop down in the horizontal stabs?
fh64_lucky is offline Find More Posts by fh64_lucky
Old May 02, 2012, 10:03 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Yeah that looks better.
Old May 02, 2012, 10:05 PM
fh64_lucky's Avatar
Joined May 2005
OK,now you can ship it to me....
Old May 02, 2012, 10:16 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I'd like to.
Old May 02, 2012, 10:20 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Any other input welcome. Thank you
Old May 02, 2012, 10:22 PM
fh64_lucky's Avatar
Joined May 2005
I think it looks cool,what size fan are you planning to use?After having quite a few sport jets,the one thing I wish they had was more room for batteries up front,but still achieve the proper CG.Does not need to be high speed setup,just enough batteries to fly 6-7 minutes without worry.I have enough jets that fly fast for 3-4 minutes...
Old May 02, 2012, 10:33 PM
gbmoore is offline
Find More Posts by gbmoore
Colorado Springs, Co
Joined May 2002
1) The inlets look big to me (compared with the tail cone)
2) With the "Toucan beak" shape to the nose, how is the battery room?
Like the anhedral mod to the stabs!
Greg
gbmoore is offline Find More Posts by gbmoore
Old May 02, 2012, 10:38 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
I'm thinking 90mm with a 40" length and 36" span. 22mm wing for retract options, and battery space directly above the wing and forward. That pushes the fan back into the empanage which should help with balance, especially with a 6oz inrunner. I may route one out in foam via CNC and see how it balances.
Old May 02, 2012, 10:48 PM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Greg
The long nose is for looks but will help to keep the nose gear forward. I havent calculated the area on the intakes or added radius yetbut I will and make necessary changes, but the exhaust is about 75mm. The batteries will probably have to be above the wing to make CG, and maybe spill over into the nose for higher power with a heavy motor. I'm a fan of <6lb. 6S setups with unlimited vertical and minimal investment.
Old May 03, 2012, 12:18 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Here I opened it in Fusion and it has a more presentable look.
Old May 03, 2012, 10:51 AM
geostomp is offline
geostomp's Avatar
Joined Sep 2007
Ok so I modded the intakes and changed the nose and canopy. Thoughts? Input??
Old May 03, 2012, 11:00 AM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looks great but I would change the canopy too. Also it is pretty small for a 90mm fan. I found this out with my Plenum sport jet, it landed at mach 1. The bungee launch model wasn't as bad but it was about 12oz lighter without retracts.
Kevin Cox is offline Find More Posts by Kevin Cox
Old May 03, 2012, 11:02 AM
Kevin Cox's Avatar
Joined Jan 1997
The canopy looks better!
Old May 03, 2012, 11:07 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
If this will be a bungee jet, consider moving the stabs up on the fuse.
Less chance of damage during the landing phase.!!
Robert Belluomini is online now Find More Posts by Robert Belluomini
Question ARF FPV plane design - I need your input IBCrazy FPV Aircraft 26 Mar 10, 2012 11:34 AM
Need some input on how to mod this design Slope Nut Electric Plane Talk 3 Apr 18, 2004 06:21 PM
Design input for 3D limited production run airplane KonstantKrash Parkflyers 1 Feb 28, 2003 11:05 AM
Need input regarding twin edf300 design project topforce Electric Ducted Fan Jet Talk 5 Apr 12, 2002 10:28 PM
Design input GWS A powered bipe boomerace Parkflyers 7 Dec 18, 2001 06:28 PM
