Old May 02, 2012, 08:37 PM
DavidMC is offline
Find More Posts by DavidMC
Toronto, Ontario
Joined Jul 2002
Not Getting Full Power? Motor or ESC? Help
Hi Guys,
I am having an issue with my current setup.
I am running the following
Castle HV45 with v4.01 software
Hacker A40-10S V2
Zippy 4s4000 20c
APC 12x8 prop
When I tested this setup on the ground, I was getting 52amps on a fresh pack, 600ish watts. This matches pretty well with Ecalc
Yes, I realize this is slightly over the amp rating, but I have heard many people run over and this is only for a few seconds and I am only at 4s.
The first 3 flights felt fine. During the takeoff of the 4th it felt sluggish. Thinking I might have had an uncharged pack by mistake. I landed and went home for the day. The next day at the field on a fresh pack it felt sluggish. I checked the amp draw and I was pulling 30 amps.
Thinking I popped the ESC, I tried another Castle HV45 and was getting 53 amps again. I reinstalled all the gear and did a final test and I am back down to 25 amps at full power.
Im stumped guys! Is it the motor.
Im going to try the esc in another plane to check the draw.
DavidMC is offline Find More Posts by DavidMC
Old May 02, 2012, 09:36 PM
DavidMC is offline
Toronto, Ontario
Joined Jul 2002
Looking in the castle forum I saw another member complaining about ver 4.01 of the soft ware.
So I downgraded to 3.27 and the problem went away......
Unfortunately, it still cost me a speed controller as I tossed the other one after my second controller worked.
And yes, the second controlled did stop working right after the 4.01 "upgrade"
arrrggg
Old May 02, 2012, 10:29 PM
Glacier Girl is online now
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Bummer, but something you need to know with your set up too.
Do not fall into the thought that when you back off the throttle your amps drop too.
Brushless systems don't work that way. A brushless esc, in layman's terms, is nothing more then three on/off switches. Each "switch" fires power to one each set of windings in the motor.
Those three "switches" determine your motor speed by how long each one is turned on and off.
The motor draws the same amps at idle as it does at WOT. It's just how long it does so that changes it's speed.
Where you can get fooled is reading a meter at anything below WOT. A meter averages readings, we'll say it take 10 readings a second. In those 10 seconds at less then WOT, it might see 5 full amp (on) readings, and 5 zero amp(off) readings. It takes all 10 readings and averages them out. And tells you the motor is only drawing half of what it's actually drawing in amps.
And in your case, you are over drawing the esc's capability, and things go south on you.
Glacier Girl is online now Find More Posts by Glacier Girl
Help! Spektrum A6020 not getting full travel in one direction jgalexander Radios 8 Mar 05, 2012 08:17 PM
Discussion I have a problem getting full power from my ESC DaN_Th3_MaN Power Systems 13 Jan 11, 2012 01:43 PM
Discussion lower kv motor is more power full or not???? Speed Stick 3D Electric Plane Talk 3 Jan 22, 2006 07:39 AM
Phoenix 25 does not always get full power Franz2002_01 Castle Creations 2 May 02, 2004 02:07 PM
Can't get full throttle, esc seems to cut off motor, please help! Newbie1 Power Systems 10 Dec 08, 2002 02:39 PM
