Old May 02, 2012, 07:00 PM
sajeev is offline
Find More Posts by sajeev
United States, VA, Fairfax
Joined Feb 2004
Question
thread locker for TREX
the Align manual says to use T41 green locker. I have a Z42. ok to use that?
thanks for your replies.
sajeev is offline Find More Posts by sajeev
Old May 02, 2012, 07:38 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
As I remembered and checked, I don't see any T41 green locker used in Trex-manual, at least not from those I built. Can you tell where T41 threadlocker apply, is for screws and nut fasteners or for bearing mount.
As I know T41 is SAF-T-LOK product and is medium strength, used for bearing mount, i.e. retaining compund. On the other hand, Z42 is zap product, medium strength and used for screw/nuts fasteners.
If you find T41 is true, then Z42 is not substitute for T41.
wlee1017 is offline Find More Posts by wlee1017
Old May 02, 2012, 09:07 PM
sajeev is offline
Joined Feb 2004
it says on page 1 on the "Needed to complete build" section that T41 is needed
Old May 02, 2012, 09:52 PM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
can u tell what trex model and if you may find from manual where T41 applied. Trex manual pretty good and indicate where you should apply thread locker, CA or adhesive.
my trex kit manual use T43, R48 and CA, no T41
Old May 03, 2012, 02:47 AM
pitchp is offline
Find More Posts by pitchp
Retired
pitchp's Avatar
Australia, VIC, Melbourne
Joined Aug 2010
+1
T43, R48 and CA is all that you need and nothing else
pitchp is offline Find More Posts by pitchp
Old May 03, 2012, 06:36 AM
sajeev is offline
Joined Feb 2004
ok after a good night sleep......it R48 and T22
the T22 is in the kit.
so instead of R48 can i use Z42?
Old May 03, 2012, 08:44 AM
pitchp is offline
Retired
pitchp's Avatar
Joined Aug 2010
Old May 03, 2012, 09:02 AM
sajeev is offline
Joined Feb 2004
was trying to save a trip to LHS and use the Z42 i already have
Old May 03, 2012, 10:09 AM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
I suggest you do not use T22, it is low strength threadlocker and I won't use for any metal to metal fastebers in heli. use your Z42 instead which is medium stregth threadlocker.
I suggest do not use Z42 to substitute R48. R48 is reatining compound and used for bearing mount or other press fit/slip fit application. Retaining compound can be used as threadlocker but not vice versa. All retaining compound are designed to withstand dynamic radial load, like on bearings.
I would go to lhs or hardware store to pick up R48 or same loctite 680 or 609. I used loctite 242, 243, 680 and 609 all the times, depends on the applications.
You may found more info from
http://palmlabsthreadlockers.com/thr...sked-questions
Old May 03, 2012, 12:31 PM
sajeev is offline
Joined Feb 2004
ok so i went to LHS and they dont have R48
where does do i get R48, loctite and T22 from online? direct links will be helpful so i will know i am getting the right one
many thanks!
Old May 03, 2012, 12:33 PM
sajeev is offline
Joined Feb 2004
http://www.helihobby.com/category-s/307.htm
anything from here?
Old May 03, 2012, 12:37 PM
sajeev is offline
Joined Feb 2004
this i already have
http://www.helihobby.com/product-p/paapt42.htm
Old May 03, 2012, 12:57 PM
wlee1017 is offline
wlee1017's Avatar
Joined Jul 2011
You don't need T22, use Z42 instead. As I explained before, both are threadlocker T22 is low strength and Z42 is medium strnegth. If you look at all other Trex kit manul, they use T43 which is medium strength.
R48 commerical name is loctite retaining compound and medium strength, loctite 609. Loctite 243 and 242 are both medium strength threadlocker but 243 is capable of being used in oil contamination, like thread /w grease or lubrication
I ordered loctite 609, 243, 242 ... from grainger.com
http://www.grainger.com/Grainger/LOC...M29?Pid=search
I have attached loctite reference chart too.
Mini-HowTo R/C Heli Tutorial #3 Remove Thread Locker From ANYTHING! frivilousteamrc Beginner Training Area (Heli-Electric) 2 Apr 15, 2012 09:01 AM
Question Thread sealer & locker? mogogear Steam Boats 9 Apr 01, 2012 06:31 PM
Discussion HK450/HK500CMT - HK now using thread locker on components? cswilsn Electric Heli Talk 3 Dec 10, 2011 08:54 AM
Question Thread Locker rowdyates Micro Helis 2 Oct 14, 2004 01:34 AM
