Old May 02, 2012, 04:58 PM
United States, NY, Hamburg
Joined Mar 2012
12 Volt Starter Conversion Help?
I have a Hobbico 12v electric starter, 3 Shark 1500 mAh 6s 7.2 NiCd batteries, and a male connector. I would like to solder a series-circuit connection on the batteries. How do I do this?(I know the voltage is overkill, I want lots of power.) Thanks!
trevorcgross is offline Find More Posts by trevorcgross
Old May 02, 2012, 05:47 PM
United States, CA, Sebastopol
Joined Dec 2010
Get matching connectors and solder up a series harness. But I think you're going to toast the brushes on that starter. You'll be sending a 12 volt starter over 5 times its rated voltage. It won't run long that way. I'd expect a few minutes out of it... a few seconds if you put a load on it, like try to start a big engine with it.
And, what's the C rating of those batteries? Dumping over 60 volts into a starter wound for 12 volt operation is going to run some serious amps into it. Those batteries may get damaged too. More I think of it, the more this looks like a bad idea.
EDIT: Oh, 6S NiCd... well, even 22 volts it too much for longevity.
erkq is offline Find More Posts by erkq
Old May 02, 2012, 05:56 PM
Joined Mar 2012
what if I just did 2 batteries? How would I solder them? By the way, it's for a .61 2 stroke.
Old May 02, 2012, 08:09 PM
Joined May 2010
It would be fine on the 21.6 volts of the three packs, but will do the job on two packs wired in series. Connect the positive of one pack to the starter. Connect the negative of the other pack to the other wire of the starter. Connect the two remaining wires on the packs to each other.
Mark
Mark Anderson is offline Find More Posts by Mark Anderson
Old May 02, 2012, 09:03 PM
Joined Mar 2012
Yes, that's what I thought, how do I solder them? Tinning? What solder? Silver ribbon?
Old May 03, 2012, 12:29 AM
Joined Dec 2010
Just so you know, that starter has no trouble turning over a .61 on 12volts. I used one for years.
Old May 03, 2012, 12:34 AM
Joined Dec 2010
I don't have the best technique, so others can chime in better, I'm sure. But I need more than a pencil iron. I use a Weller soldering gun to get enough heat. You're dealing with solder cups on the ends of the connectors. You put the bare wire in the cup and heat it all enough to fill the cup with solder. Tinning... I don't bother, though I do tin the iron itself to keep it from corroding. Whatever you do, make sure the solder gets hot enough to flow into the wire.
You don't need to silver solder.
Old May 03, 2012, 01:22 AM View Post
lantian
A moderator felt this post violated the following rule: Off Topic Advertisement. It is temporarily hidden while lantian edits it. Show it to me anyway.
Old May 03, 2012, 05:35 AM
Joined Mar 2012
Ok. I will tin 2 batteries with lead solder. Proper technique? Tips? Tricks?
Old May 04, 2012, 07:56 PM
Air Cooled VW mechanic
THX-181's Avatar
USA, CO, Longmont
Joined Jul 2008
How to solder bullet connectors for Brushless Motors/ ESC (8 min 15 sec)
THX-181 is offline Find More Posts by THX-181
Old May 06, 2012, 06:09 PM
Joined Mar 2012
Go to the Home Depot electrical dept and buy a small package of butt crimp splice connectors of a suitable size. They're good for about 30A.
NACA0012 is offline Find More Posts by NACA0012
Old May 06, 2012, 08:31 PM
Joined Mar 2012
Thank-you! that's what I need. I'll put heat shrink tubing over the wires before I solder them.
For Sale *** (PRICE REDUCED)Hangar 9 (12 volt) Super Starter with 2 1500 mah batteries*** stgtech2 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Apr 28, 2012 12:11 PM
For Sale Hobbico Starter 180 12 Volt sgrady41 Aircraft - General - Miscellaneous (FS/W) 0 Apr 16, 2012 09:05 AM
Sold 12 Volt HD Hanger 9 Super Starter unclegeorge Aircraft - General - Miscellaneous (FS/W) 0 Mar 24, 2012 09:17 AM
Sold Sullivan dynatron starter 12/24 volt lla Aircraft - General - Miscellaneous (FS/W) 1 Mar 14, 2012 01:10 PM
Sold Miller Dynatron Reduction Belt Drive 12/24 Volt Starter Barely Used $145.00 SHIIPED! stevster Aircraft - Fuel - Engines and Accessories (FS/W) 3 Sep 07, 2011 06:11 PM
