Old May 02, 2012, 05:41 AM
airviewlive is offline
Find More Posts by airviewlive
Joined May 2012
Alert
Ducted Hexa System
I present to you, the Shielded Hexa System.
Full carbon frame with sexy color , 6 shielded propellors, semi-waterproof, enough room for 4 5A 4s lipo's. maximum prop size is 12".
Props are fully protected, can bump into wall, tree, person, without breaking props or hurting people. At the moment controlled by DJI Wookong-M but different flightcontrollers are possible.
My question for you, what motor/prop combo would be best for edurance? Max prop size 12", 30A esc's. Weight 3,5kg without lipo's.
airviewlive is offline Find More Posts by airviewlive
Last edited by airviewlive; May 02, 2012 at 02:48 PM. Reason: Not ducted, but shielded! Duh!
Old May 02, 2012, 05:42 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Is this Killy's new ducted Hexa?
Sid3ways is offline Find More Posts by Sid3ways
Old May 02, 2012, 05:50 AM
areis81 is offline
Find More Posts by areis81
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
soooo sweeeet! wonderful looking! i wonder what's the added weight to a 'naked' structure'?
plus, actually i don't think it's techically 'ducted', since it's just a great prop protection, but is still great!
areis81 is offline Find More Posts by areis81
Old May 02, 2012, 06:14 AM
Doblao is offline
Find More Posts by Doblao
Spain
Joined Jan 2010
sexy
Originally Posted by airviewlive View Post
I present to you, the Ducted Hexa System.
Full carbon frame with sexy color , 6 ducted propellors, semi-waterproof, enough room for 4 5A 4s lipo's. maximum prop size is 12".
As sexy as killys ones...almost...maybe the colour...:-)
just....sure can bump into people with more than 4 kgs without hurting? Which material is the shield done?
Saludos and really cool,
Jose
Doblao is offline Find More Posts by Doblao
Old May 02, 2012, 06:21 AM
samwei1950 is offline
Find More Posts by samwei1950
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
Totally awesome
Sam
samwei1950 is offline Find More Posts by samwei1950
Old May 02, 2012, 06:55 AM
Joined May 2012
Jose
The total frame is carbon fiber. It looks like a killy frame, and it actually is. We have been working intensively together making this prototype. However, it is made under contract so not for sale (yet).
My estimate is that the frame adds about 1 kg extra to the copter, however it is really really rigid and nearly vibration free.
Now only looking for a better motor/prop combo for lifting this pink puppy.
Old May 02, 2012, 09:48 AM
germaj is offline
Find More Posts by germaj
Joined Feb 2012
Here is a great site to help you answer your own question -- http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
It should give you a general idea of what combo will be the most efficient. What is the total weight with LiPo's?
germaj is offline Find More Posts by germaj
Old May 02, 2012, 10:06 AM
Joined May 2012
I use 500g 4s 5A lipo's. planning on using 2 or 3 at a time, depending on the flight time....
Old May 02, 2012, 10:35 AM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
Nice looking but those motor mounts are hideous. Any plans for a better mount design.
milo12 is offline Find More Posts by milo12
Old May 02, 2012, 10:45 AM
Joined May 2012
there will be carbon fiber plates covering it, thus protecting the esc's from rain... Dont want to disturb the airflow too much, thats why we mounted the motors upside-down.
Old May 02, 2012, 11:08 AM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
As a prop/motor setup you will need something like a 100gr+ Motor with arround 800 KV and e.g. 12x4,5 CF props (for a little bit of efficiency)
Now you have 3,5 kg + Battery it will be around 5kg, so about 800gr per motor, so 1600gr max thrust per motor, not easy and efficient possible with 12" max.
My suggestion would be:
https://www.mikrocontroller.com/inde...5374fe40ec1d4a
with props:
this is just illustrate what I suggest, but of course other motor/prop combinations but with similar tech. data are possible.
best regards
Ferdinand
P.s: Did it lift off with the 11"?
EndOfDays is offline Find More Posts by EndOfDays
Old May 02, 2012, 12:21 PM
Joined May 2012
Thanks for the reply. Yep it flies fine with the 11" props. Nice sound too!
The biggest problem is the weight, as i cant slim down on the pounds. so i need the best combo prop and motor. For efficiency, is it better to use light motors(at 70% throttle) or strong ones (at 40%)?
Old May 02, 2012, 12:25 PM
EndOfDays's Avatar
Joined Jan 2010
For efficiency it is better to use 12" props. Of course in would be nice to take light-weight-motors, since this would also reduce weight, but if you want a solid performance (and be able to climb fast for several minutes on a hot day in summer) you have to use motors of 100-150gr (to get rid of the heat).
best regards
Ferdinand
Old May 02, 2012, 12:38 PM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Motor mount color should be black
color of the vehicul look wierd
nice desing but work the color
Will be better if you do like army camo paint
I think it will sell better
saskya is offline Find More Posts by saskya
Old May 02, 2012, 12:41 PM
Joined May 2012
The pink color is for the customer. the 'normal color' is carbon-pattern, just like Killy's frames. They look awesome!
Discussion Hexa vs. Y6 - pros and cons of each system Chris Burton Multirotor Talk 6 Jul 11, 2014 10:01 AM
Wanted Hexa / Hexa XL / Hexacopter or octocopter fiego007 Aircraft - Electric - Multirotor (FS/W) 3 Jul 08, 2012 03:51 AM
For Sale trade my flyduspider hexa for fpv goggles or long range system imdone FPV Equipment (FS/W) 0 Mar 16, 2012 11:34 PM
Sold ELE ADF40-200 Ducted Fan Power System (8600 kV) w/ Turnigy 12A Plush ESC snolord1 Aircraft - Electric - Power Systems (FS/W) 3 Sep 24, 2011 10:47 AM
Discussion Installed Thrust Testing - SR-71 Duct System William E Brown Electric Ducted Fan Jet Talk 1 Apr 23, 2011 06:47 PM
