Old May 19, 2012, 12:47 AM
albx is offline
Find More Posts by albx
albx's Avatar
Italy
Joined Jun 2007
Originally Posted by quix-fz View Post
mine seem to have arrived at the post office, will post pictures once i get them and do a quick test
great, I'm interested in the 700tvl
albx is offline Find More Posts by albx
Old May 19, 2012, 04:17 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Thanks!
msev is offline Find More Posts by msev
Old May 21, 2012, 10:14 AM
quix-fz is offline
Find More Posts by quix-fz
Basel, Switzerland
Joined Mar 2008
the cameras arrived today on friday it was a lens that arrived after 2 months from dealextreme
here are the first photos. came nicely packaged in those little parts-boxes! i think i have a new place for storing my lenses the screws for the lens mount were free inside that box, they might scratch the lens or the image sensor if you had bad luck, but most probably wont.
the cmos cam doesnt have a IR filter, and the lenses dont have one either... will have to find one which has. but i'll do the testing with the stock lens (the 3.6mm one, not 6mm).
from left to right: 420tvl cmos, 420tvl ccd, 700tvl ccd
more coming
quix-fz is offline Find More Posts by quix-fz
Old May 21, 2012, 10:29 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
more coming
great, now test them
Old May 21, 2012, 10:51 AM
quix-fz is offline
Basel, Switzerland
Joined Mar 2008
the 420tvl cameras work and i recorded a short sequence with each. but the 700tvl came with the cables loose, the plug housing is separately in the box... have to find the pinout, nothing on the sureelec. site...
the cmos works down to 6.5V. the 420 ccd down to 7.0V. they both work slightly below that, but noise and gliches appear.
i'm sure the cmos can be easily modded to 5v operation. theres a 7805 right after 12v-in...
Old May 21, 2012, 11:52 AM
quix-fz is offline
Basel, Switzerland
Joined Mar 2008
fpv camera comparison (2 min 53 sec)
0:00 - 0:30 sureelectronics.net 420TVL cmos pal, stock lens (3.6mm), looks like it doesnt have a IR filter
0:30 - 1:00 sureelectronics.net 420TVL ccd pal, stock lens, should be 3.6mm but looks wider, more like 2.8mm
1:00 - 1:47 sureelectronics.net 700TVL ccd pal, stock lens (3.6mm), check low voltage reaction around 1:40
1:48 - 2:14 sc2000.com PZ0481 690TVL pixim seawolf, stock lens (2.8mm), this camera was inside my bixler, and running over 5.8ghz, that's why there's the osd. not default settings, i changed some things
2.14 - end nghobbies.com 20mm 600tvl 5V pal, stock lens (3.6mm). the camera output compresses the sync pulses when there are bright parts in the image, so the osd can't sync correctly (the osd does some internal timing/sync restoration, so it can show the osd most of the time, osd looked much worse without the internal timing), not even the dvr can keep up. otherwise good camera, exposes for shadows (which is good), great low light capability! here's a flight video of that cam: youtube
the sun came through when testing the 700tvl cam, so it's quite contrasty, the pixim handles it much better. will have to do some flight testing to able to say something useful, but so far, the sureelectronics cams work and look good.
here's the video file straight from fpv-japan dvr, appended the files in virtualdub and saved with direct stream copy, so this should be the raw data. http://upload.festzeit.ch/upload/zeu...02_allcams.avi
Old May 21, 2012, 01:28 PM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
http://youtu.be/PtZyJh9y19Y
quix-fz thank you very much for this quick comparision, i think the cameras are good for what you paid, thinking to buy the 700tvl
Old May 24, 2012, 08:58 AM
Macattaka is offline
Find More Posts by Macattaka
Beyond the BlackStump
Macattaka's Avatar
Australia, SA, Adelaide
Joined Mar 2006
700 tvl arrived today and just tested (in my poorly lit shed), I'm impressed so far. Look forward to testing it in daylight outdoors tomorrow.
quix-fz, have you got the OSD working yet? I used the pin out from the picture on their site but was a bit reluctant to throw another 12v into the longer OSD leads but since I got nothing on the screen I'm guessing this needs to be done?
700TVL 1/3" SONY Super HAD CCD II test (1 min 25 sec)
Cheers,
Al
Macattaka is offline Find More Posts by Macattaka
Old May 24, 2012, 11:03 AM
msev is offline
Joined Sep 2010
Pretty cool, waiting for the flight vids,..and what can be tweaked and improved in the cams osd.
Old May 24, 2012, 11:10 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
anyone tried how is in the night?
Old May 24, 2012, 11:12 AM
albx is offline
albx's Avatar
Italy
Joined Jun 2007
just a question about your osd, you don't have used the lm1881, did you?
Old May 25, 2012, 09:40 PM
quix-fz is offline
Basel, Switzerland
Joined Mar 2008
i'm using a lm1881
Old May 28, 2012, 02:39 PM
cmr123 is offline
Find More Posts by cmr123
Joined Mar 2012
Does these cameras have the same osd as securitycamera2000īs?
cmr123 is offline Find More Posts by cmr123
Old May 28, 2012, 09:36 PM
soulreaper is offline
Find More Posts by soulreaper
Joined Nov 2005
Quix-fz what are you using to record the video from the cameras that you tested (What DVR are you using)
soulreaper is offline Find More Posts by soulreaper
Old May 29, 2012, 02:09 AM
dziedrius is offline
Find More Posts by dziedrius
Joined Jul 2008
I think he mentioned, that he uses http://fpv-japan.com/item/fj-dvr-sd4/lang/en/
dziedrius is offline Find More Posts by dziedrius
Discussion FPV? EBay>600TVL SONY SUPER HAD CCD Camera lrplin FPV Talk 49 Jan 27, 2015 08:54 AM
Help! 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens not working bighead93 FPV Equipment 18 Jan 10, 2015 11:01 PM
Discussion Super HAD 600tvl camera - does it operate w/o control board? BCSaltchucker FPV Talk 3 Mar 09, 2012 02:41 PM
Discussion Help with OSD settings(Sony Super HAD II 600TVL) chatch15117 FPV Talk 4 Nov 18, 2011 09:53 PM
Sold 1/3" Sony Super HAD, Color, PAL format board camera, NIB kdill2160 FPV Equipment (FS/W) 2 Sep 18, 2011 08:15 AM
