Old May 20, 2012, 01:37 AM
SuperFPVflyer is offline
Find More Posts by SuperFPVflyer
One with the machine
SuperFPVflyer's Avatar
United States, GA, Atlanta
Joined Oct 2010
Svede you're a newbie quad flyer, sit down.
Tim, your quad is totally freaking awesome!!!
SuperFPVflyer is offline Find More Posts by SuperFPVflyer
Old May 21, 2012, 12:11 AM
timnilson is offline
Find More Posts by timnilson
timnilson's Avatar
United States, FL, Sarasota
Joined Nov 2010
Thank you very much!
timnilson is offline Find More Posts by timnilson
Site Sponsor
Old May 22, 2012, 09:13 PM
aWanderer is offline
Find More Posts by aWanderer
Joined Jan 2012
That is a NICE quad design. I would definitely buy one of those.
I have a DJI F450 quad and it really rocks. I put a 4500 mAh pack on it and crashed from approx. 30' up. It did break where the motors are mounted, but zero damage where the arms attach to the centre plates. I had full FPV gear on it and a GoPro (in the case). That baby was heavy. The DJI quad is super strong!
What I don't like.. I can barely fit all the gear on it. Your design is MUCH nicer for sure. I think the F450 and your quad are in two different categories. One is sport flying and the other is FPV. I too want a price and availability.
If I were to buy one, I would be putting the stock DJI motors/ESC and a Naza on it. Probably spin 10" props.
aWanderer is offline Find More Posts by aWanderer
Old May 23, 2012, 12:01 AM
timnilson's Avatar
Joined Nov 2010
Thanks! Yes, the DJI 450 frame is very sturdy. Keep in mind that the QAV500 is 50mm larger diagonally, quite a bit heavier, and is built to carry a lot of payload (3 cameras, a 5000mah Lipo, etc.) and fly with big 40mm stator motors. I'll be selling replacement parts for the individual pieces of the frame so that you can easily rebuild it if needed.
Price and availability will soon be announced.
Site Sponsor
Old May 23, 2012, 08:14 AM
squigg is offline
Find More Posts by squigg
What goes around comes around.
squigg's Avatar
Joined May 2011
Looking forward to this, nice looking machine.
squigg is offline Find More Posts by squigg
Old May 23, 2012, 10:05 AM
caju is offline
Find More Posts by caju
caju's Avatar
Joined Jul 2011
SOON when my fingers are eatching
beautifull machine, canīt wait to have one
CAju
caju is offline Find More Posts by caju
Old Jun 06, 2012, 11:27 PM
timnilson's Avatar
Joined Nov 2010
The QAV500 frame, landing gear options, and spare arms are now available for pre-order here:
http://www.getfpv.com/qav500-fpv-quad.html
Site Sponsor
Old Jun 07, 2012, 01:13 AM
ROCKY2 is offline
Find More Posts by ROCKY2
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
i cant wait for mine! make them faster
ROCKY2 is offline Find More Posts by ROCKY2
Old Jun 14, 2012, 10:46 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
Just tried to go to your site to look at a preorder but the site was down. Something about magneto?
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Jun 15, 2012, 08:34 AM
timnilson's Avatar
Joined Nov 2010
Paul
The site was down yesterday for a bit when Amazon had an outage. It's back up.
Site Sponsor
Old Jun 16, 2012, 02:19 AM
brifa is offline
Find More Posts by brifa
brifa's Avatar
ITALY
Joined Aug 2006
could you post a picture where we can see a 4s lipo 5000mah on that frame??
thank you
brifa is offline Find More Posts by brifa
Old Jun 19, 2012, 11:59 PM
DerekB is offline
Find More Posts by DerekB
DerekB's Avatar
Cape Coral, FL
Joined Nov 2001
I am just starting to learn about multi-copters and aerial photography, so forgive me if my question is in the wrong ballpark here. I have a GoPro HD Hero 2 and also a Panasonic Lumix GH2. I would really like to use the GH2, but obviously quite heavy. I see others using the very expensive Cinestar 6 with the GH2 on a gimbal hanging underneath. Can the QAV500 handle the GH2? My GH2 with 14-42 lens weighs 641 grams. The GoPro without the case is 100 grams. I see you have 2 on board, so that's 200 grams. Can you handle 441 grams more .?
- Edit: Ok, I just read the GH2 with 14mm pancake lens is only 500 grams. Getting closer!!
- Derek
DerekB is offline Find More Posts by DerekB
Old Jun 20, 2012, 09:44 AM
ROCKY2 is offline
TREES!!! Ouch!!!
ROCKY2's Avatar
Mexico, BC
Joined Jun 2009
- Derek
im going to try a t2i on mine and that is 510 grams i think it will handle it
Old Jun 20, 2012, 10:07 PM
timnilson's Avatar
Joined Nov 2010
- Derek
Derek -- The GoPro is a great little camera that is just small enough to place on the nose of the QAV500. The issue with your high end GH2 is primarily with the full 500g on the nose of the frame -- you would need the same amount of weight on the back of the frame to balance the frame ("getting the CG right"). So that's one reason you can't place the camera on the nose (the camera is also too big for the nose and the props will bing with the camera). If you were to try to place the camera someplace else on the frame you'd have to come up with your own mechanism to do that. Only places possible would be above the Flight Controller or underneath the frame. While it might be possible for the QAV500 to lift the weight of the camera, flying a high end camera like the GH2 is not what the QAV500 was designed for. For a high end camera you'd always want to use a gimbal. A good gimbal alone will cost you more than the entire QAV500 frame. The QAV500 is a FPV quad that can also be used to take commercial use video with two GoPros (one forward and one downward). Applications like search/rescue, checking large areas of farm land for irrigation patterns, check forests for fallen trees, and even some real-estate work like aerial video and photos. For all these uses a GoPro is fine and you can also get away without a gimbal if your FC is finely tuned. For the price, I think the QAV500 provides very high quality video results, but not at the level of a Cinestar 6 with a good gimbal and high end camera hanging underneath.
Site Sponsor
Old Jun 21, 2012, 12:28 PM
squigg is offline
squigg's Avatar
Joined May 2011
Any shipping news?
New Product GOPRO FPV Spider Quadcopter V4.0 + Anti Virbation Mount (NEW Pics Updated 15Apr2012) DiVidesign Multirotor Talk 98 Nov 05, 2013 05:12 AM
New Product New from fpvmanuals: Lipo Strap made by Scorpion timnilson Multirotor Talk 9 Apr 26, 2012 11:41 PM
Wanted FPVmanuals tricopter lower main frame flohio117 Aircraft - Electric - Multirotor (FS/W) 2 Apr 02, 2012 10:35 PM
Discussion New GoPro lens protection product by fpvmanuals timnilson Aerial Photography 0 Dec 15, 2011 10:34 PM
Sold HobbyKing Quadcopter Frame V1 - NEW - $22.50 shipped Merkin77 Aircraft - Electric - Multirotor (FS/W) 3 Sep 30, 2011 12:55 AM
