Old May 02, 2012, 12:29 AM
imdone is offline
Find More Posts by imdone
imdone's Avatar
United States, WA, Seattle
Joined May 2011
Originally Posted by timnilson View Post
It comes in at about 450g -- so a bit heavier than the HT FPV quad, but again, you fly it with bigger motors and bigger props. Can you fly the HT FPV quad with 10" props without seeing them in the GoPro picture?
holy smokes that things a tank! a sexy tank
imdone is offline Find More Posts by imdone
Old May 02, 2012, 12:34 AM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
I have to say this is a pretty frame! I really like the design and thinking behind it. However, as an aggressive FPV pilot myself with a slight tendency to crash I don't think those pretty arms would last long, initial cost may not be much of an issue but replacement cost is going to be! I would like to see this design with booms made out of readily available materials and then we're talkin!
Still, if it's not astronomically expensive I think I'm quite interested. Thanks for the tip BenHayat!
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old May 02, 2012, 12:35 AM
timnilson is offline
Find More Posts by timnilson
timnilson's Avatar
United States, FL, Sarasota
Joined Nov 2010
Originally Posted by BenHayat View Post
Tim, have you tried it with HF Sport & Pro?
No, Naza is all I tried so far. I think I will try a simple KK Blackboard v5.5 for $20 -- I've been getting great results with these boards on my tricopters.
timnilson is offline Find More Posts by timnilson
Site Sponsor
Old May 02, 2012, 12:39 AM
timnilson's Avatar
Joined Nov 2010
Paul
I wanted to design the two structures so that the motor/arms section was as flat as possible and then add a electronics fuselage that has a large 35mm clearance to mount any FC including the HK KK board that has the cables sticking up high. And then there is another 12mm of space between the two structures. Overall, the frame is still pretty low profile. I will sell replacement arms as well.
Site Sponsor
Old May 02, 2012, 12:42 AM
timnilson's Avatar
Joined Nov 2010
Yes, it is a bit heavier, but supports large motors/props and big/heavy 4s Lipos (5000mah fit easily).
The HT FPV frame comes in at 390g -- so we're 60g above that, not too much considering the fact that this is really two separate structures, not just one.
Site Sponsor
Old May 02, 2012, 12:55 AM
BenHayat is online now
Find More Posts by BenHayat
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
Take a look at the connecting bolts of this:
V.S. This:
BenHayat is online now Find More Posts by BenHayat
Old May 02, 2012, 01:32 AM
imdone is offline
imdone's Avatar
Joined May 2011
where can I buy some of those dampers? do you sell them?
Old May 02, 2012, 01:38 AM
tru168 is offline
Find More Posts by tru168
Joined Apr 2004
Hi,
Yes, a little bit heavy but with 4006, or 4008 motors, should be a solid performer.
My t-copter no prop in the frame, and also a quad with pod in front, just like multiwiicopter products . But crashed last week and rebuild one now.
My new 600 size quad I use double decker too, just that the stable deck at below of the frame, coupled with industrial anti vibration rubber screw set. with landing gear attached,battery, and a 2 axis gimbal under the landing gear. The heavier the stable deck, the more stable it get. Quite bulky ......
I like your folder design, ( My mistake here, Non folding ? ) looks professional, compact and easy to transport.
Regards,
Ew
tru168 is offline Find More Posts by tru168
Old May 02, 2012, 06:44 AM
Capello1986 is offline
Find More Posts by Capello1986
Joined May 2011
You can buy those bobbins off ebay, I use them on my tricopter for the under plate gopro mount. There normally used in rc boats engines.
Capello1986 is offline Find More Posts by Capello1986
Old May 02, 2012, 07:02 AM
timnilson's Avatar
Joined Nov 2010
Yes, I will start to sell the mounts soon for my kits and anyone that wants to use them on their own kit(s). They use M3 threaded studs and a very specific durometer and material to work well for RC. They were so hard to find in this configuration that I designed my own and am producing them now.
Site Sponsor
Old May 02, 2012, 07:17 AM
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
Tim, one question I had on the first post and I think you missed it, is regarding Landing Gear. Since right now without one, the copter can get exposed to anything it lands on like shallow water, mud or dirt and etc. What kind of LG are you planning?
Thanks!
Old May 02, 2012, 07:38 AM
timnilson's Avatar
Joined Nov 2010
Thanks!
Yes, the LG is not yet done. I am thinking about straight Fiber Glass tubes sticking down from the aluminum arms held on by a clamp. Still fine tuning this.
Site Sponsor
Old May 02, 2012, 08:16 PM
fpvguy is offline
Find More Posts by fpvguy
Joined Mar 2010
does it fold up?
fpvguy is offline Find More Posts by fpvguy
Old May 02, 2012, 09:06 PM
timnilson's Avatar
Joined Nov 2010
Originally Posted by fpvguy View Post
does it fold up?
No, it does not fold up.
Site Sponsor
Old May 04, 2012, 08:26 PM
timnilson's Avatar
Joined Nov 2010
QAV500 flight with 3 cameras at once in 1080p
Here is a new video that was shot with 3 cameras on the QAV500. 1 GoPro in 1080p, 1 GoPro in 720p (down), and one fpv flight cam.
QAV500 flight with 3 cameras (1 min 51 sec)
Site Sponsor
New Product GOPRO FPV Spider Quadcopter V4.0 + Anti Virbation Mount (NEW Pics Updated 15Apr2012) DiVidesign Multirotor Talk 98 Nov 05, 2013 05:12 AM
New Product New from fpvmanuals: Lipo Strap made by Scorpion timnilson Multirotor Talk 9 Apr 26, 2012 11:41 PM
Wanted FPVmanuals tricopter lower main frame flohio117 Aircraft - Electric - Multirotor (FS/W) 2 Apr 02, 2012 10:35 PM
Discussion New GoPro lens protection product by fpvmanuals timnilson Aerial Photography 0 Dec 15, 2011 10:34 PM
Sold HobbyKing Quadcopter Frame V1 - NEW - $22.50 shipped Merkin77 Aircraft - Electric - Multirotor (FS/W) 3 Sep 30, 2011 12:55 AM
