Old Oct 01, 2012, 06:25 AM
Joined Jan 2007
Originally Posted by timnilson View Post
It flies fine with either a Plush 18amp ESC on 4s or a Tiger 18amp ESC. You can use the NX-4008 or the FM-4008 -- they are a lot cheaper, but not at the same build quality as the Tiger motor.
Thanks for clearing that up. I will be going with the Turnigy Plush 18 because I intend to re-flash them. Do you know if those use Atmega or Silab chips?
The tiger is too expensive for me now and I settled on the NX or FM 4008. My last question is, whats the difference between the 2? I see the FM has a 4 mm vs 3 mm shaft and different mounting holes and is also heavier. Which one should I choose and why?
And that should do it. Thank you for your patience!
skripo is offline Find More Posts by skripo
Old Oct 01, 2012, 11:28 AM
United States, WA, Spokane
Joined Oct 2012
Tim: Quick question.
I am writing an article on Aerial Videography for Beginners. Just published part 1.
Second part deals with camera options.
Will the next Sony RX100 work with the QAV? It's only .5 inches wider than GoPro with mount. I'm worried about prop interfere, not weight, as it's only 80 grams heavier.
Dimensions:
4.00 x 2.29 x 1.41
Weight :
260 grams.
It has better video (1080/60p), less compression, and the less an optical stabilization.
Sent an extensive message using the online form at FPVmanuals on this issue, but no response.
Thank you.
david
daskim is online now Find More Posts by daskim
Old Oct 02, 2012, 08:02 AM
timnilson's Avatar
Joined Nov 2010
The Plush 18amp ESC are Silab. I know there are efforts to flash Silab ESCs, but it's not nearly as far along as flashing ESCs with Atmega. If you're planning on flashing your ESCs, the Plush 18amp is probably not the best ESC you can pick for that reason.
On motors, the FM-4008 and NX-4008 are very close. Same KV, same power, just slightly different in the way the shaft and prop mount is put together. For the QAV500, the FM-4008 is the more popular motors, but I have seen builds that use the NX-4008 successfully. The QAV500 has mounting holes for both motors -- even though both motors have unique mounting holes.
timnilson is offline Find More Posts by timnilson
Old Oct 02, 2012, 08:03 AM
timnilson's Avatar
Joined Nov 2010
Dimensions:
4.00 x 2.29 x 1.41
Weight :
260 grams.
Thank you.
david
David -- just to make sure everyone knows, I did respond to your message on the RX100. While the cam can theoretically fit, the QAV500 was not tested or designed with this camera in mind.
Old Oct 08, 2012, 06:09 PM
timnilson's Avatar
Joined Nov 2010
Dave Slack sent me this promo video he put together. I think he did a great job.
QAV500 Video Ad (4 min 55 sec)
Old Oct 08, 2012, 06:52 PM
United States, CT
Joined Oct 2012
http://www.youtube.com/watch?v=3Kw_ou3fO7o
Really cool, except Dave Slack is amazing at recording quality shake free footage as it is. He could make a Radio Shack $40 helicopter with a Chinese Micro FPV rig look like an IMAX Movie presentation.
Jokes aside.. looking good
TimeTrave1er is offline Find More Posts by TimeTrave1er
Old Oct 08, 2012, 11:31 PM
Youtube Johnbrum26
Mckinney,TX
Joined Oct 2010
Not as good as some others, but here's one from today
QAV Good Times (9 min 52 sec)
Killab is offline Find More Posts by Killab
Old Oct 10, 2012, 03:20 PM
United States, IL, Chicago
Joined Jul 2012
What are your thoughts on the kk2 board vs. Naza board to control this quad. Pros and cons of each would be great!
S2000442 is offline Find More Posts by S2000442
Old Oct 10, 2012, 04:55 PM
timnilson's Avatar
Joined Nov 2010
I have personally not flown the KK2 board on the QAV500, only the Naza, CC, and APM2. I did fly the KK2 board on a tricopter though and I like it. It's a good board especially given the price point.
Old Oct 10, 2012, 08:20 PM
MD2
Joined Sep 2012
Hey guys really close to pulling the trigger on my QAV500, need some help making sure I have everything I need!
Please check out my thread here and comment. Super exited for the build!
http://www.rcgroups.com/forums/showt...0#post22967545
MD2 is online now Find More Posts by MD2
Old Oct 12, 2012, 06:24 PM
timnilson's Avatar
Joined Nov 2010
I hope you were able to get the answers you need. Let me know if you have any other questions.
Old Oct 22, 2012, 01:10 PM
dslack67's Avatar
Joined Dec 2011
Daskim - Here is the answer to your question. YES, the RX100 works beautifully. Here is the first 2 test flights, see for yourself. No prop issues at all, fits fine. I also used my GoPro2 in the down rear mount location and the motors didn't even get warm, handled the weight no problem.
Beautiful footage for the first 2 test flights. Watch it in 1080p mode for sure.
QAV500 Sony RX100 & GoPro2 FPV Test (4 min 22 sec)
Dimensions:
4.00 x 2.29 x 1.41
Weight :
260 grams.
Thank you.
david
dslack67 is offline Find More Posts by dslack67
Old Oct 22, 2012, 01:13 PM
dslack67's Avatar
Joined Dec 2011
HAHAHAHA. Well, I don't know about IMAX Movie quality, but hey I gotta love your faith in me. LOL.
Check out the first flight tests with the QAV500 and a Sony RX100. Very promising in deed.
Old Oct 24, 2012, 07:07 AM
shauntot's Avatar
Joined Aug 2005
sub'd
shauntot is offline Find More Posts by shauntot
Old Oct 24, 2012, 09:39 PM
United States, CA, San Diego
Joined Apr 2012
When is the QAV500 expected back in stock? It's looking to me like a good platform for the GoPro Hero 3
Is this frame "backpackable"? By that I mean, will it fit or attach to a normal sized backpack? I can't seem to find the dimensions any longer
jcmonty is offline Find More Posts by jcmonty
New Product GOPRO FPV Spider Quadcopter V4.0 + Anti Virbation Mount (NEW Pics Updated 15Apr2012) DiVidesign Multirotor Talk 96 Feb 11, 2013 11:36 PM
New Product New from fpvmanuals: Lipo Strap made by Scorpion timnilson Multirotor Talk 9 Apr 26, 2012 11:41 PM
Wanted FPVmanuals tricopter lower main frame flohio117 Aircraft - Electric - Multirotor (FS/W) 2 Apr 02, 2012 10:35 PM
Discussion New GoPro lens protection product by fpvmanuals timnilson Aerial Photography 0 Dec 15, 2011 10:34 PM
Sold HobbyKing Quadcopter Frame V1 - NEW - $22.50 shipped Merkin77 Aircraft - Electric - Multirotor (FS/W) 3 Sep 30, 2011 12:55 AM
