This thread is privately moderated by LittleG, who may elect to delete unwanted replies.
Old May 01, 2012, 02:04 PM
LittleG is offline
Find More Posts by LittleG
LittleG's Avatar
Raleigh, NC
Joined Jan 2007
FPV Project(s)
FPV reference:
Building a cloverleaf antenna
FPV Backpack Ground station 1
FPV Backpack Ground station 2
http://videoaerialsystems.com/fpv-a-guide-to-success/
Antennas 101 - Polarization, Diversity & Gain Patterns (27 min 56 sec)
How to install wire mesh tutorial video
Putting wire mash guard on a servo lead (5 min 34 sec)
My equipement from Range Video:
KX151 camera
900MHz , 500 mW transmitter (adjustable microphone gain, automatic Li-poly battery cut off to prevent battery damage)
Standard receiver
0.9GHz 8dBi Patch receiver antenna
Components from ReadyMadeRC:
RMRC-PICO-WIDE 12V (6-24V) Ultra Compact Wide Angle NTSC
Skylark Trace OSD III
Camera Cable (3-Wire Super Compact)
Skylark USB Update Cable for Tiny and Trace OSD (SL-II-USB)
16mm OD Ferrite Torroid for RF Noise Suppression (16MMTORROID)
SkyLark Trace III OSD diagram
Configuring the SkyLark Trace III OSD:
-After downloading the Configure Tools V3 software from http://www.skylarkfpv.com/en/down.php,
-Software and required drivers will be installed automatically.
-Once the software is installed, plug in the Skylark Trace III OSD via the required USB cable. (The computer should automatically detect the OSD board.)
-Set the Port Setting on the PC to COM2
-Launch the software, and change the OSD settings according to your needs.
-After you have selected the desired setting, click on the SET button. This configures the OSD.
SkyLark Thread Link
LittleG is offline Find More Posts by LittleG
Wanted Ideas for my fpv project irun4fundotca FPV Equipment (FS/W) 0 Mar 12, 2012 08:32 AM
Build Log IBCrazy's Vampire FPV project IBCrazy FPV Talk 28 Mar 05, 2010 05:06 PM
Yippee! My new FPV project, FPV shockflyer AndrésMtnez FPV Talk 9 Feb 26, 2008 02:39 PM
