Old May 01, 2012, 12:41 PM
Blue Falcon is offline
Find More Posts by Blue Falcon
Chicago
Joined Jul 2008
Question
Clear Coat Options
Guys,
Looking on the net and at these threads, I still can't seem to decide on clear coat finish. Just finished sanding and sanding, and sanding, and finally airbrushing a small scale build. Electric plane. I used Model Master Enamel, which came out looking good. The plane is a belly lander, and clearly the paint won't stand up to the wear and tear of RC flying.
I've used Klass Kote before, with great results, but am reluctant to put laquer over enamel. It seems that a lot use Krylon satin over the Testors clear coats. Is this any better? Will the finish look as good as airbrushed? Some have used Nelson paint successfully, will it be compatible?
I could use some advice.
Thanks.
Blue Falcon is offline Find More Posts by Blue Falcon
Old May 02, 2012, 07:23 AM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I believe that Klass Kote is epoxy. http://www.klasskote.com/
TomCrump is online now Find More Posts by TomCrump
Old May 02, 2012, 10:56 AM
Chicago
Joined Jul 2008
Thanks for reply Tom. It's epoxy, but laquer thinned, and has risk of bubbling paint underneath. The more I read, it sounds like Minwax Polycrylic may be the way to go.
Old May 02, 2012, 08:40 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I used an automotive urethane two part paint on my last plane. It was a "house brand" paint. It worked just fine and i was able to purchase a quart of the clear and a pint of the activator. It is mixed 4 to 1 so the activator will be good for two quarts of clear. I had some reducer left over from a previous project. It sprays nice and holds on tight. Dry to the touch in about an hour and can handle it in about four hours.
Check with your local automotive supply house to see what they have. Mine is an Auto Value brand paint.
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old May 10, 2012, 04:59 PM
sscherin is offline
Find More Posts by sscherin
sscherin's Avatar
USA, WA, Kennewick
Joined Nov 2005
I would try a test panel of Nelsons clear and see how it goes.
http://www.nelsonhobby.com/hobby_paint.php
sscherin is offline Find More Posts by sscherin
Discussion Clear coat. 420TEE Scale Boats 2 Mar 11, 2012 02:40 PM
Discussion Clear Coating Before or After Color Sanding? FoamCrusher Painting and Finishing Tips 8 Feb 01, 2012 11:31 AM
Discussion Clear coat houseboat 3D Foamies 4 Jan 23, 2012 03:18 PM
Discussion Clear fill for a scrape in clear coat? wingbeat Painting and Finishing Tips 4 Oct 28, 2007 11:01 AM
Clear Gloss coat? Paul Willenborg Scale Kit/Scratch Built 8 Feb 24, 2003 08:33 PM
