Old Oct 10, 2012, 09:45 AM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
Description:
Getting close to completing my build. Anyone out there have any return home settings that work for the ET with guardian?
Tony97 is offline Find More Posts by Tony97
Old Oct 10, 2012, 07:31 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Description:
Done!
Old Oct 10, 2012, 07:44 PM
usa.alex is offline
Find More Posts by usa.alex
Alex USA
usa.alex's Avatar
Joined Oct 2011
Originally Posted by Tony97 View Post
Tony,
could you post some canopy photos please ?
I'm wondering what have you done
usa.alex is offline Find More Posts by usa.alex
Old Oct 10, 2012, 10:32 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Description:
How's this?
What angle do you want? Let me know and I'll take more.
I have not put the go pro inside the canopy yet.
Old Oct 11, 2012, 09:35 AM
usa.alex is offline
Alex USA
usa.alex's Avatar
Joined Oct 2011
Attachment 5221656
How's this?
Nice job Tony ! Well done !
Looks like you have a lot of EagleTree under the hood
Wings reinforced
Actually I was wondering how did you figure out GoPro installation ... where and how it affects your FPV camera.
I decide to put my GoPro one the nose - to keep my video clear - and use GoPro as FPV camera. And because of that - I couldn't put cockpit cover.
Old Oct 11, 2012, 09:47 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Alex, is you GoPro held on velcro only !!!???
One thing Im considering is just mounting the pan servo on the back of Gopro case so both cams have clear view.
Just trying to work out mounting Gopro to the cover so it wont break it or rip off on sudden stop.
nakelp86 is offline Find More Posts by nakelp86
Old Oct 11, 2012, 01:30 PM
usa.alex is offline
Alex USA
usa.alex's Avatar
Joined Oct 2011
Actually it's just original mount with 3m tape. Holds VERY good. I am not 3D pilot
Old Oct 11, 2012, 01:38 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
thats scary
solved problem to have clear view on both cams :-)
Old Oct 11, 2012, 02:25 PM
usa.alex is offline
Alex USA
usa.alex's Avatar
Joined Oct 2011
thats scary
Isn't it all about ?
Use some CA glue around mount, but honestly I flied like that many times - never had an issue ... so far
Old Oct 11, 2012, 02:27 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Good to know, I will have to make it bit stronger due to added weight on the Gopro.
Can you get some close up, before I start poking holes in the foam :-)?
Old Oct 11, 2012, 04:45 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
I'm not sure where or how I will go about mounting the GoPro. My last FPV plane I had mounted the pan and tilt camera above the GoPro itself. I could go the same route on this plane and just not use the canopy. I didn't plan on using the canopy anyway if a Go Pro was on board. To me, if you are using a GoPro you want clear high definition pictures or video. Therefore you would not want to use a canopy.
I purchased this plane for flying FPV not as a camera or video platform.
I was thinking however about purchasing another cockpit/canopy if possible. If I did want to use a GoPro, I would just change out cockpit assemblies without a clear canopy. I would then just use the Go Pro as the FPV camera.
Old Oct 11, 2012, 05:03 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
I managed to get bot with clear view, look at the pictures.
Good distance from Vtx, just in case you have noisy cam.
Old Oct 11, 2012, 09:14 PM
Beerwiser is offline
Find More Posts by Beerwiser
Beerwiser's Avatar
Canada, AB, Mundare
Joined Mar 2011
I have been following this for a while now and am wondering how the plane thremals? I want something for nice relaxing fpv, I have a wing to get the adrenaline going lol.
Beerwiser is offline Find More Posts by Beerwiser
Old Oct 12, 2012, 10:54 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Ok boys, so whats the idea with the wooden washers ( as per instructions) the will point the motor upwards
Shouldnt they go on the bottom screws??
Or, do we really need them??
Old Oct 13, 2012, 07:18 AM
Atflying is offline
Find More Posts by Atflying
Atflying's Avatar
Joined Feb 2010
Hi:
we have discussed this before,
http://www.rcgroups.com/forums/showt...1684618&page=9
quoted from post #127:
this is not only to change the orientation of the motor thrust but also very importantly to change the airflow of the propeller, it would be influence the horizontal stabilizer and vertical stabilizer, I tried no to use these Discs, the conclusion is that the airplane tends to nose rightward, you have to use rudder trim a little big left to correct the nose direction. But with discs on to, it fly straight forward and hand free control comes.
another one is:
http://fpvlab.com/forums/showthread....eRC.com/page18
Quoted from post #171:
yes, in theory it should be at the side, but not everything is workable according the theory on the book, we tried at the side, the result is get the flight bad enough so do never try it again
get the airflow of the propellery go though the root of the vertical stabilizer is far more significant than to change the "
Reverse torsion moment" so this is the reason
Atflying is offline Find More Posts by Atflying
Site Sponsor
New Product CarbonCore Multicopters for FPV & Aerial Photography Carbon Core Aerial Photography 55 May 12, 2013 11:48 PM
Discussion FPV/Aerial Photography with a purpose.... ApachePilot Aerial Photography 0 Dec 31, 2011 07:49 PM
Discussion Aerial Photography / FPV scratch Slow Stick daronj Foamies (Scratchbuilt) 6 Nov 09, 2011 10:03 PM
Build Log Cheap Aerial Photography and FPV Quadcopter srthomas218 Multirotor Talk 30 Nov 09, 2011 12:19 AM
Build Log Cheap Aerial Photography and FPV Quadcopter srthomas218 Radios 0 Oct 09, 2011 01:50 AM
