Joined May 2012
Need help with FPV...
Hi I was wondering if anyone knew what the voltage this receiver this is?
http://www.hobbyking.com/hobbyking/s...mera_NTSC.html And what all would I need to have it run of a lipo? thanks again |
Its 12v as well. It should run fine off of a 3s lipo charged at 12.6v max.
P.S. that transmitter is rated at 800mw but in reality, it is 600mw. Doesn't make a noticeable difference but just so you know what you're buying ![]() P.S.S if you are just starting out, I would buy a lower output transmitter. This transmitter is heavy (because of heatsync). heatsink can be taken off but you will need constant cooling over the tx. I would also note that if you live near cell phone towers, this will be a cluttered frequency. Great article Here. http://team-blacksheep.com/article/page:16 |
| Thread Tools | |
| Discussion Help needed on purchase of FPV TX/RX setup with my Spektrum DX8. Which MHZ to use | jasper7821 | Video Piloting (FPV/RPV) | 14 | Feb 14, 2012 07:08 PM |
| Discussion Help needed on purchase of FPV TX/RX setup with my Spektrum DX8. Which MHZ to use | jasper7821 | Multirotor Talk | 2 | Feb 13, 2012 05:10 PM |
| Help! FPV Need Help With set up | tom6696950 | Aerial Photography | 1 | Jul 17, 2010 10:32 AM |
| Discussion Need help with FPV setup | metalfred | Video Piloting (FPV/RPV) | 0 | Apr 27, 2010 10:19 PM |
| Discussion Need help with Aiptek wiring harness for FPV & flight recording | MinneFlyer | Video Piloting (FPV/RPV) | 5 | Oct 08, 2008 11:53 PM |
