Old May 01, 2012, 01:07 AM
Joined May 2012
Why is my T-rex 100x spin in a circle after take off??????
My T-rex 100x will not stop spinning to the left. Half throttle, full throttle it just spins in one place. Tried adjusting to the right in both modes and it just spind left. I got a new tail rotor and it has the same problem....so it must be something else??? PLease help, thank you
B_nasty21 is offline Find More Posts by B_nasty21
Old May 01, 2012, 01:54 AM
Different fly 4 different guy
gordonzo's Avatar
Canada, BC, Salmon Arm
Joined Jan 2011
Is the tail rotor on correctly (correct side out and not pressed on too far) and is it turning? With the heli running in your hand, if you turn it to the left and right does the tail motor rpm change?
gordonzo is offline Find More Posts by gordonzo
Old May 01, 2012, 07:55 AM
Joined May 2012
Rpm does change. I'll hold it in my hand and when I turn it right it slows down a little, but turning left it speeds up alot.
Discussion high pitch noise then spin in circles? andrewho83 Micro Helis 11 Jan 21, 2012 06:29 AM
Question T-Rex 100s with T-Rex 100x Tail? H3liN00B Micro Helis 0 Jan 14, 2012 02:23 PM
Discussion Twister CPX blades spin - won't take off (no pitch??) Marshfacev2 3D Electric Heli Flying 4 Dec 29, 2011 12:11 AM
Rant Kennedy Composites 10% off 4 days after my purchase and won't refund the difference. bcucoach2 Vendor Talk 7 Nov 30, 2011 12:37 PM
Discussion After T-rex 100, which should be my first CP? demiluk Beginner Training Area (Heli-Electric) 1 Nov 26, 2011 04:21 PM
