Old May 02, 2012, 07:33 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Originally Posted by wyowindworks View Post
I really need to see videos of people who have mylars that fall off and parts that fall out of mold.
Me too Adam!
I am using a blue foam that is also used by a proffessional bloke in town who makes epoxy composite boats and other things like panels for caravans etc.
Anyway, he reports the same phenomenon as I do, depressions forming in random spots on the foam. They rectified it somehow, but he (and I) are not sure what causes it. It does seem to be a peculiarity or irregularity of this particular source of foam. It's as if the foam is reactive in spots to the epoxy and partially dissolves or something.
Jim.
p.s. I have not read every post on this thread thoroughly yet!
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old May 02, 2012, 08:03 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
I like Meguiar's Mold Release #8 wax.
I usually let the bagged mylar wings cure for 12 hours at room temp under vacuum. I don't like to heat the mylars when they are under vacuum. The mylars become more pliable which reduces the finish quality. Once the resin has set it's no longer necessary to hold the vacuum.
I then cure them without vacuum for at least 12 hours at 125*F with the mylars still on. I often go for 24 to 36 hours if time allows. Then I peel the mylars. Peeling the mylars too soon will almost always cause more fabric print-thru....even with light fabrics. The longer the mylars are on, within reason, the better the surface will be.
A fun experiment is to peel the mylars part way after the 12 hour room temp cure. Then peel it off the rest of the way after it has cured for a few days or at elevated temps. You will notice a very distinct surface finish difference between the two.
Adam
wyowindworks is offline Find More Posts by wyowindworks
Old May 05, 2012, 07:54 PM
plove891 is offline
Find More Posts by plove891
San Diego
Joined Nov 2004
steam and boiling water worked great!
Just to put closure on this, here's the wing, just about done. Just needs reinforcement at the dbreaks, and maybe I'll round the TE at the tips. I used boiling water as suggested and most dents disappeared. Then steamed the rest out with the iron and wet paper towel. Works great. I'm glad I asked because when I first saw those dents I had pretty much written off this wing
Thanks again to everyone for your help.
Paul
plove891 is offline Find More Posts by plove891
Discussion Value Hobby possible credit card stolen after first order gquiring Vendor Talk 6 Aug 28, 2013 11:33 AM
Discussion Golf ball dimple effect on micro airplanes. bdp3822 Scratchbuilt Indoor and Micro Models 28 Oct 04, 2011 03:27 PM
Question Delamination after bag Rogerio Brandao Destito Composites Fabrication 12 Oct 17, 2010 10:57 PM
Possibl;e Virus? Mario Life, The Universe, and Politics 4 Jul 28, 2001 10:01 AM
