Old May 04, 2012, 04:17 PM
mogogear is offline
Find More Posts by mogogear
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
This for you George.........
SUPER SOAKER CPS 2500 Aquatic Weapon Water Blaster Rifle Demonstration (1 min 3 sec)
mogogear is offline Find More Posts by mogogear
Old May 04, 2012, 06:01 PM
ooyah is offline
Find More Posts by ooyah
ooyah's Avatar
GLASGOW
Joined Feb 2011
http://youtu.be/32iYz4MSPUs
Thanks Mo , now I know and I shall pass on having one, at present in Scotland if you were soaked with this you would freeze to death.
Duncan,
Better not go down the road of DUKE of ARGYLLS else we get accused of going off topic.
OOYAH is the name of my flash steamer and is derived from the shout that one gives on touching very high temperature steam pipes.
I wanted to call the boat OOYAAH/B !!! but was told in no uncertain manner by S.H.M.B.O that it was not on.
George.
ooyah is offline Find More Posts by ooyah
Old May 04, 2012, 09:50 PM
mogogear is offline
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
all who wander off topic are not lost...
Old May 04, 2012, 11:26 PM
hookpilot is offline
Find More Posts by hookpilot
hookpilot's Avatar
Reply to George
Other than making the engine more complicated with servo-operated drain valves, are there any other issues with doing it my way? The heavy paddlewheel precludes rapidly switching the reversing gear as this could stress everything too much. I appreciate the posts and pictures.
hookpilot is offline Find More Posts by hookpilot
Old May 05, 2012, 04:42 PM
ooyah is offline
ooyah's Avatar
GLASGOW
Joined Feb 2011
Mike,
Don't know if I explained the reversing valve properly,
It will not cause a surge to the engine and put any stress on the paddle wheel.
If you think about the servo being in mid position with a 45deg swing both ways and when in the mid position the steam is cut off.
Move the servo to the left and as it moves it opens a hole which controls the engine speed until you have full power ahead.
Bring it back to the mid position and the steam is cut off, move it to the right and you have the same control over the engine speed, in both cases it's progressive.
As I have already said your engine being a piston valve you switch the steam from the inlet over to the exhaust and with the 2- cylinders as long as the crank is set at 90 deg to each other the engines will self start and reverse.
In my previous post the Saito Single cylinder engine must not be stopped ,so as you whip the valve over in 95% 0f the time it will reverse the engine as long as it doesn't stop. this method would put a great strain on the paddle wheel
I don't know what " your way" is so how do you propose to stop start and reverse the engine, from your pics it looks as tho' there is a curved quadrant similar to Stevenson link reverse which will have the drag links to pull the eccentrics over to reverse.
How does the full size engine work ?
George.
Old May 07, 2012, 08:28 AM
-kno3- is offline
Find More Posts by -kno3-
-kno3-'s Avatar
Austria, Vienna
Joined Mar 2008
I had the problem of the burner not getting enough air to burn properly on my small steam tug. The windows are all glazed.
I have added a very small fan to a purpose-made brass front hatch, and it solved the problem. Here is a pic (it is somewhat hard to see because the hatch casts a shadow, but it's there):
20090221_125 by -kno3-, on Flickr
The hatch has to stay open when the plant is running.
-kno3- is offline Find More Posts by -kno3-
Old May 07, 2012, 01:15 PM
mogogear is offline
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
Still such a nice tug Calin!!
Old May 07, 2012, 04:55 PM
hookpilot's Avatar
Circ Fan
Great job hiding a functional fan on your steam tug. I'll be installing a fan behind a door window located on the bow work deck. This should take care of airflow inside the boiler room.
Mike in Edmonds
Old May 09, 2012, 12:37 AM
Deserteagle is online now
Find More Posts by Deserteagle
dontflystupid.org
Deserteagle's Avatar
USA, Mt, Great Falls
Joined Nov 2006
I am having to resort to placing a fan in my Clyde puffer because of the burner starving as well. I just got a brushless small pc fan and run it at low rpm's
Deserteagle is online now Find More Posts by Deserteagle
Old May 13, 2012, 01:29 AM
hookpilot's Avatar
Cooling Fan
I picked up a small 12VDC CPU cooling fan, 40mm x 40mm. I'm ready to install it behind one of the boiler room door windows up forward. That should take care of airflow to keep the boiler burner working. If need be, I can install a second fan in the other door window up forward. There are two of them. I'll leave the two aft engine room doors open for exhaust.
Old May 14, 2012, 04:40 AM
-kno3- is offline
-kno3-'s Avatar
Austria, Vienna
Joined Mar 2008
That should work.
Old May 17, 2012, 02:43 AM
hookpilot's Avatar
Preston Steam Engine Build
See my new post on Scale Model Boats, 1/32nd Preston Build Log. At long last, the steam engine for Preston has started construction.
Mike in Edmonds
Sold Graupner Glasgow, Steam Plant, Upgrades, LAST CHANCE ir3 Boats (FS/W) 3 Feb 20, 2012 11:41 AM
For Sale Graupner Glasgow, Steam Plant, Upgrades, REDUCED ir3 Boats (FS/W) 6 Feb 06, 2012 08:30 AM
Help! Cheddar Puffin steam plant dunc2504 Scale Boats 10 May 30, 2011 02:32 AM
Discussion Steam plant for Brooklyn Tug peconic steam Steam Boats 16 Jan 07, 2010 03:52 PM
Wanted cheddar puffin steam plant dunc2504 Boats (FS/W) 1 Jun 13, 2008 03:32 AM
