Old Apr 30, 2012, 09:20 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Question
how much overlap do you use with lam film??
for max strength for a chevron wing /\ that I plan to fly hard..
thanks,
Gary
grfcon is offline Find More Posts by grfcon
Old Apr 30, 2012, 10:42 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
~1/4"
mw
Mark Wood is online now Find More Posts by Mark Wood
Old May 01, 2012, 11:09 AM
macinr is offline
Find More Posts by macinr
macinr's Avatar
USA, CA, Santa Barbara
Joined Feb 2003
I like to lay a piece of film large enough to cover the entire top and bottom. As most planes tend to need more nose weight, and more protection along the leading edge, and I find the more overlap the more torsional rigidity is produced, I overlap a LOT in the center section and along the leading edge. Along the trailing edge a 1/4" is fine. Remember to start ironing from the center and use your wing beds... also overlap such that you don't have the top piece of film wrapping around the bottom on the TE because repeated landings will start to peel back that lip. I ironed the top first, then the bottom.
On my last 48" wing I used the standard width 5 mil NS with a strip that went the entire length of the wing for both top and bottom, butted at the TE so that most of the overlap was along the LE.
Incisions around the nose (in the film) will help the film contour to the compound curves too.
macinr is offline Find More Posts by macinr
Old May 01, 2012, 12:57 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
macin.. did you do your 60" danwing with a single piece top and bottom?
Old May 01, 2012, 01:47 PM
macinr is offline
macinr's Avatar
Joined Feb 2003
for my 60" danwing i used 4 main pieces, always butted them to have 1/2" or so of overlap against the TE. careful about too much tip weight as the tips are behind the CG. the center section of the wing and leading edges had 2 layers of NS and the overlap would taper off as it got towards the tips. i also layed 3M 983 (single direction) tape end-to-end across the entire wing top & bottom.
i also cut out a 8" or so long 1/2" deep slot right along the CG on the bottom and inserted a 1/2" copper tube filled with various lead ballast. to remove i just peel off a single strip of strapping tape. i've lost far too many pieces of lead by taping them to the outside.
enjoy my MS paint drawing....
Old May 01, 2012, 04:47 PM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
Macin your drawing rocks!! never thought of doing that before. Looks strong enough to DS for me. I have a bluto plank I might add a ballast tube to but I hear the scouts will DS stock up to about 120 or so. We will see.. what is the most ballast your 60" danwing ever flew with? what did it's AUW end up to be?
thanks,
Gary
Discussion how much line do you store on your winch webdragon Thermal 17 Apr 21, 2012 07:40 PM
Discussion How much time do you guys spend on flight trimming your planes? Roguedog Classic Pattern Flying 5 Jan 04, 2012 11:24 PM
Question What laminate film do you use? stallion explosi Flying Wings 4 Dec 30, 2011 01:09 PM
Question How much stick time do you have? lovegroove Multirotor Talk 20 Nov 14, 2011 01:28 AM
Radio Control for UAV, What do you use and how much range do you get ???? JettPilot UAV - Unmanned Aerial Vehicles 17 Apr 14, 2009 12:47 PM
