Old Apr 30, 2012, 08:26 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Need advice on quality motors for new build....
Okay guys I am a little stumped.....
I am building a OMGFly Hex
http://www.omgfly.com/index.php?main...roducts_id=381
to go with my RC-Carbon Y-6 (2814s HFpro board)
now it says 2208/2212/2216 motors. I am looking to spend $25-$50 per motor and I need something that will run on 4s 10-12" props and provide over 1000g of thrust in a 60g or lighter case
The 2814-10s are perfect for my larger lifting Y-6, but I need a lighter motor for this smaller hex that will still have the punch i need to lift a 4s4000mah + light gimbal and GoPro or GF2
So I am thinking I need around 7000-8000g of thrust for the whole rig, that gives me up to 3500g of AUW and keeping flight times good.
Any suggestion on 2212,2216 4s capable motors that are 40-70g or less and provide 1200-1400g of thrust on a 10-12" props for $30-50
I know I am damn specific, but thats what I am looking for
thanks guys, ill post my own research here as well
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 30, 2012, 08:39 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
http://www.omgfly.com/index.php?main...products_id=10
seems like decent motor that would probably work with 10" graupner prop on 4S. I believe they are about 80gm motor.
alternately, I believe tiger has some
http://www.clubheli.com/Tiger-Motors...KV_p_3580.html
askman is offline Find More Posts by askman
Old Apr 30, 2012, 08:42 PM
Adidas4275's Avatar
Joined Mar 2011
hey thanks....
i am sure you know this and I am going to look like a complete an utter n00b
but...... how are the motor numbers correlated to power?
I have 2814s that are smaller than 2830s and the 2814s put out more thrust and are heavier than the 2830s.
I get the park nomenclature but the XXXX numbering keep baffling me
like i said i just embarrassed my self
oh and those T-motors liked to
say they are only good for 2s-3s but i like the low KV (larger props)
Old Apr 30, 2012, 09:26 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I hate the number scheme, since they don't follow the standard. in general though I worry about is the weight of the motor and kv. weight has to do with ability to dissipate heat. (ability to handle power) kV has to do with rpm and prop size. (to an extent. we will get to this in a bit)
you are talking about 50-80gm motor. (which is the typical 2212-2218 sized) they have kv ranging from 750-1400 depending on wind (thicker wire /lower turn means higher kv and thinner wire/higher turn means lower kv) in general though, each size motor has sweet spot and for this class motor, it is about 1000kv. you will find that there is a trade off between Io and Rm as you change turns. This affects the efficiency of the motor.
In general, lower kv means higher torque and visa versa, but there is physical limit. thinner wire means it can only carry limited current. I don't worry about voltage, but I do worry about current. this really limit you in prop size or voltage. (why they say 2-3S)
anyway, there is no free lunch and lot of tradeoff. if you want higher torque, you need mechanical advantage that comes with larger diameter can. if you want to limit the weight, you need to make it short. that is why pancake motors are the best choice for us. taller can also give more torque, but not as good as larger diameter. but it is tougher to make pancake. so price goes up. if you want to run 10-11" prop, it is not easy to do with small motor. why prop selection gets important.
Old Apr 30, 2012, 09:38 PM
Adidas4275's Avatar
Joined Mar 2011
Yeah apparently I want my cake and I want to eat the whole thing.
Thanks for the description.
Old Apr 30, 2012, 09:39 PM
BenHayat is offline
Find More Posts by BenHayat
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
Nice!!!
BenHayat is offline Find More Posts by BenHayat
Old Apr 30, 2012, 09:40 PM
BenHayat is offline
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
Or do you mean the "Pancake"? :-)
Old Apr 30, 2012, 10:38 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
>>I have 2814s that are smaller than 2830s and the 2814s put out more thrust and are heavier than the 2830s.<<
The best thing to do is to look at the drawings if they are available. Some vendor describe 2830 as the outer dimension and some as the inner dimension. Typically the 2814 is an inner dimension. So 2216 is also an inner dimension.
For example the Axi motors all use inner dimension. So their 2814 should be the same size as the Avroto 2814 and the SunnySky 2814.
Pretty confusing huh!
So you really need some 2216 with around 700 kV to use 4 cells. I wouldn't swing an 11" or 12" prop with them though. If your 2814's are swinging 11" or 12" props at 4 cells how can you expect a smaller motor to do the same thing? Unless you can find a 2216 that has 600kV.
Here is a pretty good 2216 but you need to use 9" or 10" props max:
http://epbuddy.com/index.php?main_pa...roducts_id=270
Your other option is to use those pancake motors like these:
http://www.clubheli.com/Tiger-Motors...KV_p_3583.html
SeismicCWave is offline Find More Posts by SeismicCWave
Old Apr 30, 2012, 10:42 PM
Adidas4275's Avatar
Joined Mar 2011
yeah, my turnigy 2830s are perfect for 4s and the are the right weight the thrust...
just looking for something similar with a little higher quality windings and bearings
so ill do some research and figure out which inside measurement motors are similar for 4s
Old Apr 30, 2012, 11:26 PM
Adidas4275's Avatar
Joined Mar 2011
okay, i just ordered some
Sunnysky 2216-11 KV800 motors and will run them on 4s with 10" props it will be better in the wind with 10" rather than 11" anyways
thanks guys..... stupid motor numbers
Old May 01, 2012, 08:39 AM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
See you ordered some already but tigermotors makes several 2830 in different kv they just call them 2212
pug398 is offline Find More Posts by pug398
Discussion Need a new platform. Advice on zepher build? slowjett FPV Talk 3 Apr 02, 2012 01:34 AM
Discussion Need advice on gears for modified Stampede Augy_IA Off-road Cars 0 Mar 25, 2012 08:11 AM
Discussion Advice needed for first quadrotor building lotus_cb Multirotor Talk 7 Mar 18, 2012 08:33 PM
Question Need advice on new quad frame, to replace x525!!! Arxangel Multirotor Talk 3 Mar 01, 2012 04:29 PM
Help! First Build - Need advice on electronics and motor NewarkAndy Beginner Training Area (Aircraft-Electric) 5 Jan 20, 2012 01:12 AM
