Espritmodel.com Heli Air
Old Apr 30, 2012, 12:50 PM
Wazmo's Avatar
No. VA
Joined Nov 2004
Taboo GT Bulkhead
Does anyone have a measured drawing, template, or plan-view photo of a Taboo GT bulkhead (the one just ahead of the wing, where the pins insert)? Mine is broken, and the top half is missing. I can try using a contour gauge to duplicate the shape of the pod, but it would be nice to start with the correct size and shape.
Wazmo is offline Find More Posts by Wazmo
Old Apr 30, 2012, 01:00 PM
Wazmo:
I had three (3) Taboos (and often wish I still had one). Trust me on this: the top half is NOT repeat NOT critical in shape.
My recommendation: remove (if you haven't already) the bottom half, use it to rough out a new outline on new plywood and make a new replacement bulkhead. The original was designed to fit closely on the bottom, only.
If you do not wish to remove the bottom half, that's OK, too. I broke one of mine and made a rough-shape second one, and glued it to the back side of the remainder of the original. I drilled the initial holes a bit too small, then enlarged them with a round file to match the wing posts. In retrospect, it would have been easier to pull the old one out, and make a new one.
Good luck!
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Apr 30, 2012, 01:55 PM
Auger up & out, not down & in!
United States, ID, Lewiston
Joined Apr 2011
Wasmo, I am currently putting my Taboo GT together using a windworks fuselage( long skinny thingy) . I have a complete fuselage and parts that you can have including a ballast system all brand new! PM me a reasonable offer and I will ship it to you. Tom
IDOF3K is offline Find More Posts by IDOF3K
Old Apr 30, 2012, 03:11 PM
The ground's the limit.
shawnc's Avatar
Boulder, CO Area
Joined Aug 2008
I had this same problem last week. I cut up a piece of paper board until it fit the fuselage and under the canopy, then traced its outline onto my bulkhead stock (thin ply/balsa/ply-didn't have the stock plywood). A little finish sanding gave a like new fit.
shawnc is offline Find More Posts by shawnc
Old Apr 30, 2012, 05:55 PM
Walter Roos
ROOSWH's Avatar
Canton, Ga.
Joined Aug 2004
Scanned it, let's see how it looks
Comes out a tad small on my screen. Need to blow it up to 28x20mm
Right click on the small picture, click print and you get a big picture which you can reduce on most copy machines etc.
walt
ROOSWH is offline Find More Posts by ROOSWH
Old Apr 30, 2012, 05:58 PM
Wazmo's Avatar
No. VA
Joined Nov 2004
Fantastic. Thanks, Walt.
@IDOF3K: Thanks for the offer. I'll keep that in mind as I evaluate the remaining repairs.
Old Apr 30, 2012, 11:32 PM
Wazmo's Avatar
No. VA
Joined Nov 2004
The remaining bulkhead was glued with something rubbery and very tenacious, probably Goop. Finally got it out after much pulling, twisting, and cutting.
Sold Taboo GT DLG BNF $460 SHIPPED Conus bcucoach2 Aircraft - Sailplanes (FS/W) 7 Apr 13, 2012 06:19 AM
Sold Taboo GT DLG BNF $460 SHIPPED Conus bcucoach2 Aircraft - Sailplanes (FS/W) 6 Apr 11, 2012 06:35 PM
For Sale Taboo GT DLG 225$ Angus540t Aircraft - Sailplanes (FS/W) 5 Mar 14, 2012 07:32 PM
Question Taboo GT Bulkhead Outline wamdue Hand Launch 2 Jun 04, 2009 04:48 PM
Discussion Taboo GT front bulkhead material D_Ryan Hand Launch 3 Sep 04, 2008 02:30 PM
