Old Apr 30, 2012, 10:45 AM
Thane63 is offline
Find More Posts by Thane63
Joined Nov 2004
Inertia - 100" Pitcheron / TWF
I convinced a good friend of mine Jim, that we should each build a pair of pitcherons that I had been dreaming up for a couple of years now. He hasn't said it, but I'm sure he wondering what he got him self into. It's been a struggle at times.
The design called for a 100" wingspan, able to fit inside a packing case so a cross tail is mandatory, thin airfoils optimized for fast huge air carving & the largest diameter wing rod possible to take the abuse of the Dragons Teeth. The construction is all carbon. Uni on the bagged wings & carbon sock on the fuse.
The twisty hardware uses 3 thrust bearings capturing two flanges that rotate independently. The wing rod does not carry thru, but is split in the middle and each half slides into the rotating flanges. It's hard to describe & unfortunately I don't have any photos of it not installed. I hope it works.
I hope to maiden it in a couple of weeks at Wilson Lake during the MWSC.
Thane
Thane63 is offline Find More Posts by Thane63
Old Apr 30, 2012, 11:04 AM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Beautiful! Nice job molding, too! I love the slip on nose! I hope you can video her maiden flight!
So...what exactly is going to take the span wise bending load?
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Apr 30, 2012, 11:09 AM
BigSwede is offline
Find More Posts by BigSwede
Ninja Master
BigSwede's Avatar
United States, CA, Thousand Oaks
Joined Feb 2007
Wow! Looks amazing! I've been thinking about a 100" wingeron/pitcheron for a while. I don't think I'll get to building one for a long time though. Your ship looks great. Good luck on your maiden.
BigSwede is offline Find More Posts by BigSwede
Old Apr 30, 2012, 11:23 AM
Thane63 is offline
Joined Nov 2004
Ward, the loads are carried by the thrust bearings & flanges working against each other.
I hope it works, if not I'll be giving you a shout.
Thane
Old Apr 30, 2012, 11:48 AM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
Looks super clean Thane! Nice work! Good luck with the chuck!
-hutch
Hutch is offline Find More Posts by Hutch
Old Apr 30, 2012, 11:55 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Elegant airframe and lovely workmanship
Have you locked the wing rods to the rotary bearings and is the frame that carries the servos / bearings very strong? I think I get what you're doing but there may be some odd loads in the fuselage. Or I may have got it completely wrong
Best of luck for the maiden flight.
S
Shedofdread is offline Find More Posts by Shedofdread
Old Apr 30, 2012, 12:15 PM
Thane63 is offline
Joined Nov 2004
The side rails are 0.25" 6061-T6 that squeeze the flanges & bearings together with four 10-32 aircraft grade screws. In a positive bending load situation the bottom of the flanges will want to spread apart & are held from doing so by the rails, while the top of the flanges are compressed against each other. The thrust bearings hopefully keep everything running smooth.
Old Apr 30, 2012, 12:18 PM
Thane63 is offline
Joined Nov 2004
Here's a photo before the servos were mounted.
Old Apr 30, 2012, 12:26 PM
Jack B is offline
Find More Posts by Jack B
Jack
United States, NE, Lincoln
Joined Dec 2005
Wow Thane its done. hope to see it in a couple weeks. Is Jims plane done?
Jack B is offline Find More Posts by Jack B
Old Apr 30, 2012, 12:30 PM
c0dem0nkey is offline
Find More Posts by c0dem0nkey
I want it to go fast...
c0dem0nkey's Avatar
United States, OR, Bend
Joined Sep 2006
Plane looks wicked fast. What is the AUW on her?
c0dem0nkey is offline Find More Posts by c0dem0nkey
Old Apr 30, 2012, 12:57 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
Looks great. I'd love to see some video.
slopemeno is online now Find More Posts by slopemeno
Old Apr 30, 2012, 01:12 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
Very nice, should really be a big air carver...hope you have a great landing area, because your workmanship is so awesome, it'd be a real bummer to 'nack it up after one great flight (been there - done that, many times myself!)
Thanks for sharing, hope to see super positive maiden results!
Andy
droydx is offline Find More Posts by droydx
Old Apr 30, 2012, 01:13 PM
winchdoc is online now
Find More Posts by winchdoc
Yes, ALL your money...
winchdoc's Avatar
A hut in the woods in Oregon
Joined Jan 2003
nice looking plane! Shiny metal gizmos! oh yeah!
winchdoc is online now Find More Posts by winchdoc
Old Apr 30, 2012, 01:36 PM
Thane63 is offline
Joined Nov 2004
Jack, I know Jim's getting close. He hopes to have it ready for the slope challenge.
The AUW is at 79 oz.
Landing is a major concern. With the slip on nose cone, winchdocs canopy brake is out. I'm going to give it a go with no system at all for now. I have access to some hills with open stretches of pasture ground for landing zones. Hopefully it all works out. maybe a drag chute is in the future.
Old Apr 30, 2012, 03:01 PM
c0dem0nkey's Avatar
Joined Sep 2006
Would love to collaborate on the drag chute idea...I know its a one shot deal but I think with the right setup there would be no need to fly around for another landing.
Discussion foam pitcheron or TWF kit? hamburger Slope 5 Mar 20, 2012 09:28 AM
Video TWF Tail cam - 2m pitcheron flyonline Sailplane Talk 6 Feb 07, 2010 02:16 AM
Discussion TWF: Pitcheron differential and LE shape? Antonsoarer Slope 4 Jan 25, 2008 07:25 AM
Build Log SSDC 100" Pitcheron, vacuum bagged solid hardwood AndreasMergner Slope 19 Sep 28, 2007 05:58 PM
Discussion TWF Gurus - Pitcheron + elevator = CROW? BillO Slope 20 Aug 02, 2007 12:49 AM
