Espritmodel.com Heli Air
Old Apr 30, 2012, 08:35 AM
Human + R/C = Happiness
ican3d's Avatar
Joined Jun 2011
FPV air combat corner
Hi guys, come in and share your Air to Air/Air combat FPV experience and tech know how stuff. Just don't discuss about launching projectile or shooting stuff. AMA is watching.
OK here's my Air Combat video. Flying my AXN Cloud Fly with Foxtech 5.8Ghz fpv system, stock antennas, GOSDII, Quanum Telemetry, 420VTL cam with wide angle lenses, Foxtech pan tilt with HXT 900 modded to 180 degree pan, Foxtech AIO goggles, HK Mini DVR recording device and others described inside the videos.
I prefer AXN Cloud Fly because its fast, agile and can easily bail out from trouble unlike my slow Sky Surfer @ Bixler. Let's hear what setup you have on your rig.
My video:
FPV Air Combat - AXN cloud fly EPO (4 min 36 sec)
ican3d is offline Find More Posts by ican3d
Old Apr 30, 2012, 09:31 AM
Ikaruswannab
Joined Sep 2009
Hi.
I have a couple of the old sonic combat module that i guess would be great fun FPVing like you did.
But i have a question. What video frequency was used on the other plane???
Me and a friend are flying on 1.3GHz and we want to try long range formation but even when we use the two extreme frequencies on that band we still get some interference when flying near to each other.
Any info on how others have done it when using one video band?
teopbako is offline Find More Posts by teopbako
Old Apr 30, 2012, 09:34 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The sonic combat modues do not work with fast planes due to Doppler effect. However I just got a set of these: http://www.nghobbies.com/cart/index....roducts_id=486
If anyone wants to do FPV combat, please stop by and we'll have a blast
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 30, 2012, 09:39 AM
ican3d's Avatar
Joined Jun 2011
Well the other plane that i chase isn't FPV. However last time we did have both 5.8ghz running but separated by different channel. Mine at CH=56 while others at CH=59 apart so there should be a good big gap in between within the bandwidth spektrum. Our transmission power is at 200mw, so interference knock off is minimal. We once got hit by 500mw, so i think if you flying in pairs better separate yourself with different channel setup and use low MW power.
I might be wrong but we're in luck at that time. Maybe Ibcrazy could give us some tips.
Old Apr 30, 2012, 09:52 AM
ican3d's Avatar
Joined Jun 2011
Oh yeah i remember something. He was on 5.8Ghz Fatshark...that Airwave thingy. I was on Foxtech. I think thats why it doesn't cause much problem on that day but we do have problem when nearing some trees.
Old Apr 30, 2012, 10:09 AM
Ikaruswannab
Joined Sep 2009
In my case i use 1160 and my friend is on 1280.
When in ground side by side we get a lot of static.once airborn it clears but not as when only one is flying. All that up to 2.5Km as beyond that i had to return as the picture was getting worse.
He uses a patch and i made myself a BiQuad as per IBCrazy (Thanks)
Old Apr 30, 2012, 04:23 PM
ican3d's Avatar
Joined Jun 2011
Did you put low pass filter like this one at Foxtech? http://www.foxtechfpv.com/1400mhz-lo...ter-p-439.html
Old Apr 30, 2012, 04:35 PM
Ikaruswannab
Joined Sep 2009
We both fly with DL UHF so it is not needed.
The problem is that our video Rx's are receiving interference from each other.
Nobody had met/solved such an issue?
Old Apr 30, 2012, 10:26 PM
ican3d's Avatar
Joined Jun 2011
Well if you could post some vids how it would look like we might get a clue. Btw i'm making another dog fight video again. I got my wingman so hopefully i could mod my HXT900 servo to 360 degree pan for better view on the flight formation.
Old May 01, 2012, 12:26 AM
Design, Build, and Fly
KatanaGuy's Avatar
Pleasant Grove, Utah
Joined Nov 2001
Spring 2012 SWARM Combat w/ Crash (2 min 51 sec)
<iframe src="http://player.vimeo.com/video/41223839" width="500" height="375" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
Huh? It is not embedding as normal. FPV full-contact combat at the Utah Flyer's Org. SWARM.
-Steve
KatanaGuy is offline Find More Posts by KatanaGuy
Discussion Air Combat USA anyone ever done it? nuttcase21 General Aviation 6 Jul 15, 2012 04:00 PM
For Sale Hog Wild Air Combat Plane bbrown2828 Aircraft - Electric - Airplanes (FS/W) 4 Mar 06, 2012 12:06 AM
Discussion Trex FPV vs Hirobo air to air chase HeliAddx Video Piloting (FPV/RPV) 0 Dec 23, 2011 04:54 AM
Discussion Yak air combat video winterstick Slope 4 Dec 14, 2011 09:32 AM
Discussion Buzzing Bee's or Air Combat at the 2011 NAT's KickAce Combat Fuel Planes 0 Oct 01, 2011 09:31 PM
