Old Apr 29, 2012, 09:35 PM
CJRAY is offline
Find More Posts by CJRAY
CJRAY's Avatar
United States, GA, LaGrange
Joined Mar 2012
Help!
6S with a bad cell
OK, I know that I'm probably posting in the wrong section, so maybe a mod can move it for me. I tried searching to no avail, so here goes. I have a Gens Ace 6S 5300mah with maybe 20 cycles on it that has apparently dropped cell #6. When charging, it appears fines, charges fine, however, under load, that cell drops off first, heats up, and has puffed slightly. After sitting, it will come back up in voltage to equal the other cells. Anyone ever see that? Any ideas? What i was thinking about doing, was to removing the Number 6 cell and change it to a usable 5s pack? Any thoughts? Any help is appreciated.
CJRAY is offline Find More Posts by CJRAY
Old Apr 30, 2012, 09:27 AM
dedStik is offline
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I'm sure it can be done, but given the volatile nature of lipo's I wouldn't try it, as it's just not worth the risk.
dedStik is offline Find More Posts by dedStik
Old Apr 30, 2012, 01:05 PM
CJRAY is offline
CJRAY's Avatar
Joined Mar 2012
Yeah, I've separated a different bad 6s pack that I had, just to look and check it out. I don't think it would be too bad considering it's an outside cell. I'm just looking for some pics or a thread with pics for reference or a step by step, I guess.
Old Apr 30, 2012, 04:41 PM
Endlesslag is online now
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Orlando
Joined Jan 2011
If it's an outside cell, it's doable. i did it with a 3s pack that had a dead cell, made it a 2s. I just desoldered the dead cell and removed it's balance wire from all of them. still had to plug into the 3s balance port but functioned as a 2s fine.Just be careful. It's not impossible, but it's tough to solder the wires and tabs together, especially when it's an aluminum tab. They have to use a special solder and flux, and the tabs are tack welded together.
Endlesslag is online now Find More Posts by Endlesslag
Old Apr 30, 2012, 06:49 PM
CJRAY is offline
CJRAY's Avatar
Joined Mar 2012
Yeah, i fixed it when I got home from work. Just unwrapped it, clipped the positive wire and balance tap wire off, removed the cell and re soldered the positive wire back on. All done, Very simple with it being the last cell. Would be a problem in the middle or on other end where you would have to rearrange all of the balance leads. Now I have a good 5s pack for my Patriot.
Old Apr 30, 2012, 07:28 PM
Endlesslag's Avatar
Joined Jan 2011
Cool, glad it worked out charges and balances ok?
Old May 01, 2012, 03:39 PM
CJRAY is offline
CJRAY's Avatar
Joined Mar 2012
Yeah, which is the strange thing as it did that anyway. After a few minutes of flying, #6 would start dumping. The way I noticed is that I lost power on my 550E and when I brought in in to land, it was twitching. I immediately checked the cells and 1-5 were are like 65%, 6 was at 30% and hot. Let it sit for a while and it would revive itself and they would all show to be in the 65% range. Tried sloooow charging it, but kept getting the same results. Kind of strange. Anyway, removed the cell, balance charged it, and hooked up the Patriot for some power system testing and it worked great as a 5S. Money saved! The Patriot needs more cooling holes though.
Old May 09, 2012, 10:28 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Whoa! Don't fly with a bad LiPo cell!!
These internal cells are usually in series, which means that the pressure of all the individual cells gets pushed through the bad cell (so it heats up). Bad news.
I have had a 4S battery lose a cell and read as a 3S. I don't trust doing the surgery to remove the bad cell, so discard these.
wuest3141 is offline Find More Posts by wuest3141
Old May 09, 2012, 11:37 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Done it before when lipos were expensive, even the crappy ones from HK. If you search over at Runryder or Helifreak, there are threads showing how.
chopper62 is offline Find More Posts by chopper62
Old May 10, 2012, 07:41 AM
CJRAY is offline
CJRAY's Avatar
Joined Mar 2012
Well, it was # 6 on the end, so it was as easy as removing the covering, clipping the positive wire off of number six, un-soldering it from 5 and re-soldering the positive wire back on to # 5 and wrapping the pack back up. If it was another cell, I probably wouldn't have messed with it.
For Sale 6S 3000mah Turnigy with one bad cell MrRetro Aircraft - Electric - Batteries & Chargers (FS/W) 7 May 02, 2012 04:55 AM
Discussion New 6s Zippy from HK takes 98 minutes to charge at about 1c ? Bad cell ? phranticness Batteries and Chargers 22 Jan 24, 2012 10:18 AM
Sold Turnigy 3600mAh 6S 30C with bad cell snoshoe62 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 09, 2012 02:34 AM
Question 6S with bad cell? gallfer Batteries and Chargers 10 Apr 05, 2010 11:16 AM
For Sale Brand new Kong Power 2600mah 6s lipo with one bad cell rccrazee Aircraft - Electric - Batteries & Chargers (FS/W) 20 Mar 23, 2009 12:55 AM
