Old May 25, 2012, 10:12 AM
Joined Jan 2012
frankg-----Rich--- Planking duplication.
Rich thanks for the suggestion (above in #30) . This method seems reasonable and tedious,but then what Isn't?Even life can be tedious(unless you throw a little gasoline into the fire of life)
Seriously,I am considering that method.
However there is something no one has suggested.
If succesfull,I will "show & tell" a method presently under test.What fits me is that this method is tedious and UNREASONABLE .
Since being accused as tedious & unreasonable,I may follow that avenue
"FILM AT ELEVEN" (soon)
OBW
oldbilgewater is offline Find More Posts by oldbilgewater
Old May 25, 2012, 12:16 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
We want some more pic's!
Kmot is offline Find More Posts by Kmot
Old May 25, 2012, 01:48 PM
Joined Jan 2012
Of what? Me,a tree,and a chainsaw? (see #29 above)
You git'n a little testy and impatientTom? Ya git that way sometimes when the pain killers wear off.
OK, pics tonight or Sat.at the latest.
OBW
I just get no sympathy
Old May 27, 2012, 09:53 AM
Joined Jan 2012
Side skins
While watching the Phillies win over St. Louis last night, I fit the top side skins to the framework. This particular balsa seemed unusually resistant to the required bending three ways. It was necessary for me to wet the outside of the skins the second time before the balsa seemed to give enough.
Today I will give it a little more drying time (water), then glue the skins permanently.
OBW
Old May 27, 2012, 12:34 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
That's more like it!
Thanks OBW. Say, I like those pins with the ball ends. Looks like they may be more comfortable to push in than the "T-pin" type?
Old May 27, 2012, 01:03 PM
Joined Jan 2012
Pins
Yes , try them , (JOANN FABRICS) stores all over the US &Canada. Not only more comfortable but,you do not have to "orient"the head as you pick them up or place them. That's a small point but, I think, easier.
OBW
PS Upper side skins are cemented,should have pics up mon. with pins & clamps removed.
Old May 27, 2012, 04:13 PM
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
And we took it right back.
green-boat is offline Find More Posts by green-boat
Old May 27, 2012, 06:26 PM
Joined Jan 2012
And you did it quite well, I might add.
OBW
Old May 28, 2012, 01:30 PM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Just be careful when you push them in, i tried several where the ball splitted and i ended up with the other end of the pin in my now bleeding finger
Sharky1dk is offline Find More Posts by Sharky1dk
Old May 28, 2012, 03:39 PM
Joined Jan 2012
Balls on your pins
You are right but,don't tell the GOVERNMENT,they will make them illegal.
Actually,I like to put them in with a needle nose pliers. When I take them out I turn the ball (this breaks the glue off the pin) then pull it out.
OBW
Old May 28, 2012, 06:53 PM
Joined Jan 2012
Both sides sheets have been cemented in place, and one plank has been added.
The rest of the side must be planked . Last the bottom sheet's will be cemented in place, then the bottom planks will be done.
Old May 28, 2012, 07:10 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
It's looking good obw. Do you have some Bondo on there already?
As for the ball pins, OUCH! Yeah I can see how that would be a pain, lol.
I have some Midwest pins that have big red knobs on them:
Midwest Products Hobby & Craft Grip Pins
Old May 29, 2012, 04:36 AM
Joined Jan 2012
Me????? Bondo ?????
Okay HAWKEYE, you caught me.
When I built this identical kit 50 years ago, I learned quickly(and to suit my personality) to correct certain inequities caused by diecutting error etc. I found, to correct errors or problems early, was much less distracting for me.
Using red Bondo, is like dropping a half cup of coffee on a white carpet. It ain't much, but it sure do make a mess.
I hope to finish the side planking, today.
OBW
Old May 29, 2012, 07:21 AM
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Coming along just fine OBW. Glad to see that you will apply the diagonal planks at the bow rather than trying to sheet the whole side. The planks work much better. One problem that I found with my 63 was at the transome. A leak developed at the lower right hand corner after a few runs in the water. I sealed the leak with epoxy which worked fine but I would suggest paying particular attention to that area when gluing on the sheeting. Put a bead of glue along the seam on the inside. The transome is built so that you can't get into it after the model is complete so you need to do this before you close it up. If I built another of these models I would coat the inside of the transome area with epoxy liberally before I put the top deck on. Pete
norgale is offline Find More Posts by norgale
Alert ebay Stirling 63 MY W/fittings oldbilgewater Dock Talk 4 May 14, 2012 08:50 PM
Alert Stirling 63' Chris Craft Ebay alert oldbilgewater Scale Boats 0 Mar 17, 2012 05:43 AM
Alert TWO-STIRLING CHRIS CRAFT 50' CATALINAs oldbilgewater Dock Talk 0 Feb 10, 2012 07:00 AM
