Old Apr 29, 2012, 03:26 PM
Readability is offline
Find More Posts by Readability
Joined Apr 2012
I'm trying to build my first plane
I have been flying a trainer for quite a while now and have grown out of it. I saw mikey's video on the pylon racer ( http://mikeysrc.com/Pylon_Racer.html ) and would love to make one. and even if I crash it is seems pretty cheap to fix. I have done some research on how to make rc planes but the out side doesn't seem too hard and actually I am going to love it but I still dont know that much about the internals . I looked up some of the hardwear that looks like it would work for the pylon racer but im not sure if everything will work... I'm Guessing something has to be wrong is it? could I get some help buying my first...? EVERYTHING
14.8V 4 cell 1600 -2200mAh 20C li-po battery
http://www.hobbyking.com/hobbycity/s...Lipo_Pack.html
2600 - 2700KV 78 gram brushless motor.
http://www.hobbyking.com/hobbycity/s...idProduct=6263
60 amp ESC.
http://www.hobbyking.com/hobbycity/s...ESC_Opto_.html
9 gram servos.
http://www.hobbyking.com/hobbycity/s...cro_Servo.html
4.5 X 4.5 high speed prop.
http://www.hobbyking.com/hobbycity/s...propeller.html
also I dont have a transmitter or receiver will this work out well?
http://www.hobbyking.com/hobbyking/s...x_Mode_2_.html
thank you so much for your help
Readability is offline Find More Posts by Readability
Old Apr 29, 2012, 03:59 PM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
Welcome !!!
Hey Readability welcome to RC groups and it's nice to see you want to build your own plane . I'm also building my own plane (Scratch built balsa RC Trainer 1.6m wingspan) and it's also my very first build. Unlike you i've never flown an Rc plane before ( not including little park flyers ) but want to build my own . I've looked at the Rc plane you want to build and i think it's a neat little flyer. However as your second aircraft you might want to step up to something where you can use your skills that you've learnt from your RC trainer. Here's one i though you might like. http://rc-trader.co.uk/blog/electrifly-super-sportster. I prefer balsa over foam to build with ( you might prefer otherwise). my RC plane is made of balsa.
Also have you decided on a wingspan? once you've done that here's a link to what the proportions of you're rc plane should be if you want a nice smooth flight. If you want a more responsive and more agile plane shorten some of the dimensions.http://www.indoorflyingmodel.com/DesignParameters.html
I was also wondering if you want to include an airfoil. you probably know about this but a symmetrical airfoil is grat for a pylon racer.
If your building with foam which i presume you are, then a KF airfoil is great. It allows for lift and it's easy to build. Here's a link for a well explained youtube video on KF airfoils
Why we use KF Airfoils! (2 min 57 sec)
You may also like some of the designs this guy has.
Anyway i've gone on enough here's the link on my build if you want to check it out. http://www.rcgroups.com/forums/showthread.php?t=1638287
Hope it inspires you to go the balsa way
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old Apr 29, 2012, 05:11 PM
Joined Apr 2012
thank you! that electrifly super sportster does look like a great plane I might look into it! if anything when crash it enough to total it, I'll try my hand at building some thing else using the parts from it. I still would like to know if everything that I might buy in the first post will work together well?
I have never owned at balsa plane it seems like too much work and it is really easy to fix a foam plane. I know if I get a more aerobatic plane I am going to crash a lot at first and would like something that I could fix myself and with this modal it only cost $1 for the foam to build it
I don't know the exact wingspan I'm just basing it off mikey's pylon racer
there is (what some might call) a airfoil on the racer. he glues the spar on top of the wing and then tapes over the wing and that makes the "airfoil". I have read a little about the KF airfoil and might try something like that in the future but right now I'm sticking to using the design that I talked about above (it seems simpler, for now)
Best wished for your project! if I did that much work on some thing like that I would never fly it!!!
Old Apr 29, 2012, 05:43 PM
Joined Apr 2012
Sorry but I can't access your links to your planned electrics. However I think you'd be better of looking at this forum and setting up a thread in this link. http://www.rcgroups.com/foamies-scratchbuilt-428/ sorry I couldn't help
Old Apr 29, 2012, 08:42 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
I'd suggest building a RTF kit first, then scratch build your first R/C airplane after knowing how to deal all of the stuffs needed. Here's the link I think would be helpful with you at this moment. http://www.rcgroups.com/forums/showthread.php?t=1586139 I did suggest what he might need for the RTF kit I recommemded. Be reminded that the RTF kit, GWS Slow Stick or E-Starter is quite cheap, they are easy to build, easy to fly and easy to repair.
Chen
twn Chen is offline Find More Posts by twn Chen
Old Apr 30, 2012, 04:38 AM
boredom.is.me is offline
Find More Posts by boredom.is.me
Micro Boat Forum Founder
boredom.is.me's Avatar
United States, GA, Buford
Joined Nov 2007
Originally Posted by Readability View Post
...and even if I crash it is seems pretty cheap to fix...
The cost to fix a crash is not anything compared to the cost of time spent fixing it. Bare that in mind when you pick your build materials.
boredom.is.me is offline Find More Posts by boredom.is.me
Old Apr 30, 2012, 08:37 AM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I've had balsa kits that I've actually repaired for a cost of less than $1.
In particular I tip stalled a high wing trainer on landing and did a nice cartwheel in for my landing, there was much applause and if anyone had large numbers on signs I'm sure they would have gone up.
End result the whole tail section sheered off and was only held on by the pushrods. I took it home peeled back the covering and cut off the jagged bits of balsa. I went outside as the ice cream mans truck could be heard. I bought 2 popsicles and went home to enjoy them. I then took the sticks and then glued them into the fuse binding the two pieces, the patch held the entire time I owned the plane (about 4 more years).
True story.
dedStik is online now Find More Posts by dedStik
Old Apr 30, 2012, 11:47 AM
Joined Apr 2012
To be honest i think balsa is better to build with and is a joy to work with. But i think you seem set on foam so you should go with that.
Help! Help required building my first FPV Plane. acid_rainbow FPV Aircraft 8 Apr 08, 2012 10:32 AM
Help! I'm trying to ID my planes Diplomat Fuel Plane Talk 7 Feb 26, 2012 09:08 PM
Help! My first large scale Plane build, Hanger 9 SU 26: Umb1 Giant Scale Airplanes 6 Feb 08, 2012 11:57 AM
Discussion help with my plane I'm building airjumper Foamies (Scratchbuilt) 10 Oct 23, 2011 11:05 PM
Build Log Miss Stik Sr. - My Fianceť's first plane (and my first stick build) habitforming Beginner Training Area (Aircraft-Electric) 38 Feb 15, 2009 12:04 PM
