Old Apr 29, 2012, 09:38 AM
United States, WA, Tacoma
Joined Mar 2011
NAZA not autolanding
Noob here. Recently purchased a VC-450 with a NAZA FX. Using a Dx6i with a AR6100e receiver. I've had a couple of instances where the quad loses radio connection and just falls out of the sky. I was under the impression that when that happens the NAZA will automatically go into a fail safe mode and autoland. Well, that hasn't been happening. I've heard that the fail safe feature with the Naza won't work with a 6 channel transmitter. Is this true? If so, I'd really like to upgrade, not only to get that feature but to extend my range. I've been looking at Dragon Link and EZUHF. Any recs? At most I'd like to have a range of a mile or so with a solid connection.
Bijaz is offline Find More Posts by Bijaz
Old Apr 29, 2012, 09:58 AM
tstrike's Avatar
United States, UT, Cottonwood Heights
Joined Mar 2012
You can't set naza failsafe with the dx6i, you can set throttle failsafe through the tx which then sets the throttle at a predetermined level when you lose tx/rx connection. You need a tx with a 3 way switch to activate the naza failsafe.
tstrike is offline Find More Posts by tstrike
Old Apr 29, 2012, 10:16 AM
Fly High - Lake Tahoe
Las Vegas/Lake Tahoe
Joined Feb 2010
The Dx6i is not the problem, it is the AR6100e which does not support preset failsafe. None of the 6 series receivers do, some of the 7 series do, all the 8 and 9 series do. You can set up a two position switch to do a Tx based failsafe by using the mix. But what does that give you other than an auto land when you have Tx control.
Tahoe Ed is offline Find More Posts by Tahoe Ed
Old Apr 29, 2012, 10:51 AM
Joined Mar 2011
I guess should I then upgrade the receiver, radio or both?
I guess if you have a throttle failsafe, it only set the throttle to a predetermined level and if you are in a turn or something, it could get away from you. Is that correct? In other words, it doesn't stabilize it's position? As Tahoe Ed said, you can have an autoland feature with a two way, but you still have a transmitter connection. My desire is to have the quad land when it loses a connection to the transmitter. What would either of you recommend for a radio with a three way switch? DX7?
Old Apr 29, 2012, 10:53 AM
Joined Feb 2010
Again, it is not the radio. You can do it with a DX6i just get a receiver that supports preset failsafe. This may explain it better than I can.
http://helifreak.com/showpost.php?p=3792179&postcount=9
Old Apr 29, 2012, 10:56 AM
Joined Mar 2011
Thanks for the link Ed
That's exactly what I was looking for.
Build Log DJI F550 NAZA ARF COMPLETE BUILD and DJI NAZA ASSISTANT w/ TX CALIBRATION >VIDEOS< patrick21x Multirotor Talk 11 Nov 30, 2012 07:13 PM
Discussion DJI F450 NAZA kit vs Witespy VC450 with NAZA kit MC21 Multirotor Talk 5 May 16, 2012 02:16 PM
Help! DJI Naza F450, motor nr.3 not speeding up at once. Solex_nl Multirotor Talk 2 Feb 29, 2012 01:19 PM
Discussion DX7 Autoland pplschmpion Electric Plane Talk 3 Apr 13, 2008 10:46 PM
