Old Nov 19, 2012, 11:02 PM
Joined Sep 2008
Having watched/read about the TopGun guys (who are just this side of OCD) you have to choose a specific time period, and craft to do exactly that, freeze that moment in the life of that object (boat, tank, aircraft, whatever). If something is changed 15 seconds after that moment then drive on and know that you did your absolute best AT THAT MOMENT!
Foo
fooman2008 is offline Find More Posts by fooman2008
Old Nov 21, 2012, 02:48 AM
New Zealand, Tasman, Motueka
Joined Aug 2012
equip box platform
hi gavman
curious to know how you made the structure that box sits on, the one you are using with the more rounded cnrs and the one you started with?
fantastic work BTW
GregSpooner is offline Find More Posts by GregSpooner
Old Nov 21, 2012, 08:25 AM
Shoreacres Texas
Joined Apr 2007
GS, I started with a square box of styrene. I added the side pieces and then sanded the outside corners round with a drum sander mounted in my small drill press. I used a small dowel wrapped with sandpaper to get the curves in the side pieces. When I changed the part I glued 1/4in styrene pieces to the inside corners and used a smaller drum in my drill press to sand the inside curve, I also thinned the thickness of the sides at that time. I did not make two of these I just changed the first part to better match the pictures.
Gravman is online now Find More Posts by Gravman
Old Nov 22, 2012, 07:26 AM
"Damn The Torpedoes...."
PT-333's Avatar
Mount Dora, FL.
Joined Oct 2007
Gravman, the mast looks fine. and speaking about making extra parts, I have extra mounts for your 20MM mags. They are mounted on top of ammo boxes and are used to hold the mag while the tensioning each mag. If you like just PM me with your address and I will send you some.
And have a great Thanksgiving, Ken V.
PT-333 is offline Find More Posts by PT-333
Old Nov 22, 2012, 07:47 AM
PT-333's Avatar
Mount Dora, FL.
Joined Oct 2007
This is a photo of the 20MM racks that I was talking about.
Old Nov 22, 2012, 09:41 AM
Joined Sep 2008
I will withhold my personal opinion of the second coming of MacArthur and just say that Admiral Bulkeley richly deserved the Medal of Honor he received for a great act of seamanship and bravery. I knew a couple PT vets (and loved to hear their sea stories) from the war. I am still enjoying your build.
Foo
Old Nov 23, 2012, 03:06 AM
Joined Aug 2012
[ I did not make two of these I just changed the first part to better match the pictures
Thanks for that-- I will have to chase down supplies of different shaped styrene down here in kiwiland and have a go at this stuff.
Old Nov 25, 2012, 10:30 AM
Shoreacres Texas
Joined Apr 2007
Radar Mast
One of the prominent features on the mast are the cables which run up the sides of the mast legs. These cables are held in place by clips which are clearly shown in the photos. These would seem to be simple enough to make, but for me they proved to be a real challenge. First I tried to make a U-shaped channel out of styrene and then cut the clips off the strip. This did not work as the saw destroyed the styrene pieces. Next I cut the clips out of brass channel. This seemed to work until I tried to get them to be uniform in size as they fit over the wires. The channel I had would work for a pair of wires but I did not have anything that would work for 3 wires in brass. After a lot of trial and error I finally came up with a jig that allowed me to make the 3 sizes of clips that I needed. It is always the simple things that seem to cause me the most trouble.
Old Nov 25, 2012, 01:24 PM
Shoreacres Texas
Joined Apr 2007
Radar Mast
I trimmed the clips down and did a trial fit to the mast leg. Not too bad. Once I get it fastened to the leg I will add the little pieces to the side of each clip.
Old Nov 25, 2012, 02:05 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
More mind boggling stuff from Gravman!
Kmot is offline Find More Posts by Kmot
Old Nov 25, 2012, 05:40 PM
Spreckels Lake, GGP, SF, CA
craig_c's Avatar
USA, CA, San Francisco
Joined Apr 2007
Dis iz what scale modeling is all about!!! Cudos to Gravman for setting such a fine example for the rest of us to aspire to!
This just became a must see thread.
craig_c is offline Find More Posts by craig_c
Old Nov 26, 2012, 12:06 AM
Taking care of the pond.
MILLERTIME's Avatar
USA, CA, Fresno
Joined Apr 2004
I'm getting dizzy.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Nov 26, 2012, 08:12 AM
Tim Brown
Tim B.'s Avatar
Oakland Ca.
Joined Aug 2009
Lookin like the finished model will be Bristling with detail but not overboard~
Tim B. is offline Find More Posts by Tim B.
Old Nov 27, 2012, 01:53 PM
Shoreacres Texas
Joined Apr 2007
Radar Mast
Made a little more progress on the mast today. I added the attachment points to the wire clips. I fastened the assembly to the leg of the mast and added the wires going around the bottom of the mast leg.
Discussion Got a PT Boat engine, but no PT Boat? Kmot Dock Talk 16 May 10, 2012 03:15 PM
For Sale ProBoat PT Boat P31 Boats (FS/W) 1 Feb 29, 2012 11:22 AM
Link World War II PT-boat restoration reaches milestone, PT-305 ken_nj Dock Talk 4 Nov 16, 2010 08:12 AM
Discussion 1/16th Late War Elco PT boat Jeff Van Hofwegen Scale Boats 14 Oct 06, 2010 04:39 PM
Gallery 1/20 Late War Elco - almost ready to launch newPTboater Scale Boats 23 Apr 19, 2010 08:54 PM
