Old Apr 29, 2012, 09:03 AM
poussin is offline
Find More Posts by poussin
poussin's Avatar
France, IdF, Combs-la-Ville
Joined Nov 2011
Samson SA2- Avatar/Twincopter
Hello, I present this project in construction horns, with a fuselage of Samson bicopter SA2, If you have any questions do not hesitate!
The fuse complete with a UBEC and the kit weighs 96grammes led, Still a lot of work to finish but I'm nearer the end than the beginning! : D
Two vidéos:
Samson SA-2 Gunship RC Twincopter Avatar (1 min 48 sec)
[video]
Samson Gunship Avatar test fly Num 4 (0 min 16 sec)
[/ video]
poussin is offline Find More Posts by poussin
Old Apr 29, 2012, 04:14 PM
native18 is offline
Find More Posts by native18
Arkhangelsk, Russia
Joined Apr 2009
Hello.
I am very interested in your model. What are the dimensions of the model? There are problems on the pitch?
I built a model AT-99 Scorpion.
native18 is offline Find More Posts by native18
Old Apr 29, 2012, 05:14 PM
poussin is offline
poussin's Avatar
Joined Nov 2011
Originally Posted by native18 View Post
Hello.
Hello, this is because of your famous model, I decided to build my own, thank you very much.
And yes I have a problem of stabilization of the axis of the pitch, I use a black board KK, for the dimension it measures about 60cm long and 60cm wide and 20cm high, with a weight of 700gr.
Old Apr 29, 2012, 05:41 PM
native18 is offline
Arkhangelsk, Russia
Joined Apr 2009
How are you going to solve this problem?
I have tried many options bicoptera and they had a problem with the pitch.
In the end I put the impeller in the tail. The result is a tricopter.
Old Apr 29, 2012, 05:50 PM
poussin is offline
poussin's Avatar
Joined Nov 2011
So for now, a very high center of gravity of the machine and I reduced the end point of the pitch to 20%, and the gain to a minimum ,I remake the test in the week!
for now I want a steady, within a circle of 1 meter, but it is still difficult.
Old Apr 29, 2012, 06:59 PM
native18 is offline
Arkhangelsk, Russia
Joined Apr 2009
I look forward to continuing.
Old May 01, 2012, 03:25 PM
poussin is offline
poussin's Avatar
Joined Nov 2011
After several unsuccessful trials more or less, the right end point of the pitch will remain at 25% and no show by cons it takes a lot of weight at the lowest point of the device with 85 grams more, it becomes more docile and controllable !
The downside is that if it comes from trops on this axis, it is getting difficult to catch up!
Old May 01, 2012, 06:55 PM
leadfeather is online now
Find More Posts by leadfeather
Winging it Ò>
leadfeather's Avatar
Joined May 2006
That is an amazing project. It looks so good. Best of luck with the flights!
leadfeather is online now Find More Posts by leadfeather
Old May 10, 2012, 07:09 AM
poussin is offline
poussin's Avatar
Joined Nov 2011
Finally I can not get better with this card, I'll try another, but which one? :
Old May 10, 2012, 04:12 PM
native18 is offline
Arkhangelsk, Russia
Joined Apr 2009
In these models, I use MultiWii.
I have not tested, but try to change the location of propellers and engines. Screws-bottom. As here. This is not my model.
小卓 阿凡達直昇機 台灣製造-公羽 Small Zhuo Avatar helicopter Taiwan - movie AVATAR (5 min 43 sec)
Old May 13, 2012, 10:32 PM
vtol guy is offline
Find More Posts by vtol guy
Joined Dec 2011
What kind of gyro are you using? I have been researching and building VTOLs and it seems that a gryo that stabilizes the aircraft on all 3 axis is ideal. Just a suggestion!
vtol guy is offline Find More Posts by vtol guy
Old Sep 07, 2012, 02:42 PM
extrmsports is offline
Find More Posts by extrmsports
United States, CA, Livermore
Joined Mar 2012
Bi-copter
What kind of Bi-copter is that?
extrmsports is offline Find More Posts by extrmsports
Old Sep 07, 2012, 10:39 PM
Stenz28 is offline
Find More Posts by Stenz28
Utah
Joined Sep 2009
Very nice work, guys!
Stenz28 is offline Find More Posts by Stenz28
Old Dec 13, 2012, 10:09 PM
VikingUAS is offline
Find More Posts by VikingUAS
Joined Dec 2012
Hi I am helping my son build the same model as you he is getting really frustrated I bought him the KK blackboard and the fireware isnt working can you tell me what board and tilt booms you used much appreciated just looking to help him in the right direction.
VikingUAS is offline Find More Posts by VikingUAS
Old Dec 14, 2012, 12:51 AM
Carlos230023 is online now
Find More Posts by Carlos230023
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
A good place to start is the KK2.0 board from hobbyking, dead cheap and field programable. Make sure it's running firmware version 1.5.
CJ
Carlos230023 is online now Find More Posts by Carlos230023
Discussion Has anyone started designing a SA-2 Samson from the movie Avatar? topgun21 VTOLs 307 Aug 06, 2014 03:23 AM
Build Log Avatar Samson SA2 Aerospatial Twincopter poussin Multirotor Talk 23 May 10, 2012 07:09 AM
Discussion mini twincopter samwei1950 VTOLs 5 Apr 09, 2012 06:14 AM
Discussion singlecopter & twincopter samwei1950 Multirotor Talk 1 Feb 12, 2012 09:50 PM
