Old Apr 29, 2012, 03:42 AM
dumb_thumbs is offline
Find More Posts by dumb_thumbs
wrong descision, wrong time
United States, WA, Maple Valley
Joined Sep 2010
power tools for plane building
I am getting ready to move into our new house, and with that I will be gaining a workshop
Because of this, I'd like to add some power tools to my workshop to help with building projects. To date I've built mainly smaller foam planes from 1/4" foam board using a sanding block and xacto knife. Because I'll now have the room, I'd like to scale up
I have been kicking around the idea of getting a scroll saw or small band saw, and a bench sander. My dad had a combination bench sander (like this one: http://www.harborfreight.com/4-inch-...der-97181.html) and we used it constantly for all kinds of building projects. My question comes into which kind of saw I should get. I've used both scroll and band saws growing up, but not sure which would be the handiest for building R/C aircraft. Any and all thoughts are welcome on this, along with any other suggestions for tools I should be looking at.
I'll probably continue building with the foam board, but I'd like to build a balsa model here soon after I get my workbench built.
-Heath
dumb_thumbs is offline Find More Posts by dumb_thumbs
Old Apr 29, 2012, 06:22 AM
DeeBee1 is offline
Find More Posts by DeeBee1
DeeBee1's Avatar
United Kingdom, England, Brighton
Joined Apr 2007
Hi Heath,
You're going to get a million different opinions, but here's what works for me. Some people will tell you to buy small general purpose power tools that can also be used for other jobs, such as repair work round the house etc. Personally, I tried this but found these types of tools a little inaccurate for model building and so I purchased a Proxxon/Micromark mini bandsaw and a Proxxon/Micromark mini drill press:
http://www.micromark.com/variable-sp...dsaw,7913.html
http://www.micromark.com/microlux-3-...ress,7797.html
I've found these to be the right level of power and accuracy for model building. I didn't bother with a bench sander as I would have only used it for bevelling parts, which I can do with the bandsaw. Similarly, the band saw blade is narrow enough to do some of the cutting that a scroll saw would do.
I had a scroll saw, but hardly used it and sold it in the end (I also found it hard to use, but probably didn't practice enough!). I also tried a mini table saw, but again found that the bandsaw could do most of the jobs that I was doing on the table saw, although if you are cutting wide sheets of material, a table saw might be an option worth exploring.
http://www.micromark.com/microlux-mi...-use,7500.html
Good luck! Let us know what you decide.
DeeBee1 is offline Find More Posts by DeeBee1
Old Apr 29, 2012, 11:36 AM
earlcbrown is offline
Find More Posts by earlcbrown
United States, CA, Stockton
Joined Jan 2006
I have a scroll saw a band saw a drill press and a disc sander. I have been scratch building for quite a few years, I have need most all of them during my builds. When I started out I had a band saw and a disc sander, And I was able to build OK. then when I got my band saw & drill press, it seems like my builds from then on went a little easier. If I was starting today I would get a drill press and a band saw.
Just my two cents
Earl
earlcbrown is offline Find More Posts by earlcbrown
Old Apr 29, 2012, 08:38 PM
lindart is offline
Find More Posts by lindart
Art Schmitz
United States, TN, Crossville
Joined Jan 2012
6" bench vise, jig saw, drill press, disc sander/grinding wheel, 3/8 cordless drill, 3/8 110 drill,
and several soldering irons. Dremel tool.
Usual hand tools...common, duck bill, and needle nose pliers, many different sized screw drivers of each type, Exacto carving set with three extra #11 set ups. Aluminum yard stick, triangles, 12"x36" balsa building board. Three sizes of T pins.
Heat gun and Coverite sealing iron.
lindart is offline Find More Posts by lindart
Old Apr 29, 2012, 09:44 PM
Nergall is online now
Find More Posts by Nergall
Nergall's Avatar
United States, GA, Lilburn
Joined Aug 2009
Drill press first. It seems like a tool you'd rarely use until you have one. Once you have one, you wonder how other people live without one?
Scroll saw or band saw if you plan to cut parts. (Do you plan build? Kit bash? If so, you'll want one of those.)
I have a cheap Harbor Freight sander, and not knocking Harbor Freight, it works fine, it is just too small to be of very much use. Go big or don't bother.
Nergall is online now Find More Posts by Nergall
Old Apr 29, 2012, 10:07 PM
SeamusG is offline
Find More Posts by SeamusG
United States, CO, Arvada
Joined Sep 2007
I use a scroll saw, band saw, Dremel, & hand held drill.
A sander / grinder will be next.
Can a drill press be used as a "drum sander" as well?
Oh yea - a Harbor Freight mini table saw can barely cut balsa stock more than 1/8" thick. Please don't waste your money.
SeamusG is offline Find More Posts by SeamusG
Old Apr 30, 2012, 07:18 AM
Nergall's Avatar
Joined Aug 2009
Of course.
Old Apr 30, 2012, 07:41 AM
DeeBee1 is offline
DeeBee1's Avatar
Joined Apr 2007
Well it can, but the bearings on most drill presses don't like lateral force very much, so you might find that the press looses accuracy over time if used in this way too often.
Old Apr 30, 2012, 01:53 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
For sanding balsa or light duty wood drum sanding the drill press bearings would be fine. But it's not wise to do anything hardcore in terms of side loads on a drill press like heavy sanding of hardwoods or metals. It's all a case of a scale of the forces involved compared to the bearing sizes. Besides, if the drill press is a little bigger and uses a Morse taper tang chuck then any serious side loads will cause the Morse taper to quickly lose it's lock and walk out. Then the drum falls down onto the table. That's a good sign that you're pushing harder than you should....
If you're going to have any sort of sander I'd suggest that you include a shop vac in the sander budget and use some aluminium roof flashing or similar to make up dust catching shrouds around the sanding areas and have the shop vac handy to act as a dust collector. Sanding balsa and other light density woods makes one heckuva lot of fine dust which messes up everything in short order.
For saws I prefer the constant downward travel of a bandsaw over a scroll saw. But for the size and money you get a lot more throat clearance with a scroll saw. If you have the room I'd suggest a 14 inch bandsaw. It'll do anything you can imagine for model building and will come in very handy for any bigger wood working uses as well. If you're a little tight for space and funds then "settle" for a scroll saw. Not that it's a huge step down if you get a nicer one.
If you can manage it eventually get both. The scroll saw has the advantage of being able to cut internal holes by unhooking one end of the blade to pass through a hole where the bandsaw has to cut its way in from the outside.
In terms of priority for power tools I'd suggest the following;
  1. hand drill
  2. Dremel or similar rotary tool
  3. Drill press
  4. Band or scroll saw (I prefer the bandsaw)
  5. Sander AND dedicated or handy shop vac as dust collector.
  6. Table saw- A contractor style that will accept a variety of blade sizes including a very thin kerf 8 inch blade for resawing balsa sheet into strip stock.
BMatthews is online now Find More Posts by BMatthews
Old May 02, 2012, 11:01 AM
Joined Sep 2010
Thanks for everyone's feedback. I'm lucky that I have a number of tools already (including a dremel tool, and several cordless tools). I think I'll be looking at a drill press and a band saw. The really nice thing with both of those, is my wife can use them for her crafts and jewelry making. It makes getting the appropriate budget aproval much easier
Of course along with the above power tools, I'll be building a band saw style hotwire cutter, and a regular bow type hotwire cutter. These are to feed my foam additiction ...
-Heath
Old May 03, 2012, 01:56 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Originally Posted by dumb_thumbs View Post
.....These are to feed my foam additiction ...
-Heath
There's help groups available for this illness.... .
Old May 04, 2012, 12:36 AM
shootnstarz is offline
Find More Posts by shootnstarz
USA, FL, Pensacola
Joined Jul 2009
I use my disk sander quite often. Cut the parts slightly oversize on the band/scroll saw and sand to final shape.
Rick
shootnstarz is offline Find More Posts by shootnstarz
Old May 05, 2012, 01:50 AM
Tarasdad is offline
Find More Posts by Tarasdad
Re-kitting Expert
Tarasdad's Avatar
USA, CA, California City
Joined Jul 2009
Don't go cheap on a band saw, you want to spend as much as you can possibly afford and then some. Table flex, blade centering and other problems are common with a lot of the cheaper ones.
Tarasdad is offline Find More Posts by Tarasdad
Old May 06, 2012, 10:13 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"Don't go cheap on a band saw, you want to spend as much as you can possibly afford and then some."
Amen. I was doing furniture for my family, and made that mistake. Looked great, and the price was right. I spent more time trying to get it dialed in, and cutting right, that I did cutting. Then, in the middle of a project, the base casting actually broke, and I had to buy AGAIN.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old May 06, 2012, 11:42 AM
old_dude is offline
Find More Posts by old_dude
Groundloop World Champion
old_dude's Avatar
USA, AZ, Glendale
Joined Jan 2002
You'll probably end up with a Dremel ....very handy for modeling and around the house. I prefer the cordless (even though I have a corded I had used for many years). If it doesn't come with a keyless chuck...GET ONE !!
THE practiced voice of first hand experience says, "DO NOT BUY A DREMEL DRILL PRESS !!" They will not give the precision you will want.
I use my disc / belt sander all the time ...... very handy
I have a Sears top end scroll saw that I've learned to use properly....important. Though I don't use it a lot, it is indispensable / irreplaceable for some jobs.
Lots and lots and lots of smaller hand tools
Old_dude
old_dude is offline Find More Posts by old_dude
For Sale Great Planes Power Plane and Hinge tool gavoss Aircraft - General - Miscellaneous (FS/W) 4 Jun 13, 2012 12:10 AM
Discussion Tools for multi rotor building anonamous Multirotor Talk 15 Mar 08, 2012 09:58 PM
Discussion Need help getting all the correct tools (links,basic hand tools to basic power tools) schusterjo The Builders Workshop 31 Jan 19, 2012 06:50 AM
Sold GP power plane, hinge slotting tool SamD Aircraft - General - Miscellaneous (FS/W) 2 Jan 07, 2008 05:22 PM
New Power plane tool ROCKS!! megawatt Electric Plane Talk 0 Apr 19, 2002 11:24 PM
