Old Jan 13, 2013, 12:43 PM
daboz is offline
Find More Posts by daboz
daboz's Avatar
HB cali
Joined Apr 2006
Lots of room
I was able to get lots of room...
First I put a 5OZ fishing weight shaped like a stretched out football, (rugby ball for those of you in other English speaking countries) in the nose and it almost fit perfectly in the nose. I just cut the connector of the front and glued it in with some Led shot and epoxy. This allows for a very dense nose weight, pure lead. Second I put the RX in the saddle and put the antennae in the nose behind the battery.
Airtronics RX fits great.
Perfect shaped Led sinker.
daboz is offline Find More Posts by daboz
Old Jan 13, 2013, 02:25 PM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
I wonder if submerging the nose in Dry-Ice then pouring in molten lead would work??? Any one tried this before?
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jan 13, 2013, 02:42 PM
sll914 is online now
Find More Posts by sll914
sll914's Avatar
Joined Oct 2003
Typically, cool water is enough to prevent damage to the paint. Just make sure it doesn't leak thru into the nose before you pour the lead... that would be BAD! No guarantees on what effect it has if any regarding the strength or toughness of the structure... Tape a cup to the nose once the elevator servo is done so you can see just how much lead you're going to need for balance. I anticipate roughly 11-14oz for the heavy layup. Fitting the necessary nose weight really hasn't been an issue.
sll914 is online now Find More Posts by sll914
Old Jan 13, 2013, 04:52 PM
Joined Jul 2005
All good, I tend to over analyse things. I just want it all to go really well and have no failures. I hate Hate HATE it when a model of mine crashes because something has failed. I would much rather dumb-thumb a model, at least then I know it was me and I could have prevented it.
Old Jan 13, 2013, 06:19 PM
spotterone is offline
Find More Posts by spotterone
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
I've made wet sand moulds for my models before. Just get a large cup or a small bucket, fill it with sand, wet it enough so it stays together and poke the nose of the plane in it. Slowly pour in some molten lead and voila! A little bit of shaping, and it should fit perfectly.
A good trick is to quickly put a fishing swivel into it as soon as you have poured it, while the lead is still molten. That way you can tie some cord to it and pull it back out while your testing the fit.
spotterone is offline Find More Posts by spotterone
Old Jan 13, 2013, 07:44 PM
lesterpk is offline
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
Done similar but with plaster of paris mold. An old tin can with the wet mix in it, slather the nose of the glider with release or even just something like cooking oil. Hang so it doesnt touch the bottom of the tin. When dry pull the fuse out and then I baked the tin in an oven for an hour at 80C or so. Engouh to ensure all moisture is out, then melt lead and pour into mold, allow to cool, job done.
IMHO much safer than pouring lead into something containing water.
lesterpk is offline Find More Posts by lesterpk
Old Jan 14, 2013, 12:01 AM
gizzo is offline
Find More Posts by gizzo
Live slow, Die whenever
gizzo's Avatar
Adelaide, Australia
Leo, thats how I usually do it (wet sand mould), but I like the swivel idea, never thought of that. Sometimes the lead shape needs a bit fettling with a hammer afterwards, to make the diameter less so it fits properly, if it's a thick moulding. My Homebuilts I've been pouring the molten lead in directly, with the nose submerged in cold water with ice chips after AvB described the method. Works great and from my experience, doesn't make the nose exposed to heat any weaker than it would have been otherwise. The thing that catches me out is, I balance the model with a cup taped outside then melt that weight of lead. Pour it in and it ends up a bit nose heavy ('cause the lead gets right up the front) and you can't get it out to drill it.
My 2c, YMMV, IMHO etc
gizzo is offline Find More Posts by gizzo
Old Jan 14, 2013, 12:31 AM
LVSloper is online now
Find More Posts by LVSloper
LVSloper's Avatar
Las Vegas
Joined Mar 2009
I always subtract about 2 oz. from the cup and just add stick on weights to balance it out. This way, you don't run the chance of being nose heavy and have to grind out any weight or add tail weight. My2c.
LVSloper is online now Find More Posts by LVSloper
Old Jan 14, 2013, 02:45 AM
AvB is offline
AvB
Find More Posts by AvB
AvB
Wind, hill, ... I'm keen ...
AvB's Avatar
Australia, QLD, Woody Point
Joined Nov 2006
Pouring into the nose is a regular thing for me now, very quick and easy. But a word of warning! I've had a couple where I've failed to get the cloth to close over the seam right at the tip of the nose. It may look fine (closed over with epoxy and paint) but when you pour the lead in, the lead melts the tip hole and runs out like water! Don't hold the fuz over your feet!
If in doubt, or if there is a hole, it's easy fixed ... just wrap a couple of layers of aluminium foil around the tip and tape it on with masking tape, then pour lead. Works perfectly.
You need to use a butane bottle and burner to get enough heat. Forget about using kitchen gas stoves. Get a small container of water and ice cubes and get the water level so you can stick the nose in and rest it on the bottom without water entering the cavity. I hold the fuz in one hand, take the pannikin with molten lead in the other and pour in fast, then put the nose in the cold water quickly. Watch the lead and soon as it's gone solid, I run outside, making sure that I bang the fin against the door frame when exiting the shed, and hold the lead tip under a running tap for a minute or so. Finished.
I agree with the guys above ... it's better to put about 10% too little into the nose and then add a couple of shaped plates of lead on top, which can be easily removed to get the CG right. I've had to take a big drill up to the slope sometimes, to remove lead when trimming, which is a pain. And you can twist the nose right off your model with a powerful drill if you're not careful.
AvB is offline Find More Posts by AvB
Old Jan 14, 2013, 03:24 AM
pope is offline
Find More Posts by pope
Dave Pope Manawatu NZ
pope's Avatar
Palmerston North NZ
Joined Dec 2006
We do the same as avb all the time, works great, I used to cast it in sand but too much shaping to get it in and it never goes right to the front. The last hot lead pour I did the other day did have a tiny hole in the nose, saw it when we had a pin line of lead in the bucket of water, all fine though. I normally splash a little water in the nose just after pouring whlie the nose is in the bucket, once cool I stuff paper towels in on top of the lead and tip the fuse upside down for the towels to soak up the water.
pope is offline Find More Posts by pope
Old Jan 14, 2013, 05:57 AM
gizzo is offline
gizzo's Avatar
Adelaide, Australia
I will learn some day.....
Old Jan 14, 2013, 06:05 AM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
These should fit nicely will have mine tomorrow and will double check on a heavy lay-up, Just add a Vreg/bec and everyones happy, Just dont crash and start a fire!
http://www.hobbyking.com/hobbyking/s...dProduct=17283
Forrest12 is offline Find More Posts by Forrest12
Old Jan 14, 2013, 06:09 AM
decones is offline
Find More Posts by decones
making my own planes...
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
Why don't you use LiPoFe ?
decones is offline Find More Posts by decones
Old Jan 14, 2013, 06:10 AM
Forrest12's Avatar
Joined Jul 2009
Can you get it in those dimensions?
Old Jan 14, 2013, 07:19 AM
decones is offline
decones's Avatar
Curitiba - Brazil
Joined Oct 2007
I do think yes
http://www.hobbyking.com/hobbyking/s...iver_Pack.html
Discussion Another New Model Kumeta DP daboz Dynamic Soaring 17 Oct 29, 2012 05:57 AM
Cool 100" Kinetic DP in Museum! sll914 Dynamic Soaring 32 Dec 23, 2011 11:09 AM
