Old Jan 09, 2013, 12:33 PM
jibber is offline
Find More Posts by jibber
Joined Jan 2009
Hi,
did I get that right? MKS6125 all around? Elevator also?
thanks,
cyril
jibber is offline Find More Posts by jibber
Old Jan 09, 2013, 05:18 PM
sll914 is offline
Find More Posts by sll914
sll914's Avatar
Joined Oct 2003
Yes Cyril, I believe the MKS DS6125 are the best solution for every surface..
sll914 is offline Find More Posts by sll914
Old Jan 10, 2013, 10:36 AM
jibber is offline
Joined Jan 2009
Thanks spencer!
looking so much forward on getting this awesome plane...
cheers,
Cyril
Old Jan 12, 2013, 10:47 AM
wdeighton is offline
Find More Posts by wdeighton
Where is the inspiration
wdeighton's Avatar
Moira
Joined Feb 2006
Not sure if this question has been covered, but what is the Fuz Construction?
2.4gig friendly?
wdeighton is offline Find More Posts by wdeighton
Old Jan 12, 2013, 11:43 AM
sll914 is offline
sll914's Avatar
Joined Oct 2003
Yes it is 2.4 compliant from 1" ahead of LE
Old Jan 12, 2013, 01:54 PM
wdeighton's Avatar
Moira
Joined Feb 2006
Cheers Spencer
Old Jan 12, 2013, 08:48 PM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
But if the nose is full of lead, kinda gives you a small 2.4 friendly area. Same for most models
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jan 13, 2013, 08:54 AM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Perhaps use tungsten powder in lieu, Alex, & buy a bit more space?
Not too pricey bought via fleabay.
dsman is offline Find More Posts by dsman
Old Jan 13, 2013, 09:33 AM
sll914 is offline
sll914's Avatar
Joined Oct 2003
There is room enough for lead, battery and 2.4 rx... I like to use a rx with (2) antennae so you can cheat them up partly beside the battery on opposite corners. I've been doing this with the Hitec Optima 9 and haven't had any range check issues on any of them. I think the best battery for allowing max antenna room is the 4cell 2500mah Eneloop square pack. Allows alot of battery capacity and still lots of room too. I'll remove the tray from my orange K2m and post that photo ASAP. In the mean time heres a photo of my light (green) one with a 5cell 2000 mah eneloop pack for the hitec servos.
If you range check and get poor results with this approach, then an alternative could be to use 1500 2/3A cells end to end and lay them in the wing saddle (yellow plane photo). This leaves the nose wide open.
If you have concerns, use as much solid lead as possible in conjunction with lead shot and epoxy. I usually use a 4oz-8oz torpedo trolling weight with a little hammering to shape it some more. First I put a small amount of shot and epoxy into the nose then drop the torpedo into it and tap the nose to seat it as far forward as possible. Then I fill the rest with lead shot and epoxy.
I do have some tungsten and tungsten powder but have not needed it. Actually wondering if the final density of tungsten powder and epoxy is any more than solid lead? Anybody ever checked?
Old Jan 13, 2013, 09:46 AM
sll914 is offline
sll914's Avatar
Joined Oct 2003
Oh, and here is that photo I promised of Tony Fu's bearing kits. Really nice stuff!
One cool feature is his custom headless shoulder screw that allows the servo to be removed or installed without removing the screw from the servo. There are also ground flats on either side of the bearing to allow grip for pliers.
Old Jan 13, 2013, 10:00 AM
Frank S is offline
Find More Posts by Frank S
sewing machine thumb
United States, CA, Palo Alto
Joined Jul 2001
I have tried it. I've never been able to get greater density with tungsten powder and epoxy, but maybe I'm not mixing it right.
Frank S is offline Find More Posts by Frank S
Old Jan 13, 2013, 10:14 AM
dsman is offline
dsman's Avatar
Joined Mar 2007
Finalising the build of a 26" span carbon mouldie a few days ago, found I needed the tungsten powder as there was insufficient nose volume for lead alone.
But I pour it in dry & compact it hard before adding a layer of lead shot onto which is dropped thickened epoxy to form a sealing skin.
Used the same method successfully before.
Though given the space Spencer has demonstrated is available on the K2M, it would appear to be of no benefit.
Old Jan 13, 2013, 10:15 AM
dsman is offline
dsman's Avatar
Joined Mar 2007
One cool feature is his custom headless shoulder screw that allows the servo* to be removed or installed without removing the screw from the servo. There are also ground flats on either side of the bearing to allow grip for pliers.
* arm ?
Old Jan 13, 2013, 10:16 AM
sll914 is offline
sll914's Avatar
Joined Oct 2003
Heres the tray with the AA square pack for my orange K2m. This install uses a 6.5oz piece of removable noseweight on the stick that accounts for keeping the CG correct with the d-box empty vs. filled with lead shot. A better alternative I think would be to make all the noseweight fixed and correct the CG when the dbox is filled by adding a weight on a stick down the fuselage boom aft of the CG...
Old Jan 13, 2013, 10:18 AM
sll914 is offline
sll914's Avatar
Joined Oct 2003
Originally Posted by dsman View Post
* arm ?
OK, arm and / or servo...
Discussion Another New Model Kumeta DP daboz Dynamic Soaring 17 Oct 29, 2012 05:57 AM
Cool 100" Kinetic DP in Museum! sll914 Dynamic Soaring 32 Dec 23, 2011 11:09 AM
