Old Apr 28, 2012, 09:19 PM
Riodiler1 is offline
Find More Posts by Riodiler1
United States, CA, Livermore
Joined Jan 2005
Lack of aileron throw near wingtips on ASW28 (ST-Models)
I just completed assembly of my ST-Models ASW28 glider and when I function the ailerons, the movement of the ailerons is much greater near the fuse and the ailerons don't have much movement near the wing tips. The ailerons are flat and not warped. Is this normal for this plane? Do you guys see the same thing on your ASW28 models out there? Any suggestions or advice would be great.
Riodiler1 is offline Find More Posts by Riodiler1
Old Apr 30, 2012, 03:10 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
Hinge stiffness might be the issue... Disconnect the servo and hand move them..
rtbates is offline Find More Posts by rtbates
Discussion ST Model ASW28 Mr Kamikaze Australia 935 Aug 02, 2016 12:55 AM
Discussion Hobbyking / St Model ASW28 Review and Hacks foamaircraft Foamies (Kits) 1 Aug 05, 2012 07:29 AM
Discussion What is CG for ST-Models ASW28 Riodiler1 Electric Sailplanes 2 Jun 23, 2012 12:02 PM
Discussion CG for ST-Models ASW28????? Riodiler1 Foamies (Kits) 5 Jun 23, 2012 05:49 AM
Discussion Replacement motor/prop for Hobbyking / St Model ASW28 ? frank48 Electric Sailplanes 0 Apr 10, 2012 09:49 AM
