Apr 28, 2012, 03:55 PM
United States, NJ, Mystic Island
Joined Jul 2009
ParkZone Spitfire MK IX (BNF) Will Be at Joe Nall
Assembled, Never Flown, Buying Options Available, A friend of mine has this loaded up and is heading to Joe Nall, You can buy this with or without the retracts, you can buy the retracts and struts alone,, either way it is a good deal. $200 for plane, $85 for retracts and Struts, $275 Takes both,
Spektrum™ AR600 DSM2/DSMX receiver, installed
4-channel control - throttle, elevator, aileron and rudder
Powerful 15- sized BL outrunner; 950Kv, installed
E-flite® 30A Pro Switch-Mode BEC brushless ESC, installed
Servos, installed
Dual aileron servos for precise control
**Designed to accept E-flite electric retracts, (optional) **
Durable Z-Foam™ construction
20mm cannon, exhaust and cockpit details
Authentic Johnnie Johnson World War II trim scheme
Includes 3S 2200mAh 25C Li-Po battery
Includes 2- to 3-cell DC variable rate charger
2.25 inch (56mm) Main Wheel Diameter
Needed To Complete
A 4+ channel DSM2 or DSMX compatible Transmitter. 5 channels are required for retract operation.
Retracts And Struts Are Available for Purchase
- 10-15 size main electric retracts (EFLG100)
- Pre-bent landing gear struts are required for this plane (PKZ5717)
Reason: Options,
