Collierville, TN
Joined Aug 2003
FlyVA, I just did a quick search here: http://www.robotshop.com/motors-actuators.html. I'm sure they have something pre-made that you could attach to a drawer . . . Another thought . . . pairing up a "continuous rotation" servo with a "servo tester". I have a cheap servo tester I bought from Hobby King that has a pot you can set the speed. Put a couple Normally Closed switches on the limits of your drawer, hack the servo tester . . . . . Or if you want to go "full Tim "the Tool Man" Taylor on it . . . http://www.robotshop.com/40-stroke-4...-actuator.html . |
| Thread Tools | |
| Discussion Pre-Made Small Parts Drawer Units For Shop - Sources? | itsme2 | The Builders Workshop | 3 | Feb 10, 2012 12:21 PM |
| Can you slide the motor shaft on a Himax outrunner? | Parkflyer | Power Systems | 7 | Feb 10, 2005 11:41 AM |
| Can you slide the motor shaft on an Eflite outrunner? | CDR Randy | Power Systems | 1 | Jan 28, 2005 10:14 PM |
