Old Apr 28, 2012, 02:48 AM
j5ffx is offline
Find More Posts by j5ffx
Joined Nov 2007
Question
FlySky 9x Which failsafe receiver?
Hi, can someone please help me understand this. I'm used to 2/3 channel plug and play transmitters but now I'm getting into fpv.
So, here I am waiting for my FS-TH9X-B radio to arrive and trying to learn what i can about it. In doing so i find there is no failsafe as standard. (correct me if I'm wrong)
OK, lets order one! ah but which one? I cant quite seem to find out which receivers with failsafe are compatible with it as standard.
These are my Qs
1. Which receivers can i buy with failsafe and will work with the original transmitter?
2, Or do i need to upgrade the module as well in order to get a failsafe receiver.
3. Do i need to upgrade the module to use telemetry receivers. ( I would only need/want to know signal strength RSSI )
I have read alot about these 9x radios but i cant find a simple answer to this. Maybe its information overload I'm suffering from lol.
j5ffx is offline Find More Posts by j5ffx
Old Apr 28, 2012, 07:17 AM
reacher10 is offline
Find More Posts by reacher10
reacher10's Avatar
United States, NY, Shirley
Joined Oct 2008
You need to buy a module/Rx that has telemetry such as this.
Module: http://www.alofthobbies.com/jr-trans...ry-module.html
Rx (out of stock here): http://www.alofthobbies.com/frsky-d8...telemetry.html
There are other brands that you can use. If you flash the 9X with one of the many custom firmware options you can have the telemetry data on the screen however there is some soldering involved.
I suggest you start reading here, everything you need to know is available and you will have tremendous support from other members: http://9xforums.com/forum/
reacher10 is offline Find More Posts by reacher10
Old Apr 28, 2012, 07:21 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
These are my Qs
The 9x radio uses a FlySky module. This works only with FlySky receivers, none of which provides fail safe.
To get fail safe, you need to buy an FrSky DJT module and suitable receiver, such as V8R4 for non-telemetry.
The same module will work with FrSky telemetry receivers, such as D6FR.
http://www.frsky-rc.com/Products.asp?BigClassID=17
Daedalus66 is offline Find More Posts by Daedalus66
Found turnigy 9x/flysky 9x wanted!!! kremecheze Aircraft - General - Radio Equipment (FS/W) 2 Mar 25, 2012 04:04 PM
Discussion Stock Turnigy 9x with Chainlink Failsafe? mrracer98 FPV Talk 1 Mar 16, 2012 12:46 PM
Discussion Flysky 9x with Frsky module Which one? glenncol Radios 1 Feb 14, 2012 01:25 AM
Question Adding failsafe to Turnigy 9x? marhar Beginner Training Area (Aircraft-Electric) 1 Dec 08, 2011 05:43 PM
For Sale Turnigy 9x, and 2 flysky rs-6b receivers skyjacker07 Aircraft - General - Radio Equipment (FS/W) 12 Nov 22, 2011 02:27 PM
