Old Apr 29, 2012, 03:52 PM
rusty_y2k2 is offline
Find More Posts by rusty_y2k2
Joined Oct 2007
Malcolm, that won't do you any good... The output from the ezuhf isn't analog. If you want RSSI/link from it on osd pro you need the device I linked to. It's quite cheap, about 12 posted if I remember correctly, and designed specifically for this very purpose.
As I say, best to forget RSSI and use link quality since its available - much better indication anyway.
You simply set up your ezuhf rx to output link quality on a particular channel, attach this convertor and then hook it up to the osd pro. You can then calibrate it by setting 100% with transmitter next to the plane, and then turn off the transmitter (beware failsafes of course!) and set the 0% value.
You should then have a very simple % link quality available to you. The ezuhf link quality is a bit more advanced than just RSSI as I believe it analyses lost packets etc too.
Edit - check this thread for full details on it http://fpvlab.com/forums/showthread.php?3559-PPM-to-Analog-Converter-(For-EzUHF-RSSI)
rusty_y2k2 is offline Find More Posts by rusty_y2k2
Old Apr 29, 2012, 04:04 PM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
Edit - check this thread for full details on it http://fpvlab.com/forums/showthread....For-EzUHF-RSSI)
Thanks for the link I was wondering where to order. I guess I'll just PM the guy.
Cheers
malcr001 is offline Find More Posts by malcr001
Old Apr 29, 2012, 04:11 PM
Joined Oct 2007
Send him an email with postage address and an email for PayPal invoice.... email is order (at) mictronics.de
Btw, eagletree specific info here http://fpvlab.com/forums/showthread....ll=1#post67210
Discussion Better than Keychain cam, cheaper than GoPro? -james- FPV Talk 8 Apr 08, 2012 01:42 PM
Discussion Esky 2.4 ghz Better? than other radios? Bare Radios 1 Dec 08, 2009 05:35 AM
Discussion Walkera 5#6 vs 5G6 - Is one better than the other? RichTJ99 Micro Helis 1 Dec 20, 2007 04:39 PM
Discussion Any TX/RX channel set better than the other? Howemd Radios 2 May 22, 2006 12:56 AM
