Old Apr 27, 2012, 06:29 PM
Pilot Fatigue is offline
Find More Posts by Pilot Fatigue
Joined Jan 2012
Icharger 206b shows balance error....help?
Even when I connect blanche lead straight to the charger.....any ideas.
Would it be ok to fast charge until resolved? Always balance charge and cells
are all matched and always stored properly.
Thanks in advance
Pilot Fatigue is offline Find More Posts by Pilot Fatigue
Old Apr 27, 2012, 07:57 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
I'll bite, what is the error?
What are the cell voltages?
What size packs?
How old are they?
And, NO don't fast charge them unless you want to start a fire.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Apr 27, 2012, 08:02 PM
Joined Jan 2012
When I connect the balance lead to the paraboard......balance error on screen appears. Batteries are 3s and 4s.....all in perfect condition and balance.
This just started today....never a problem before with balance charging.
BTW....charger works fine.....just won't balance due to the balance error message.....maybe a charger issue......??
Old Apr 27, 2012, 08:12 PM
RC Helicopter Pilot
Joined Mar 2010
You have charged these packs before with no problem?
Or course you have the charger set to LiPo and 3S?
And you plug in the main leads and then the balance leads and that's when an error pops up?
Old Apr 27, 2012, 08:24 PM
Joined Jan 2012
Yes....used this charger for 4 months...problem free until today.
Batteries are not the issue.....just thought maybe I dumbed thumbed a setting.
Guess I will just charge w/o balance for flying tomorrow.....never done that but I guess it won't hurt this time...,all cells in all my batteries....Hyperion....match perfectly and stored that way
Any ideas would help.
Old Apr 27, 2012, 10:25 PM
Syner01 is offline
Find More Posts by Syner01
United States, NJ, Lodi
Joined Jan 2012
I had a similar issue on my 206b and turns out I had changed from lipo to life or some other type of battery under balance charge section. All I did was hit start and change it back to lipo and error went away.
Syner01 is offline Find More Posts by Syner01
Old Apr 27, 2012, 11:11 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Have you ever gotten a spark when plugging in a pack to the balancer board? If so and if you run out of ideas and don't have another balance board to try read this and inspect your balancer board.
http://www.rcgroups.com/forums/showthread.php?t=1634850
Rick
rampman is offline Find More Posts by rampman
Old Apr 27, 2012, 11:27 PM
Joined Jan 2012
Had another brand new board I tested.....did the same thing.....gonna call
Dave at progressive where I got it less than 6 mo ago.....any other ideas would be great..... in the meantime.....I be fast charging.
Old May 29, 2012, 06:53 AM
CruiserY2K is offline
Find More Posts by CruiserY2K
CruiserY2K's Avatar
Germany, NRW, Goch
Joined May 2012
Hi guys,
i have exactly the same problem with my brand new i charger 206B. ( 2 weeks old )
After charging the first LiPo pack ( 3S 1000mAh with 2C ) without problems
i liked to start the next charge of my second pack
( no balance board up till now, and the LiPo packs are brand new ).
I have connected the main plugs first, then the balancer plugs.
After that the message "Bal. Err." appeared.
Now i pressed the start button and read: "Balance Port Voltage Err".
By checking the voltage of each cell ( press Dec one time ) i found out,
that the voltage value of cell one is not listed: There are only 4 lines !
Cell two is displayed with 4.97 volts and cell three with 4.17 volts.
BTW: The same procedure now with my first LiPo pack.
Maybe the balancer port is damaged or a short circuit ?
Any ideas ?
Thanks for help,
greetz from germany,
Heiko
CruiserY2K is offline Find More Posts by CruiserY2K
Old Mar 19, 2015, 10:04 PM
Zahid Rasheed is offline
Find More Posts by Zahid Rasheed
Let,s build it and fly ..
Zahid Rasheed's Avatar
Pakistan, Sindh, Karachi
Joined Dec 2010
208b and balance port voltage err
Hi
Well have the same balance port voltage err in my icharger 208b . update charger to new firmware, but nothing
till now open the charger and check inside, no burn no smoke all looks fine.
I don't know what to do. Is there anyone who can help me fix this charger . Im not able to balance charge now ...
Zahid Rasheed is offline Find More Posts by Zahid Rasheed
Old Sep 24, 2015, 02:40 AM
MhmT is offline
Find More Posts by MhmT
Joined Aug 2013
I have the same issue on my 3 weeks old Turnigy Reaktor 300W charger.
Has anyone found a solution to this issue?
MhmT is offline Find More Posts by MhmT
Old Sep 24, 2015, 12:49 PM
SilverSport is offline
Find More Posts by SilverSport
Other side of Your Screen
SilverSport's Avatar
United States, LA, New Orleans
Joined Dec 2014
Sure. I had the same in the first week. Don't plug your balance connector straight into the charger, use the balance board that may have been sent with the charger depending on where you purchased. And - don't plug your main lead charge cable, or leads from a parallel board, into the banana sockets when you have a battery connected to the charge cable, if you don't get that banana plugged in on target .... hit the casing or make a spark of some kind - it will blow out the traces for the balance plugs inside the charger.
Now I plug all that in, then connect to power source and then add batteries. Haven't had a problem since. I think my original problem was from touching the black banana to case with battery plugged in and balance from battery plugged in.
Send it back for repair.
SilverSport is offline Find More Posts by SilverSport
Old May 09, 2016, 02:06 PM
motka is offline
Find More Posts by motka
Slovenia, Gornja Radgona, Radenci
Joined Feb 2016
This discussion was not continued. Can you change the traces? Or is the charger a goner?
motka is offline Find More Posts by motka
Old May 09, 2016, 02:40 PM
Joined Dec 2014
You might be able to, but their would be a ton of soldering to do. On mine it was traces on the balance board .... this board has all of the 5 balance connectors solder to it, then it is soldered onto the main board. When I took it apart I could see the breaks but did not want to take it all down to fix, If I recall there is something blocking access to solder directly to that board.
Help! Low Voltage warning in iCharger 306B when plugging in balance port, please help jasper7821 Batteries and Chargers 15 May 04, 2012 11:57 AM
Sold iCharger 206B and accessories mode1 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 09, 2012 03:59 PM
Sold iCharger 206B with PSU hi2nr Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 01, 2012 04:08 PM
Help! ICharger 206B Temperature sensor emelum Batteries and Chargers 3 Feb 04, 2012 11:47 PM
Wanted iCharger 206B Davey NY Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 21, 2011 08:34 AM
