Old Oct 29, 2003, 03:01 AM
Chas Hunter
Chas Hunter
Guest
n/a Posts
Setting Piston Valve Gear Timing
Hi
Can someone tell me how to set a steam engine's piston valve gear please.
Have timed slide valves ok - but not sure if its the same for a piston.
Chas
Old Oct 29, 2003, 06:01 PM
Colin MacEke
Colin MacEke
Guest
n/a Posts
Re: Setting Piston Valve Gear Timing
When the piston is as far forward as it will go, then the inlet port should
be on the point of opening.
Setting up GWS gear stevem1928 Beginner Training Area (Aircraft-Electric) 9 Aug 03, 2002 02:44 PM
