Old Apr 27, 2012, 02:19 PM
ChrisDangerPants is offline
Find More Posts by ChrisDangerPants
United States, MI, Ann Arbor
Joined Jan 2012
New to FPV, my 5.8ghz goes thru my house when I was told it wouldnt..
So ive been told that 5.8ghz wont go thru trees, humans, much less a house...
I just tested that theory and I was able to penetrate an entire house (1 glass door, 3 walls, and a wood front door)
Im using a 5.8ghz 100mw immersionrc with blubeam whipset, dominator goggles...
So whats the real penetrating power of 5.8ghz?
ChrisDangerPants is offline Find More Posts by ChrisDangerPants
Old Apr 27, 2012, 02:51 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Ooo ok well how much farther were you able to get reception past your house? What likely happened is that the signal actually went over the house than through it.
Remember that the signal is transmitted in a sphere from the antenna not in a straight line. Try covering the antenna completely with your hand and see how that goes.
5.8 is the worst out of all the available frequencies in regard to penetration. Just a fact of physics
ashdec87 is offline Find More Posts by ashdec87
Old Apr 27, 2012, 02:52 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Oh and usually it's the water in people, the leaves of trees, clouds, etc that cuts the signal. Doors and walls are fairly dry.
Old Apr 27, 2012, 03:03 PM
nkkromhof is offline
Find More Posts by nkkromhof
NKK for short...
nkkromhof's Avatar
United States, IN, Mitchell
Joined Oct 2010
You'll also find that humidity will influence range. The 5.8Ghz signal will go 'through your house', after all 5.8Ghz is used for WiFi as well, it's just a matter of how much your range is reduced by having to go through solid objects.
There is no accurate, meaningful way to describe the actual 'penetrating power' of a given frequency/output power combo because there are so many variables (noise floor, antennas used, etc.)
nkkromhof is offline Find More Posts by nkkromhof
Old Apr 27, 2012, 03:07 PM
Joined Jan 2012
thanks guys! that explains a lot!
Old Apr 27, 2012, 03:10 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
I think your house might be made of paper.
chaosdestro0 is offline Find More Posts by chaosdestro0
New Product My new 5.8GHz Video TX for FPV 7.5gram... CSG_EU FPV Talk 19 May 02, 2012 03:49 AM
Found fpv goggles (480 rez) for my foxtech 200mw 5.8ghz ro.bi. FPV Equipment (FS/W) 0 Apr 23, 2012 12:01 PM
Found My IPAD for FPV gear (900mhz, 2.4ghz, 5.8ghz vtx,vrx, uhf radio etc) crd FPV Equipment (FS/W) 1 Jan 28, 2012 10:28 AM
Discussion Quad goes crazy when FPV equipment is turned on ! oded mazor Multirotor Talk 1 Sep 08, 2011 05:19 PM
Sold FPV a/v system 5.8ghz 200mW NEW karolpenconek FPV Equipment (FS/W) 1 Mar 22, 2011 08:01 PM
