Old Apr 27, 2012, 11:10 AM
DDallaire is offline
Find More Posts by DDallaire
Joined May 2010
Help!
Quad Copter - Xconfig w/ HK V3.0 Board
Taking my 1st whack at a quadcopter. Have it completely built. Tested all motors for direction, calibrated ESC's per HK recommendations, and do hear correction with out the props.
After adding props and testing (very carefully), while holding in my hand, from the rear of the copter, on my 1st power up with the props, it tried to, very severely, flip over to the right.
Using a Futaba 7c transmitter, Throttle is reversed and all else is normal. All trims on the xmitter are at neutral.
Any suggestions as to where to start to diagnose the problem?
Thanks.
DDallaire is offline Find More Posts by DDallaire
Old Apr 27, 2012, 11:16 AM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Are your gyros working properly. Does your roll gyro need to be reversed?
Dave8888 is offline Find More Posts by Dave8888
Old Apr 27, 2012, 11:20 AM
reelflyt is offline
Find More Posts by reelflyt
reelflyt
Edmonton, Alberta, Canada
Joined Mar 2010
HI.
The problem is not the transmitter but the gyro on the board has to be told which way to react.
If it wants to flip over sideways then reverse the roll gyro . If it wants to flip over in pitch then reverse the pitch gyro .
Gordon
reelflyt is offline Find More Posts by reelflyt
Old Apr 27, 2012, 02:11 PM
Joined May 2010
Thanks Dave / Gordon,
I'll give it a try. I guess what didn't lead me to that was if it was correcting, it was correcting severly to the right. I was holding it relatively level and sticks / trim was neutral.
Not hard to reverse. I'll try that tonight.
Thanks again.
Dan
Question Quad Build Using HobbyKing Multi-Rotor Control Board V3.0 (Atmega328 PA) SJackson Multirotor Talk 27 Apr 30, 2012 08:51 PM
Sold Foldable Quad copter X525 V3 Kit kevinlib Aircraft - Electric - Multirotor (FS/W) 3 Apr 26, 2012 07:23 PM
Help! Phoenix V3 Quad Copter CT4 Simulators 1 Mar 30, 2012 01:38 AM
Sold Foldable Quad copter X525 V3 Kit kevinlib Aircraft - Electric - Multirotor (FS/W) 5 Mar 23, 2012 03:16 PM
For Sale Paris control board v2.0 and v3.0 Talajouy Aircraft - Electric - Multirotor (FS/W) 3 Feb 28, 2012 01:52 PM
