Old Apr 27, 2012, 04:26 AM
twinkle is offline
Find More Posts by twinkle
It can't rain all the time
twinkle's Avatar
United Kingdom, Peacehaven
Joined Mar 2009
Falcon 56 hybrid in depron at .85 size
Hi All
over 30 years ago just after I leant to fly I was given a falcon 56 it had been modified with flaps and large outboard ailerons . I found the plan on a uk database of vintage plans www.outerzone.co.uk and downloaded it . My original was powered by a webra 40 and was a real dream to fly .Now over 30 years later I found the plan again and i'm building a .85 size at 48" in span it will fit happily in one piece in the boot of the estate car . This one will be powered by a 3530 brushless motor and be constructed in depron . I will start to post photos as I progress
At present I am considering modifying the wing section to a kfm6 and rigging the model 0 0 0 to increase its aerobatic characteristics
regards emma
twinkle is offline Find More Posts by twinkle
twinkle is offline
twinkle's Avatar
Joined Mar 2009
Pre Flight Photos from later posts
Editted 21st May 2012
Here are the first pre flight photos from later posts
The test flights went well But I would suggest a 3536 motor and 2200 lipo and a 10" prop
the 3530 was screaming its little heart out on a 9x4.3 prop just like an IC motor
below are the photos of the 42" Falcon 2822 motor 9x4.5 30amp esc and 1000 lipo
Build Photos of the 42"
http://www.rcgroups.com/forums/showp...&postcount=175
Baby falcon 1/2 size added 12/9/12 still needs pushrods etc estimated 400gm auw
emma
Last edited by twinkle; Sep 12, 2012 at 03:10 AM. Reason: update Little falcon added 1/7/12 baby 12/9/12
Old Apr 27, 2012, 04:27 AM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
models
here are the post 3 models
this post was reserved for other peoples models
here are the first photos
Birdof play Falclone 56 see post 164 for more details of this model
the depron parts are available cnc pre cut to shape to speed assembly
My Fun master 42 /48
The Funmaster, a slimline tail dragging version built on falcon technology see later in the thread
It uses a KFm wing sections as a test bed for other models and an ambassador for the KFm wing section
Justj Jerry's 45" tail dragger falcon .
Superb75 Jeans 50" foam Falcon prior to finishing 2 views
other photos will follow
emma
Last edited by twinkle; Aug 20, 2012 at 02:45 AM. Reason: justj and superb75 photos added
Old Apr 27, 2012, 06:55 AM
owlsabie is offline
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Got it! Enjoy the build
Owl
owlsabie is offline Find More Posts by owlsabie
Old Apr 27, 2012, 09:22 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
This is nice. I started with a Falcon 56 in 1969 and an OS 35.
It was Thailand and we couldnt get nitro so we just used alchohol from Bankok
and castor oil from the AFB.
Still it was a solid fun flying trainer.
I know the plans are in a box amongst a roll of many othe rplans.
I've been meaning to do WHAT you are doing .
Thanx for the outerzone tip. It saves me the trouble of all the searching and scaning.
Made from Foam we could call them Foamcon 56 as in Foam construction.
Are you going to try a full FOAM but built up like balsa type construction ?
edit later: sorry I reread you are doing kfm.
Will you be doing plans or should I get started on my version of plans ?
Good luck with you ideas and build.
Bob
Northwest Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Apr 27, 2012, 09:48 AM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
Foamcon now thats an idea
Bob
Thanks Bob
Wont be doing plans I use the original plan on outerzone and printed it out at 85% the outline of the" foamcon" will be very similar to the original the formers will be a ply faced composite .it wont be a built up wing as such ( see the jackal thread ) more a main spar and depron covering .or a kfm wing
I want to put 1.5x 3/8 strip ailerons on mine with a non dihedral wing and possibly inboad flaps just like my old one
this thread was started as I think I trud on someone else's patch yesterday so everyone is welcome here all ideas and any size I'm sure someone will make a hugh one and others cut down to 39"
I've reserved the first few posts for photos of the finished items . the concept is not for first time builders but for anyone who wants a go at building an old faithfull who's origin is half a century old using their own methods to get their results .
So Come on lad's lets get building and have a fun machine and for us oldies a trip back to memory lane without the smell of nitro in my case!!!!
The foam falcon artf has now been released at 37" span if built it that small I would have to fly it in circles like a control-line model so I could see it.
regards emma
Old Apr 27, 2012, 10:18 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
As soon as I get the Image extracted from the PDF I am going to CAD for
my version of the plans.
I thought it might b fun to try a built up wing with 6mmfoam ribs and 3mm foam covering
and a bit of CF in the spars.
Probably some .8-1mm play laminated foam parts in the forward Fuse to soak up abuse.
Whats the link on that other thread ?
Thanx
Bob
Old Apr 27, 2012, 10:34 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
NICE. I'll be following this build Emma. Looks like it will be a real winner at this size, material, and motivation system. The KFM sounds interesting, but Bob's idea of a built up foam wing great too. Maybe we will see both for comparison!
Good luck and looks great so far.
Fred
Freddie B is offline Find More Posts by Freddie B
Old Apr 27, 2012, 10:40 AM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
baked wings
Fred
Hi Fred nice to hear from you again
would be nice to bake a couple of depron sheets for the wing covering
how about it fred I know you want to build one
Old Apr 27, 2012, 11:31 AM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Great build do you have any more links to old plans like that?
dedStik is online now Find More Posts by dedStik
Old Apr 27, 2012, 11:32 AM
superb75 is offline
Find More Posts by superb75
superb75's Avatar
Quebec City, Qc, Canada
Hello, am very interested in this log.
I'm back into r / c and it seems that the price of balsa has increased incredibly. I was wondering already if I was not going to build a Falcon 56 out of foam. I understand that you will use a kfm6 wing section for yours. I think I'll try to reproduce the original profile.
I do not have much experience with the foam. I have only one BluBaby 42 (kfm3) under my belt.
I will read with interest!
superb75 is offline Find More Posts by superb75
Old Apr 27, 2012, 11:36 AM
twinkle is offline
twinkle's Avatar
Joined Mar 2009
link to old plans
go to outerzone.co.uk there are 1000's of plans there just waiting for you
regards emma
Old Apr 27, 2012, 11:41 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
This is one of my favorites, here on RCG too. Vintage & Olditimer Plans. Check it out, then pray for two hundred more years to build 1/10th of the plans there!
Fred
Old Apr 27, 2012, 11:43 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
DO NOT got to OUTERLINK !
You will not know what to do at 1st and you will be paralyzed for days ! ;-}
Bob
Old Apr 27, 2012, 11:47 AM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Hahaha...... I do want to build one! You caught me! Problem I am 2-3 days into a Hawker Hurricane build, 80% done on a micro F84 27mm EDF, not counting the others that have dust on them...... I'm a naughty boy because I have to force myself not to start another 20+ builds every day. I'm sick I say, sick.......
Waiting for more........ more.......
Fred
Oh, BTW...... 3mm white Depron, or 6mm gray Depron makes a great fold over spar wing that can Really be the same as a Clark 'Y'. Semetrical that way is a bit harder. Don't tempt me to post a nini-how-to somewhere. You might just love it.
Build Log Falcon 56 Scratch Build Crist Rigotti Vintage & Old-Timer Designs 421 Jul 12, 2015 01:40 PM
Sold Carl Goldberg Falcon 56 Mark II videonic Aircraft - Fuel - Airplanes (FS/W) 0 Apr 25, 2012 08:07 PM
Sold CG Falcon 56 NIB skylane42 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 24, 2012 03:38 PM
Sold Goldberg Falcon 56 kit NIB mike912e Aircraft - Fuel - Airplanes (FS/W) 1 Mar 15, 2012 04:44 AM
Help! I need a Falcon 56 Canopy. Crist Rigotti Vintage & Old-Timer Designs 13 Jan 30, 2012 11:52 AM
