Herminie, PA 15637
Joined Apr 2007
ALES glider designs
Hello from RCbobcat55@yahoo.com I must say you have some very impressive looking models. I am by chance working on a prototype 96" span electric sailplane which may be competetive in this event and certainly will be cheaper to obtain. It has a 6 panel foam core balsa sheeted wing (or you can vac bag it if you want) featuring 4 different Drela AG airfoils from root to tip. A pod and boom fuselage (custom laid up glass one is in the works, and a V tail to keep it simple. Also flaps in the center sections. Two piece wing which slides onto rods in the fuselage. Built-up sheeted V tail. I have not worked out the best power system for it yet but I want to keep things reasonable so most people can afford it and also be competetive. So far I have the wing, tail, and prototype pod built and may build another pod more suited to electric power instead of just cutting the nose off. I have access to a laser cutter and also produce foam cores for a number of small kit manufacturers as well as one-off designers. I can clean up my 3-view sketches and e-mail copies of them to anyone who wants to see what it looks like. Let me know if you have any insterest. Thanks Bob M...
| Thread Tools | |
| Discussion Requesting a forum for ALES (Altitude Limited Electric Soaring | GaryO | New Forum Requests | 85 | Jul 15, 2012 05:15 PM |
| Discussion Altitude Limiting Switches | rc4fun | Altitude Limited Electric Soaring (ALES) | 42 | May 17, 2012 12:21 AM |
| Discussion ALES - Altitude Limited Electric Soaring | shinck | Intermountain Silent Flyers | 36 | Feb 20, 2012 03:47 PM |
| Help! [Recorder Beta] Voltage on Temp B & Limit on OSD | alexvan | Eagle Tree Systems | 1 | Oct 03, 2011 08:03 AM |
| Discussion would this battery charger be an ok choice for a extreme budget limit? | chase4556 | Batteries and Chargers | 7 | Mar 01, 2006 07:41 AM |
