Old Jan 01, 2013, 03:19 AM
Karl_f3p_GER is offline
Find More Posts by Karl_f3p_GER
Joined Nov 2010
Originally Posted by Xavier Mouraux View Post
Hi Karl,
How does it work if a pilot is also the manager. Do we fill 2 forms and register twice ?
Also: any airplane museum suggestion in a 500km radius from Frankfurt ?
Xavier
Hello Xavier,
if there is no extra Teammanager there is no need to fill out an additional form. But keep in mind to announce also Helpers and Supporters by an extra form.
Best regards,
Karl-Ernst
Karl_f3p_GER is offline Find More Posts by Karl_f3p_GER
Old Jan 01, 2013, 09:35 AM
Xavier Mouraux is offline
Find More Posts by Xavier Mouraux
Xavier Mouraux's Avatar
Canada, QC, Laval
Joined Oct 2005
Thanks Karl-Ernst. We'll do that.
Thanks Jurgen and FAI guy. Now I need to extend my vacations with so many suggestions :-) I also wanted to see the Porsche and Mercedes museum ...
Xavier Mouraux is offline Find More Posts by Xavier Mouraux
Old Jan 01, 2013, 12:57 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
List of pretty much all auto museums in Germany:
http://www.auto-museum.de/liste.htm
You will find the Porsche and Mercedes Museums there too.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jan 02, 2013, 04:48 AM
JanneL is offline
Find More Posts by JanneL
Janne Lappi, F3A Team Finland
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Hello,
who will sign the entry forms for World Champs and for German Challenge? There is a line for signature, but I wonder if it will be signed by myself or by the NAC.
About the epuiqment information, there are two text boxes for "manufacturer". I understand the first one means the manufacturer of the airframe, but what is the other one for?
Regards,
Janne Lappi
JanneL is offline Find More Posts by JanneL
Old Jan 02, 2013, 08:03 AM
Joined Sep 2000
Hi Janne,
the most logical answer would be the manufacturer of the motor used.
If it was up to me, I would ask for prop, servos and rx rather than transmitter.
Jürgen
Old Jan 02, 2013, 01:48 PM
Joined Nov 2010
Hello,
Regards,
Janne Lappi
Hello All,
entry form needs to be stamped and signed by the NAC (bottom line). Two times Manufacturer = 1 time Modell, 1 time Motor
Best regards,
Karl-Ernst
Old Jan 06, 2013, 09:21 PM
Canada, QC, Laval
Joined Oct 2005
Hi Karl-Ernst,
I just noticed that the drug form says 'FAI European .. helicopter 2012' :-)
Is it still good or should we sign another one on site and forget about that one ?
Should that one be stamped also by the NAC ?
4 weeks :-)
Xavier
Old Jan 07, 2013, 04:43 AM
FAI_guy is offline
Find More Posts by FAI_guy
Joined Jul 2007
Hi Karl-Ernst,
4 weeks :-)
Xavier
Hi Xavier,
Use this one. No NAC stamp needed, this is private.
Important : any competitor using medication (for example to regulate blood pressure, diabete etc.) containing a substance in the WADA list of prohibited substances must ask the FAI office for a TUE (Therapeutic Use Exemption). This is again personal but it is high time as obtaining the certificate may need a minimum of 3 weeks.
See also http://www.fai.org/cimp-projects/cim...xemptions-tues
FAI guy
FAI_guy is offline Find More Posts by FAI_guy
Old Jan 15, 2013, 12:49 PM
Joined Nov 2010
WCh is comming closer
on the homepage www.indoorwm.de plenty of information is now available.
All teams are listed, ....
If somone still likes to join the competition feel free to send the offficial entry form.
Looking forward seeing some of you at Coburg.
best regards
Karl-Ernst
Old Jan 19, 2013, 05:35 AM
JanneL is offline
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Originally Posted by pmackenzie View Post
I have flown in quite a few W/C (in other classes), and you can make your own stickers, including scaled down versions.
We usually print them on clear label stock(Fascal) in a laser printer. Here is an example in a pdf, 1:1 scale.
IIRC the original was downloaded from the FAI web site.
In addition to the sticker you need your national ID number somewhere on the model, but that can simply be drawn on with magic marker.
Typically in processing they will apply another small sticker partly over yours as proof that the model has been processed.
I have also seen them use ink stamps or initial them.
Pat MacKenzie
Hello,
there were discussion about the FAI sticker and I would like to get information about this from contest organisers. Is it allowed to make an own sticker which includes the same information than the original one? Can I scale it a bit smaller? I want to be sure our models are completely legal so that there will appear no surprises at the model processing.
Regards,
Janne L
Old Jan 19, 2013, 07:56 AM
lsky is offline
Find More Posts by lsky
Joined Jan 2005
thanks to ask janne, I have the same questions !
Loïc
lsky is offline Find More Posts by lsky
Old Jan 19, 2013, 11:10 AM
Joined Nov 2010
FAI Stickers
hello all,
FAI Stichers Layout can be found at
http://www.fai.org/component/phocado...imodelstickers
you can print and apply it on your own. About resizing it I don't know.
We will prepare decal stickers that will be available at the contest. Attaching them to the modell and fixing them long lasting is a litle bit tricky - so pending on everybody themselves to apply them ...
best regards,
Karl
Old Jan 23, 2013, 11:30 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Hi,
quick question, will there be Wifi in the arena?
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 24, 2013, 02:03 PM
Joined Nov 2010
Quick Answer but LIVE STREAM FR- SA available
No!
We have internet access but only for the organization Team.
Additional we will have an Live Internet Stream for the finals, open German Challenge and the indoor show Saturday evening ... so everybody around the world can follow the last part of the contest directly online ...
Transfer Volume will be enough for 11000 spectators at a time ..
Formats available for a wide range of equipment from all kinds of Mobile Phones to Computers.
Videos can also be reviewed at any later time.
Link can be found at www.indoorwm.de
Lets see how far we can go. Maybe you can announce this in your local comunities. We would like to see the full load test.
Best regards,
Karl
Old Jan 25, 2013, 05:58 AM
3w_flyer is offline
Find More Posts by 3w_flyer
Joined Oct 2008
Can you buy a prepaid sim card in Germany for internet on smartphones or laptops ?
that can be usefull.
I guess the local mc donalds also provides free wifi for customers ?
3w_flyer is offline Find More Posts by 3w_flyer
Gallery First pictures from nuremberg toyfair 2012 in germany guyro Electric Heli Talk 15 Feb 06, 2012 08:53 PM
Gallery First pictures from nuremberg toyfair 2012 in germany guyro Fuel Heli Talk 3 Feb 06, 2012 07:51 AM
Discussion My first F3P plane. Any reccomendations? tele1974 Indoor Pattern/F3P 42 Dec 23, 2011 09:36 AM
Discussion First F3P competition in Slovenia alan_g Indoor Pattern/F3P 7 Dec 14, 2011 06:05 AM
Discussion First Multicopter Flight School in Germany / Berlin - Open NOW - Rc Heli Halle Multirotor Talk 0 Sep 09, 2011 09:09 AM
